Doktor Napisano Septembar 8, 2017 #89 Napisano Septembar 8, 2017 8 minutes ago, sir Oliver said: Valjda će rešimo nekako Resimo ? Nema razloga da govoris u moje ime. Ja uipravo krecem u "Slon"-a na mutni Paulaner. https://foursquare.com/v/slon/4f66618de4b0eae10c2214b8 Jbga, poceo vikend, pa da se pocastim malko. Ti se vec snadji u Nish ( vec ti rekoh, ali ti mnozina, pa mnozina ). Zflazar je reagovao/la na ovo 1
ZZZ Napisano Septembar 8, 2017 #90 Napisano Septembar 8, 2017 On 9/7/2017 at 4:15 PM, Colin Wonfor said: The above statement is not quite correct:- Sorry No, this is wrong, Magnum was formed from my company MIH, which became Pro-Ac Magnum, then Tony Relph joined me as a business guru, then after 3 yrs managed after locking me out after a holiday stole the company and I was force to take legal action for use of some patents. and stealing my company. Meanwhile I started Inca Tech producing no electronics until the legal action was resolved but the world first Gold Plated Power Connectors for the audio world, now be warned never share a company 50/50 if you have started it you partner may not be so trustworthy as you. And for folk out there here is a rough list of other things I have designed. In order:- Pushpull 1 Germanium Amp 1971 V1 Tube amp 1972 12W Single Ended A Class 1974 MIH 100W 1975 MIH 400W ProAc stereo 100w 1980 ProAc 3 Channel 100W Magnum A100, 400W 1982 Magnum A200 Magnum Pre-amps IncaTech Gold Plated Power Plus and Sockets 1982 Inca Tech Sabre iss 1 1983 Inca Tech Prelude Inca Tech Claymore 1 1983 Inca Tech Claymore Gold Inca Tech Claymore S Inca Tech Claymore 2 Inca Tech Quatra Inca Tech FMT Tuner Inca Tech IT50,IT100,IT200 Inca Tech IT1P preamp Inca Tech Sabre iss 2 Inca Tech Dirk Inca Design ID25,ID50,ID75 Inca Tech MSB (a monster) Inca Design Oberon Classic Inca Design Oberon (standard) Lescon Quatra Oxford Acoustic's "Mystic" TOCA SECA 20W,50W,100W,200W,300W single ended class A,s 1995 TOCA I75 TOCA Pre A TOCA 75W Tellurium Q Cables 2009 Tellurium Q, A Class 20W, 100W 2011 Tellurium Q Headphone/Phono Amp Tellurium Q Pre-Amp EWA (Elsdon Wonfor Audio) A complete range of new designs after yet another twit full of greed stole by waiting for me to become very ill yet another company from my original company called Catch 22 then it became Tellurium Q. EWA have cables, Power Amps, Pr-Amps, SECA Amps. Read on:-http://seca.freeforums.net/ https://www.elsdonwonforaudio.com/ Products worked on Naim Nait 5i, other bits also for Naim and Cambridge Audio. 2008- 2010 Hi I am interested in Your first designs Would You be kind and share these 3 circuits? Pushpull 1 Germanium Amp 1971 V1 Tube amp 1972 12W Single Ended A Class 1974 thanks
Doktor Napisano Septembar 8, 2017 #91 Napisano Septembar 8, 2017 5 hours ago, sir Oliver said: Valjda će rešimo nekako Ja zaista ne znam kako ces ti resiti to sto si zamislio, ali evo ja, kao sto sam i obecao, da ti dokumentijem kako bi to trebalo ( odprilike ) da radis : 74 Zflazar and crni. je reagovao/la na ovo 2
crni. Napisano Septembar 9, 2017 Autor #92 Napisano Septembar 9, 2017 uradio test magnum fono sekcija vs mf m1 m1 sam povezao sa kimber pbj kablom na cd input i samo gramofonski kabl menjao čas ovamo, čas onamo ploče od rtb iz 80ih do 180g, od džeza do roka m1 ima veći volumen instrumenata i glasa, nešto manju detaljnost i generalno bolje zvuči svuda osim na roku m1 na istom nivou glasnoće daje više zvuka...ni na većem nivou glasnoće magnum mm ne može da dostigne taj volumen, ali ono što mi se nikako ne sviđa je to da m1 skroz menja karakter magnum zvuka...kao da sam uključio neko drugo pojačalo, a to ne želim da imam više ulaza na ampu verovatno bih priključio i m1 pa bi se igrao sa muzičkim pravcima...na njega bi definitivno išlo sve što ima veze sa džez triom ili ona cilimili muzika što kaže zen ovako, ode i m1 u orman da čeka neka druga vremena Zflazar and Doktor je reagovao/la na ovo 2
Doktor Napisano Septembar 9, 2017 #93 Napisano Septembar 9, 2017 Da sada ne pretrazujem po tvojim postovima, ali koja je zvucnica u pitanju ? Sto se tice specifikacija za Magnum MP 150 vezano za MM i MC : Moving Coil: 220u volts, 100 ohms / 30pfMoving Magnet: 2.8m volts, 47 ohms / 100pf
Zflazar Napisano Septembar 9, 2017 #94 Napisano Septembar 9, 2017 ne bih da uterujem crnog u dužničko ropstvo ali mislim da bi taj magnum trebao da ode na pošteni recap kod nekog poštenog servisera da se zamene ti stari elektroliti da bi ovaj preamp pokazao šta može. Doktor je reagovao/la na ovo 1
Doktor Napisano Septembar 9, 2017 #95 Napisano Septembar 9, 2017 Evo nesto vezano za MP 150 : http://www.kabrna.com/hifi/magnum_review.htm Ima elemenata koje je @crni. opisao. Sound Quality During and after the listening tests our panel commented on what they considered to be a marked discrepancy in performance between the line and disc stages of the pre-amp, despite being very impressed at the overall sound of the combo. Specifically, the line input was thought to sound smooth and very tidy with a balanced, strain-free and extended bandwidth. Furthermore it offered a good sense of pace and involvement and while there was a hint of graininess at the very top of its range this did little to dampen our listeners' enthusiasm for the emotive accuracy of the music. Meanwhile the combo failed to reveal all the spatial qualities available from the PDM compact disc source which we used during the listening tests, even though this omission was traded for a degree of comfort and fluidity missed by many other amplifiers - a justifiable bargain in the view of the assembled listeners. On the downside there was an immediate narrowing of the soundstage, though no apparent loss in stereo depth via MM disc. In tonal terms the sound of the MP150 / MF150 combination was smooth and even; strings were a little strained but were certainly not hard or edgy. However the music, though not totally lacklustre, was neither particularly vivid nor alive, and was described as 'languid' by one listener when compared to the radiance of the CD input. Via the CD input it was the subtle captivation of the amp - its sheer lack of the obvious - that dawned on our listeners over a period. One erudite panelist implied that it homed-in on the intellectual centres of the brain rather than going for the throat! Conclusion If only from the subjective standpoint this pre / power combination is particularly suited to CD-based systems, with records as a secondary source. The MOSFET power amp is clearly the more successful of the duo, for the pre-amp's value - though still high - is inevitably compromised by its flexible but inferior disc stage. Still, with these provisos in hand, and bearing in mind the keen pricing of the amplifiers, a qualified recommendation seems most appropriate. Mozda se ponovo prikljuci Colin pa da neki hint za upgrade phono stage-a ? Coline - javi se.
sir Oliver Napisano Septembar 9, 2017 #96 Napisano Septembar 9, 2017 Dotore, pivo je piće bez ideje. Kad će stasaš do vina ?
chakija Napisano Septembar 9, 2017 #97 Napisano Septembar 9, 2017 57 minutes ago, Zflazar said: ne bih da uterujem crnog u dužničko ropstvo ali mislim da bi taj magnum trebao da ode na pošteni recap kod nekog poštenog servisera da se zamene ti stari elektroliti da bi ovaj preamp pokazao šta može. Maaali problem-pitanje je da li ima dovoljno veliku lupu...
crni. Napisano Septembar 9, 2017 Autor #99 Napisano Septembar 9, 2017 2 hours ago, Doktor said: Da sada ne pretrazujem po tvojim postovima, ali koja je zvucnica u pitanju ? Sto se tice specifikacija za Magnum MP 150 vezano za MM i MC : Moving Coil: 220u volts, 100 ohms / 30pfMoving Magnet: 2.8m volts, 47 ohms / 100pf ortofon blue, a ručica rb 250
Doktor Napisano Septembar 9, 2017 #100 Napisano Septembar 9, 2017 20 minutes ago, crni. said: ortofon blue, a ručica rb 250 Gledam za Ortofon Blue kapacitivnost - 150-300 pf. ( Magnum MP 150 MM phono ima 100 pf. ) Takodje output voltage je 5.5 mV ( Magnum - 2.8 mV ). https://www.ortofon.com/ortofon-2m-blue-p-333 Ocigledno je da po specifikacijama recimo sada vec vintage Ortofon serija 500 bi bila u svakom slucaju bolji match. https://www.ortofon.com/500-series-p-615-n-4873 ( Ortofon Serija 500 - kapacitivnost 100-400 pf, a output voltage je nesto veci od 3 mV, sto je u svakom slucaju blize 2.8 mV u odnosu na 5.5 mV koju ima Blue ). Ocigledno da kada je izasao Magnum preamp (1990 god. ) i zvucnice toga vremena su bolji match pair od zvucnica ovih novih serija.
crni. Napisano Septembar 9, 2017 Autor #101 Napisano Septembar 9, 2017 da, ali još u to vreme ljudi su menjali preamp za neki drugi jer je mp 150 bio slaba karika kupovali su mp 160 ili mp 250 meni mp 150 dobar i za sad ništa ne diram, osim ako se colin ne javi nešto predloži
crni. Napisano Septembar 11, 2017 Autor #102 Napisano Septembar 11, 2017 mnogo se lepo osećam...ćerka mi juče uspešno operisana od slepog creva, dobro je i fino se oporavlja posle paklenog vikenda i horora koji se hvala Bogu završio, sistem mi svira bolje nego ikad vladd, Doktor, Woland and 2 ostalih je reagovao/la na ovo 5
Doktor Napisano Septembar 11, 2017 #103 Napisano Septembar 11, 2017 ^ Brz oporavak za kcerku. Btw, ooodlican ovaj prvi vinil sto je dole ispod Harbeth leve kutije. Prakticno, obavezno stivo kako za slusanje, kako i za imanje u kolekciji svake kuce koja slusa dobru mjuzu. crni. je reagovao/la na ovo 1
Pchelac Napisano Septembar 11, 2017 #104 Napisano Septembar 11, 2017 Hvala Bogu! Uživaj... crni. je reagovao/la na ovo 1
Stradi Napisano Septembar 12, 2017 #105 Napisano Septembar 12, 2017 Da ti se cera super oporavi. Zflazar je reagovao/la na ovo 1
Zflazar Napisano Septembar 12, 2017 #106 Napisano Septembar 12, 2017 Just now, Stradi said: Da ti se cera super oporavi. +1
Beli Napisano Septembar 12, 2017 #107 Napisano Septembar 12, 2017 12 hours ago, crni. said: ćerka mi juče uspešno operisana od slepog creva, dobro je i fino se oporavlja Nadam se da je operisana na vreme i da slepo crevo nije puklo ... brz i uspešan oporavak za malu.
crni. Napisano Septembar 12, 2017 Autor #108 Napisano Septembar 12, 2017 sve je dobro prošlo, danas počinje da uzima tečnost...rana je malo boli, ništa strašno...hvala svima na podršci vladd, Beli and Zflazar je reagovao/la na ovo 3
sir Oliver Napisano Septembar 12, 2017 #109 Napisano Septembar 12, 2017 Dejane sve najbolje želim detetu. Nego daj neku sliku levog zida sobe. Može li Herberti da se ture u bookshelf ko što spada?
NIXIE Napisano Septembar 12, 2017 #110 Napisano Septembar 12, 2017 11 minutes ago, sir Oliver said: Dejane sve najbolje želim detetu. Nego daj neku sliku levog zida sobe. Može li Herberti da se ture u bookshelf ko što spada? Bolje ovako, sve dobro izgleda, onako baš Engleski, kad se stave blizu zida ili u policu ode stereo slika, nema dubine, a zvučnici ima samo da tutnje bez definicije u basu. Zflazar and crni. je reagovao/la na ovo 2
