  • 1 month later...
  • 2 months later...
  • 3 years later...
  • 3 months later...
  • 1 year later...
  • 3 years later...
  • 9 months later...
AUDIOXPRESS.COM
A few years ago, Jan Didden designed a high-voltage delay unit and shared its details in a 2019 audioXpress article. Many people built it and like it, but others said that it would be totally unnecessary. As so often happens in audio, arguments pro and con raged without a clear resolution. So Didden thought this was something he needed to get his head around. He found several sources, which he thought were credible, and this article is the...
36 minutes ago, NIXIE said:
Da iznenađenje, skoro dva dana nisu radili. Mika to završi za 5min. :haha:
Mikum ne menja software
Mikum se samo okrene
  • 10 months later...
Za ljubitelje cefki ...
WWW.NATAUDIO.COM
Single Ended Mono Block Power Amplifier Our flagship power amplifier! NAT produced the most powerfull single ended (with single tube) amplifier, globa...
..... - approx. 500J of energy storage in power supply
pa ti vidi .....
:Viannen_loungelizard:
  • 1 year later...
pa ti vidi .....
Samo da se pohvalim malo kad smo kod "JOULES" ...
Moj modifikovani Beard P100 sa 4 "Sylvania Vacuum Tubes 6KN6" ima 750J "of energy storage in power supply", orginalno je imao samo 50J.
Neverovatno je da su 6KN6 NOS oko 20-30$ po komadu, puno jeftinije nego KT88/6550, a znatno kvalitetnije cevi.
Na tom P100 bas je neverovatan (na B&W 802 Matrix zvucnicima), mnogo cistiji i dinamicniji nego na Audio Research D115 i Audio Research D90, mada je zvuk jako dobar na oba (D115 i D90) - rado ih slusam ...
