neskor
Sve objavljeno od neskor
  1. neskor
    300B pojačalo
    A very simple method would be a relay switched B+ with the relay being triggerd by the bias voltage. Either have the B+ on a spearate transformer which is switched on through the relay. Or have the relais in the ground connection to the center tap. If the bias voltage fails, the relay opens and B+ is drained through bleeder resistors and power tubes. If the bias voltage doesn't come up at turn on, the relay stays open a ako neces puno da se patis imaju i one gotove plocice za automatski bias Auto Bias Modul for two Tubes (Single pcb to Control 2 Power Tubes) | eBay WWW.EBAY.CA Find many great new & used options and get the best deals for Auto Bias Modul for two Tubes (Single pcb to Control 2 Power Tubes) at the best online prices at eBay! Free shipping for many products!
  2. neskor
    300B pojačalo
    Bias Supply protection | diyAudio WWW.DIYAUDIO.COM OK so here is a question, The bias supply...if it fails the amp could be toast:eek: So how do we protect the Bias supply and still have a fail safe amp..:confused: One idea is to use a fail...
  3. neskor
    300B pojačalo
    Fixed Bias Protection WWW.DIY-AUDIO-GUIDE.COM Fixed bias protection prevents bias runaway that damages your power tube, speakers and output transformers.
  4. ja slusam ovo pojacalo sa sluskama koje su 600R i nemam zamerku na gain uopste, niti hod volume pota 6SN7 nema kond u paraleli sa otpornikom u katodi, tako da je pojacanje sigurno manje nego sto si naveo nisam nikad merio velicinu izlaznog signal u odnosu na uzlaz, moram probati
  5. jel neko mozda slusao one Chord male dakove sa FPGA chipovima?
  6. moja preporuka Darkvoice 336SE
  7. https://www.ebay.co.uk/itm/234521050825?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
  8. Just a moment... RA.CO New disc format combining CD and vinyl technology is 'pinnacle of recorded sound,' says founder T Bone Burnett
  9. Mislio sam na DL103R, mada ni klasicna DL103 nije uopste losa https://audiokarma.org/forums/index.php?threads/denon-dl-103-vs-dl-103r-what-are-the-sonic-differences.675420/
  10. uzmes Denon DL103R za 250 EUR i uzivas imho best buy za MC zvucnicu
  11. da li si siguran da taj album uopste postoji u SACD formatu, posto ja to nisam nigde video
  12. neskor
    Lepota dizajna
    da
  13. neskor
    Lepota dizajna
    ne znam da li je lepo, ali je zanimljivo
  14. prvenstveno da bih mogao da merim VT4C i ostale cevi koje rade na malo vecem naponu, takodje neg napon ide od -100V plus: Compared to the uTracer3 the PWM frequency has been reduced to 1.2 kHz. This makes the effective heater voltage virtually insensitive to parasitic wiring inductances, resulting in more accurate heater voltages
  15. https://www.dos4ever.com/uTracer3/uTracer3_pag12.html#FAQ_A4
  16. napravljena gornja ploca i ubacen uTracer u koferce stavio sam i opciju eksternog grejanja za merenje DHT cevi
  17. Ortofon AS212 ili Jelco 750
  18. ima Yamaha JA-4281b
  19. najbolje za prvo vreme neka gura softwerski, pa onda kasnije neka pravi hardware resenje
  20. da, odavno, jedino ako se nadje negde polovan po oglasima
  21. neskor
    Lepota dizajna
    koristio je Gallium Nitride-based transistor (vs. normal silicon style). vise informacija ima ovde: AGD Production Vivace GaNTube Monoblock Amplifiers - Positive Feedback POSITIVE-FEEDBACK.COM AGD Production Vivace GaNTube Monoblock Amplifiers review
  22. neskor
    Lepota dizajna
    D klasa u cevi od KT88
  • Trenutno na sajtu   1 član, 1 Skrivenih, 1096 Gosta (Pogledaj celu listu)
