neskor
Sve objavljeno od neskor
  1. https://www.minidsp.com/images/documents/Product Brief-nanoDIGI 2x8 Box.pdf
  2. Bio, pa se prebacio pre vise godina na Canon, za sada jos uvek sam na 5D MarkIII, a koliko slikam i mobilni telefon je i vise nego sto mi treba
  3. https://www.minidsp.com/products/streaming-hd-series/shd
  4. a i ovde imas brdo informacija kako da zamenis Kube i ima FR grafik sa Kube i bez njega The Official KEF R107 Owners Registry | Page 7 | Audiokarma Home Audio Stereo Discussion Forums AUDIOKARMA.ORG TERRIBLE. I've treated the hell out of it with owens corning 703 and roxul, panels all over but the bass traps in the corners can't tame the LF...
  5. ja sam na Canon-u Sacekaj, ti ces miniDSP da koristis samo kao EQ, tj. samo da dizes bas? Imam ja kuci miniDSP negde, pa ako hoces mozes ga pozajmiti i videti da li tebi to uopste treba
  6. ma previse posla u svakom slucaju, najbolje cekati da se Kube pojavi negde i to uzeti ili kupiti nove zvucnike
  7. Aya DAC sa Amanerom za USB
  8. ne zaboravi ako budes isao na aktivnu skretnicu moras da imas dva ampa, jedan koji ce gurati basove i drugi za ostatak i naravno na zvucniku moras razdvojiti bas i ostatak
  9. upravo tako, cela ta prica oko MinDSP-a ili neke druge aktivne skretnice ne vredi bez merenja i malo znanja plus onda treba napraviti u samoj kutiji izvode za bas i za ostatak sistema
  10. ovde mozes da procitas i post o samoj skretnici od AndrewJ koji je radio tada u KEF-u Crossover instead of Kube on KEF? | diyAudio WWW.DIYAUDIO.COM Hi. A crossover instead of the Kube? Hmm. I have a pair of KEF 107 - driven by the danish LA Audio mono tube amps. I am not quite happy with the Kube though, muds up the perspective and sound, so... Next, the KUBE itself. Yes, the system was designed with the KUBE as an integral part of the overall bass alignement. You will definitely get an odd bass response if you don't use it. Yes it is full of opamps, and I know that these don't measure up to modern types. If you are into doing so much modifications, the best route would be to convert the system to bi-amplification and then insert the KUBE only in the bass amplifier chain. This would avoid any of the concerns of the sound of the KUBE throughout the mid and treble at least. Unfortunately I don't have samples of these KUBES any longer, otherwise I would measure them and offer a suggestion of how to build a better version.
  11. Slazem se sa kolegom Nixiem, najbolje zadnja varijanta ili da cekas da naleti neki Kube 107 na oglasima. Evo ovde imas malo merenja i dosta informacija: AllegroSound * KEF R-107 R107 Loudspeakers * WWW.ALLEGROSOUND.COM audio sales service rentals tubes allegrosound A evo i seme za Kube 107 hfe_kef_kube_107_schematic_low_res.pdf
  12. imao sam ja dva Gausmetra, jedan od tih zavrsio kod Zeljka prilikom kupovine samo obratiti paznju na debljinu kraja sonde da bi mogla da udje u procep
  13. ehhh, kad bi imali ovu masinu za reacharge
  14. Faital 15PR400 moze do 5Khz, mislim da je ovo bilo raw merenje bez smoothinga, zaboravih davno bese
  15. konacno sam sebi ispunio zelju da imam i ovaj tube tracer, utracer6 juce citav dan lemio, crkao, ali bitno da je na kraju proradilo, ostaje samo da se ubaci u neku lepu kutiju
  16. neskor
    IT razno.
    pa kad je ebay odlucio da koristi payoneer umesto njega
  17. pozovi Trafco, oni su nekad to imali, koliko se secam
  18. moze, samo to nije bas jeftina sprava da se kupi kao donor za VU metre
  19. ja inace imam negde Teac MB20 koji sam koristio kada sam imao Studer magnetofon
  20. Dual Analog VU Meter 2-way Amplifier/Speaker Audio Switcher Box w/Remote Control WWW.EBAY.CO.UK VU3 VU meter & audio switcher box is originally designed by Douk Audio: As a VU meter, with dual 60*35mm large meter, can dynamically decorate audio environment and provide incomparably visual effects when switching audio signals. As an audio switcher, easily to switch between two amplifiers and 2 pair of speakers, no need to plug in and out cables repeatedly to...
  21. pitas Trafomatic da ti proda par
  • Trenutno na sajtu   0 članova, 1 Skrivenih, 1108 Gosta (Pogledaj celu listu)
