Pchelac
Sve objavljeno od Pchelac
  1. Ma, pusti cenu i modularnu koncepciju, ovo napajanje sa ovim ultra-kondenzatorima, koji glume bateriju, je ono što mi je bilo interesantno.(350 farads, or 350,000,000µF, each)
  2. http://www.stereophile.com/content/vinnie-rossi-lio-modular-integrated-amplifier#ZlFcLOcrPDU5CTZ2.97 Baš sam se pitao kada će neko početi da koristi te nove generacije kondenzatora... "This patent-pending Pure DC-4-Evr technology employs banks of high-tech ultracapacitors in place of conventional AC power or batteries. The ESR of the caps is approximately 0.002 ohm, so they can supply hundreds of amps instantaneously. You can arc-weld with them. They can also be charged extremely quickly. And yes, these are ultracaps of 350F (350 farads, or 350,000,000µF, each. Multiplied by nine but run in series for each of the LIO's (two separate) capacitor banks, the total capacitance divides by the number of caps used to net 33.89F per 24V bank. But yes, there are 6300F at 2.7V of total charge under the hood if they all were connected in parallel." While one bank of ultracaps is delivering pure DC to the LIO's audio circuits, the other bank is charging. The LIO's audio circuitry is never connected to the charging capacitor bank, and is therefore always 100% isolated from the AC mains and its sometimes devilish discontents. Meanwhile, all the control circuitry is powered directly and exclusively from the 24V charger—which also feeds a dedicated 5V regulator for all logic circuits in all of the modules (see later). Rossi says, "LIO owners do not need expensive power filters, power cords, or conditioners to achieve ultimate quiet and musical resolution." Read more at http://www.stereophile.com/content/vinnie-rossi-lio-modular-integrated-amplifier#wDK3Ch9IhDqwlCAW.99
  3. Kidding, ne kidding, to jeste to ... Mi'š da sam ženi prijavio Saba oval alnico 6x4cm od pre neki dan, a bili su samo 1500din par!? Reko' , kad ovaj ITT 10ka ovako lepo sviri,možda će mu ovo biti lep par... A za skretnicu ću morati da sačekam sledeći mesec...
  4. Impulse, care...!!!
  5. Svira fenomenalno, glasovi i muški i ženski zvuče odlično, a i drugačije nekako, kod BetsyK mi je ceo srednji opseg bio tiši i zvučna slika je bila povučena unazad, ono kao sve dopire negde iza zvučnika, sada je sve ispred... Tako nekako. Samo, ne gine im povelika kutija...
  6. Ili da stavljamo full u U-frame (kutija bez leđa), valjda bi mogao da siđe recimo do 200Hz... Cifre pominjem onako grubo, odokativno i nonšalantno, ali mislim da je to tu negde...
  7. Ova moja tqwt je 33x80x35cm . Imam i ja kod sebe par tih Tesli... Čekaju mog drugara da se smisli da pravi. A nije da one moraju da idu na široku ploču, to zavisi koliko nisko želiš da sviraju.Ako imaš dobar bas helper koji može lepo da svira do otprilike 800Hz,onda prepustiš njemu taj deo ,i verovatno Tesle onda mogu u ovalnu ploču koja je 2-3cm šira od samog drajvera, i Giurgevak ima takav ram oko drajvera. To je problem sa fulrange drajverima u OB konfiguraciji, najlepše izgleda zvuče na užim daskama , ali onda pokrivaju uži opseg - na uskoj dasci nema baš mnogo toga ispod 700Hz, ako onaj EDGE ne laže. Ostaje nam da koristimo full kao srednje-visokotonac...
  8. De blizu... ja sam tek počeo zezanciju, di su skretnice, pa isprobavanje oće li BetsyK u OB-a-la- giurgevak ili u neki plići U-frame, pa Damar, pa... ko zna šta još. Ja sam i počeo ovo ne toliko da bih dobio bolji bas ( i ovo do sada mi je bilo OK) , već da isprobam one priče da će moje magarence pokazati šta zna, u srednjim i visokim , tek kad ga se oslobodi basa. Videćemo, za sada sam oduševljen ovom 10kom i to najviše srednjim tonovima, vokali su fenomenalni, i ide dosta visoko, što kaže Branislav Iz Banovaca - samo ih posoli malo odozgo sa nekim visokotoncem i uživaj..._
  9. Isprobao sa potpuno zatvorenim otvorom , tj sa zapečaćenom kutijom - i "gle iznenađenja" - radi odlično. To mu dođe kompresija od 90 literi. Bas utegnut i gibak i nema sumnje da će lepo da sviri u odgovarajućoj, dobro napravljenoj kutiji. Isprobaću i sa manjim otvorom i sa reflexom druge dužine, ali ovo je već dobitna kombinacija.
  10. Tu je važniji deo -a valve friendly impedance...-
  11. Možda izgori lak...
  12. ovo bi bi bilo dobro ze proveru basa, ima li neđe besplatu kupovinu...?
  13. Preslušano... Sa vrljavom integralnom zv. karticom sa kompa, doduše, ali...: Srednji -dumreš! Prosto mi žao da ih režem ispod 1K. Bas... ima veću težinu nego sa BetsyK , ali je malo boomy,sa snimcima gde je naglašen bas. Opet ne previše, i prijatno za slušanje. Probaću i sa zatvorenom i smanjenom reflex-rupom. Calexico zvuči bolesno dobro...
  14. Ali, evo, slušam ih... Idu dosta visoko,mogu lepo da se slušaju i brez visokotonca. Utisci o basu (ako ikoga zanimaju) za koji dan.
  15. Eh. rešenje...Pre će biti čačkanje mečke
  16. Trenutno proširujem rupu na tqwt da primi 10"...(ovo zvuči malo... ) , wild try, ok, ali š'o i da ne probam. Ova tqwt je kutijetina od 90 i nešto literi, ugođena na 50Hz, neka sviri ovako par dana. Onda još jedan divljački potez - zatvorim rupu od bas reflexa na dnu, i dobijem... pa, zapečaćenu kutiju sa tunjelom unutra. Pa nek sviri tako još neki dan... Inače spremio sam materijal za novu kutiju, imam tonu lepe obostrano furnirane iverice, sa pravim furnirom, od svajinog regala...probaćemo.
  17. Da, da na ovo obavezno idu što deblji i šareniji kablovi...
  18. E, ovi konektori na ovakvom kućištu u upišavanje!
  19. Pchelac
    Wild Burro Onken
    Pih, 3-4 Hz dole...Mada, možda to i nije isto kod svih drajvera.
  20. http://www.audiophonics.fr/en/appareils-hifi-amplificateurs/audiophonics-bt60w-amplifier-tpa3110-bluetooth-40-hi-fi-2x-30w-p-9926.html Viđu ampa ! Mrga od 10x10cm...
  21. Pa Skrstic ima verziju sa 2x 6N3 i nekom lampičicom ispravljačicom... Razlika je drastična, čula se čak i na FAKu prošle godine, u katastrofalim uslovima za slušanje...
