Pchelac
Sve objavljeno od Pchelac
  1. Ma, zekim se, mislim... nekome ko se loži na uradi -sam bi ovo trebalo da izgleda primamljivo - tip je naredjao 12 (!) dacova u paralelu...
  2. http://www.dddac.com/dddac1794.html Evo, ovde su sve informacije, to je TI dac, čini mi se top of the line, i ovaj lik je uspeo da go potera u NonOversampling modu, i kao NOS dac bolje radi ako se više čipova potera u paralelni rad (valjda sam to dobro shvatio)... Pa zato grade ove soliterčiće. Uspešna implementacija je Metrum Octave i Hex dacovi (mada sa navodno drugim nekim dac-čipom, tajna, neki industrijski čip). Rad u paraleli valjda kompenzuje to što nema oversamplinga, a zadržava prirodniji zvuk NOS daca... http://www.6moons.com/audioreviews/metrum2/2.html
  3. https://tapatalk.com/tapatalk_image.php?img=aHR0cDovL2ltZy50YXBhdGFsay5jb20vZC8xNC8wNy8xNi9vcmlnaW5hbC91cGE4ZTNlZC5qcGc%3D http://www.diyaudio.com/forums/digital-line-level/224108-nos-192-24-dac-pcm1794-waveio-usb-input-228.html Meni je ovo prelepoooo...!Viđu DACa !
  4. ''The sound of a D.M.L.'' Having owned the following : Gale chrome and black dynamic loudspeakers, Kef Concertos, Polk Audio units, Celef loudspeakers, Maneplanar 2.3's, Magneplanar Tympani 1's, B&W hybrid electrostatics, huge Altec bass horns with Le Cleach 24 inch diameter mid/high horns run with 4 inch Selenium compression drivers, ..........I think that I have sampled a reasonable range of loudspeakers in my time? So, what is the sound of a D.M.L.?.............most of you who have been following this massive thread will already have a good idea. A ''Distributed Mode Loudspeaker'' for a start, sounds better than all the above...........bold statement?..........maybe, ...........but I have discovered that D.M.L.'s have a sound that none of the above can fully match. Amongst those is one VERY important factor that I will leave and highlight as the last in my list . Here we go: 1. FULL RANGE CROSSOVERLESS SOUND 2. INCREDIBLY FAST TRANSIENT RESPONSE 3. INCREDIBLY FAST AND TIGHT DRUM REPRODUCTION 4. OMINIDIRECTIONAL CHARACTERISTICS WITHOUT ''SIX FOOT WIDE MOUTHS OR PIANO KEYS''!!! 5. LARGE PANELS CAN PRODUCE STUNNING LOWS 6. TREATED CORRUGATED CARDBOARD PRODUCES VERY NATURAL HIGHS AND MIDS - NO METALLIC ''TIZZ'','' FIZZ'' OR ''SPLASH'' 7. NO DEAD SPOT WHEN STANDING DIRECTLY BETWEEN PANELS 8. EXTREMELY WIDE SOUND STAGE WITHOUT LASER BEAM SWEET SPOTS 9. PANELS DISSAPEAR AND YOU FORGET YOU ARE LISTENING TO LOUDSPEAKERS. 10.D.M.L.'s ARE CAPABLE OF REPRODUCING ONE OF THE MOST REALISTIC SOUNDS OF A SYMPHONY ORCHESTRA, A JAZZ BAND OR A SOLO GUITARIST THAT IS TRULY SCARY AT TIMES!............I HAVE STILL NOT GOTTEN USED TO THIS PHENOMENON. http://www.audiocircle.com/index.php?topic=70541.0 http://www.tectonicaudiolabs.com/ Evo šta ima da kaže Panomaniac, član audiocircle i diyaudio.com (relativno poznat) - bio , čuo, dopalo mu se -jako--- http://www.parts-express.com/pedocs/buyer-guides/Tech_Note_Understanding_Exciters.pdf http://www.parts-express.com/brand/dayton-audio/301?N=4294967060+4294967118+4294962940&Nrs=collection%28%29%2Frecord%5Bendeca%3Amatches%28.%2C%22P_PortalID%22%2C%221%22%29+and+endeca%3Amatches%28.%2C%22P_Searchable%22%2C%221%22%29%5D&PortalID=1&brandSelected=t&showMoreIds=10025 Na sreću, ovi exciteri nisu skupi, i daju dobre rezultate već sa izlakiranim kartonom... Probaću ja to (kad-tad) sa punom tankom smrekom ili kedrom (gornja ploča za akustičnu gitaru, 4mm,50x50cm, oko 50 eura, ... http://www.diyaudio.rs/uploads/monthly_05_2014/post-46-0-12707700-1400930028.jpg
  5. 1. anubisgrau, ne spava 2. neskor 3. davor, ne spava, plaća 4. El Abejo (Pchelac), valjda dolazi, ne spava,..(mali update) 5. ManicP, plaćam, ako ima mesta spavam (daklem, prednos kolegioni izdaleka). 6. ZM , ne spava (tu), sve placa 7. добривоје, ne spava (tu), placa 8. ninja, spava, sve placa i ako odustane od spavanja 9. bb 10. lukaluka, spava, plaća 11. papadj, spava, plaća 12. gaggia, ne spava, plaća 13. zflazar, ne spava, plaća, jede i peca 14. Eci , ne spava, plaća 15. stein, spavanje neizvesno, poveo bih prijatelja, spreman da uskočim za troškove... 16. ZZZ 17. CarAca, pije i jede za dvojicu, uredno plaća, a spava kući, ako ga žena ne otera 18. zeljkor, ne znamo status
  6. Leeleee...! U redu je, ne mora ništa više da se donosi, dosta i ovolikooo... Ooosim,...ako grau ne donese Sume. To bi bio pičvajz!
  7. -Probao direkno na pretpojačalo- !?... Koji si ti loodak
  8. Još ne znam dal ću stići da se vratim, imam neodložan put za Kruševac...
  9. E, sad neće biti dovoljno mesta za spavanje!
  10. Super da imamo info da je neko i isprobao!
  11. Ovo bi mogla da bude jeftina alternativa mnogo skupljim trafoima (Lundhal npr), kao izlaz za DAC... Po ovoj ceni nije strašno ni da se proba... http://www.thomann.de/gb/monacor_ltr110.htm
  12. Ja ću doneti šolje, ako rešim neke probleme do tada, jbg i meni se nešto komplikuje...
  13. U zdravlju da trošiš lampe! Jesi li isprobao bsc filter na Fostexima?
  14. E,hebiga, fak!...Kako smo krenuli...
  15. Kako da pretvorite svoju sobu u Cameru Obscuru, efekat projektovanja svetlog exterijera u zamračenu sobu, kroz rupicu... http://www.houzz.com/ideabooks/27629732?utm_source=Houzz&utm_campaign=u528&utm_medium=email&utm_content=gallery0
  16. Kako šljaka sa win7, jel ga prepoznaje pc?
  17. Fala bogu, dosadilo već da zekimo Stein-a zbog kojekakvih Steinaudio,Steinhifi itd firmi belosveckih...
  18. http://daudio.nl/en/producten/ možda i nije neka lepota, ali je egzotično... i, ima li naš daudio veze sa ovim, he he
  19. Najbolje izvođenje ove pesme...
  20. Realno, džabe... Meni je sada sve preskupo, inače bi poleteo kao muva na ...ovaj, ...med!
  21. Ja imam loše iskustvo sa Samsungom UE32F5000, elem, crko mu ekran posle 6 meseci! Štaviše u servisu su mi rekli da ih ima puno , tih 32ki , izgleda da je cela serija problematična. Obaška što će me se žena odreći preko novina jer sam izgubio garanciju....-pchelac krelac...
  22. Oooo, krećemo dalje, čestitke!
  23. http://www.aliexpress.com/item/Tube-6N3-Buffer-Audio-Preamplifier-Pre-AMP-Kit-For-DIY/629079677.html ovo je džabaka i moglo bi da se proba za 20 $ http://www.ebay.com/itm/Tube-6N3-Buffer-Audio-Preamplifier-kit-Pre-AMP-AMP-kit-DIY-/130814272291?pt=US_Amplifier_Parts_Components&hash=item1e75236323
