sp300b
Sve objavljeno od sp300b
  1. sp300b
    F5
    Bravo za F5 !Uživaćeš dugo u njemu, a ko jednom proba A klasu pojačala, ne traži dalje Što se offseta tiče...normalno je 0Vna izlazu, i to se verovatno da podesiti trimerom na 60mV, pa kad se zagreje da podne na 0V. Ako se dobro sećam. Stein se kuno da ima nulu na F5 bez problemaPusti Zena, kod njega je uvek sve OK :sarcastic_hand:Daj slike, pa da pričamo dalje.
  2. sp300b
    GK 71 tube amp
    Peca P8K Audio pravi trafoe samo tako. Moj 300b je kod njega napravljen i za trafoe nemam ništa drugo do reči hvale. Na ulaz Kockica, na izlazu Kockica (mislim na test 1kHz na osciloskupu).Dakle, topla preporuka.
  3. Here LED comesDegeneration Question is about what would be the best solution to have in circuit - 0,5 Ohms or lower
  4. Zen, a question.Papa seems to made J2 with 1,4A current and output resistors as parallel of 0,47Ohms. Here we have slightly different approach. Personally, I don't think that running SemiSouths on 2A will make any problem, but on contrary, but Source Degeneration resistors could probably be good to be tested with some other values like 0,22 or 0,33 Ohms?Your Serve (Djokovic)
  5. Nelson P. is not using protection circuit in any of his amplifiers, and seems it's not needed.My Babel was playing for more than 2 years, connected to FR Sonido SFR144. Never had any problem - Offset was set at the very beginning of the game, and never reset again.J2 is the same structure, so set J2 after 30min working without speaker (+In, -In and Gnd together) and You've done. Conect whatever You want then.
  6. Ispadao mi je instalacioni prekidač , a ne osigurač
  7. Uvalio ti neuparene
  8. Važi - pozdrav i lepo
  9. Mirno ću da spavam kad mu dodam još 2 NTC (od 5 Ohma) u seriju
  10. Nije, ne pada više :character13:p.s. Daudio je izmerio jedan sličan regulacioni trafo kad smo diskutovali, čisto da budemo sigurni da li je taj opseg otpora namotaja OK i dobio je vrednost takodje oko 1 Ohma....čisto da se zna.
  11. Pa nije se puno promenio...u tom je opsegu,Tačnije to je ' 1,2 Ohma. Bilo mi čudno, ali tako je.Grafit iako je napravio spoj, teško sam mogao da primetim merenjem kad je sve to jako malo...
  12. Ovde je problem u Ulaznom naponu, odnosno velikoj ulaznoj struji prilikom uključenja. NTC je opšte prihvaćeno a jednostavno rešenje.
  13. Zaboravih da napomenem...Kad me mučio, merio sam otpor namotaja na ulaznoj strani (po slobodnoj proceni, debljina žice kojom se namotava je oko 2-3mm) iznosi oko 1,2 Ohma. Kad se to priključi na 220V...To mora da dobru struju povuče u startu.:tegovi:edit: pa nema, ali mirnije ću spavati
  14. Misliš da mu ne treba, ali ono uopšte ??????????
  15. Malo je gabaritno da se ubaci u Reg. trafo.Mislim da je malo povećanje samih NTC otpornika elegantno rešenje, na osnovu kalkulatora
  16. :good2:I ja to mislim, i lepo smo ga oprali, ali..kad smo već tu, razmišljamo dalje na zadatu temu....Od sad ćemo ga čistiti alkoholom redovno , a u medjuvremenu, nije zgoreg i malo mu pomoći da lakše startuje. Razmišljao sam da svakako treba da mu ograničim Inrush struju na ispod 16A, da mi ne bi (slučajno) padao osigurač, a opet voleo bih elegantno rešenje koje se može spakovati u unutrašnjost 220V utičnice na slici na koju se priključuje potrošač.
  17. Zapazi ovaj Calculatorhttp://www.ametherm.com/inrush-current/selecting-an-inrush-current-limiter.html
  18. Misliš na ovo samo umesto R, NTC ?http://mitglied.multimania.de/Promitheus/delay_circuit_for_toroids.htm
  19. Mislim da treba da se malo razmisliti na temu soft starta ili nekom drugom vidu Inrush Current limitera (nisam siguran da je 2 X NTC od 5 Ohma u serijju najoptimalnije rešenje) 1) http://www.trafco.rs/softstart.php 2) http://www.ametherm.com/inrush-current/inrush-current-limiters-pcim.html
  20. Da podelim iskustvo od pre neki dan. Može biti da će nekome koristiti.Naime, posedujem regulacioni transformator Iskra 13A i dešavalo mi se u poslednje vreme da prilikom njegovog uključenja na mrežu (220V) padne osigurač (16A automatski) u kućnoj razvodnoj tabli.. I tako ponekad i 5-10 puta moram da podižem osigurač dok transformator ne počne normalno da radi i da ne obara osigurač. Pretpostavio sam da je to zbog velike struje magnetisanja jezgra, ali ipak trebalo bi da ne obara osigurač....bar ranije to nije radio...Onda malo razmislim, posavetujem se i odradim sledeće:1) Otvorim, obrišem alkoholom (Daudio savet ), da skinem grafitnu prašinu koja se po svemu sudeći nakupila izmedju namotaja i smanjila otpor namotaja regulacionog trafoa (prilikom priključenja na mrežu).2) Stavim u seriju 2 NTC otpornika od 5 Ohma i to radi sada :character13:Verujem da je 1) bilo pravo rešenje, ali ako me ne bude mrzelo, skinuću 2) pa ću probati da bih bio siguranEto, možda nekome pomogne.
  21. Don't bother me with a questions. Let me enjoy !:sporty095_2:p.s. It's great, and better and better....Cooking on the heat ....actually burning....
  22. Ongoing....
  • Trenutno na sajtu   2 članova, 1 Skrivenih, 189 Gosta (Pogledaj celu listu)
    453.5k
