sp300b
Sve objavljeno od sp300b
  1. Daj i drugu, leba ti - Ovo je iskustvo - ne uči se na fakultetu
  2. Excellent !This will be real-time comparison.Eager to hear about the differences between 0,25/0,25/0,25 and 0,25/0,47/0,25:cheers:
  3. OK. Easy - take your time.
  4. Zahvaljujem - na prvi pogled deluje jako zanimljivo i veoma komplikovano za nabaviti sve potrebne delove.
  5. Very good. Any impression about the sound after this change?Thanks in advance
  6. I would try 300 Ohm instead of 220 Ohm on R35
  7. Play twist with (try to adjust offset with him) R25 - Could You make offset 0V ?
  8. Tea disappeared - we confuse him completely
  9. @ Zen - Now I'm confused... what Tea has to do:1) To increase only R352) To increase only R263) To increase bothWhich one is correct ?
  10. Hi Tea - Check posts 801, 802, 803.I think You have to increase R35 to 300 Ohm approximately and try then what is going on.Once You will be able to set offset with R12, R25 properly, CNY 17 will be OK.Reminder hereR28 could go down, but I think it will be not necessary if You change R35 (increase).Please, try and report.
  11. Not really sure. From the picture, clearly, there are 3 x 2 Power resistors. Who knows how those 0,47 Ohms are connected - parallel or serial ?1,4A could be a sweet point, but generally for class A mosfet bigger is better. Papa Heatsinks on J2 are not capable to provide more than 80 W dissipation per channel. I think that's why he is using 1,4A.Probably will try the same setup with lower bias, but I have to play with resistors in order to put them back in order to be able to set lower bias.From Your experience, seems 1,4 A and 0,25 Ohms are also very good. I could try 3 x 0,33 Ohms...with 1,4 A....Uhhh,,,,game seems not to be over....
  12. Ears remained the same :sarcastic_hand:Sound wise, seems to me that middle range is more opened and it is more proper balanced in comparison with bass and highs, as I think this is how it should be. Sound stage is more robust and low frequencies are more "easy driven" now. All in all, I think this is what You experienced writting down about Your 0,25 Ohm changes.I don't have 0,25 Ohms to try...but should be somewhere around this. And as ZM explained - in order to have proper tracking CNY 17 must have over 1,2 V on his input....
  13. Ja ruski učio nisam (a ne bi bilo loše da jesam), a engleski...ajd da kažem da sam redovno koristio. Dakle komša i ja smo kao Komplementaran Par - jedan vuče na jednu stranu, drugi na drugu
  14. Game Over ! :sporty095_2:R29 = 0,33 OhmR30 = 0,66 OhmR31 = 0,33 OhmVoltage over R30 = 1,20 V ==> I bias = 1,8 A => Offset deadly stable Sound....as expected to be.Gorgeous everything.:beach:Bolje, zdravlje !p.s. ZM - MOX not needed now.
  15. R29 = 0,165 OhmR30 = 0,66 OhmR31 = 0,33 OhmListening to above configuration I think that the things changed in the wrong direction.Bottom frequency part are seems to me less impressive now, and on other hands offset seems to be more unstable now.My Conclusion - Go back and setR29 = 0,33 OhmR30 = 0,66 OhmR31 = 0,33 OhmThis way most probably, CNY-17 Tracking will do better, Both SS will work with equal Source resistors (means whatever is happening good/bad it will happen in the same manner on both of them), and at the end previously tested combination ofR29 = 0,33 OhmR30 = 0,5 OhmR31 = 0,33 Ohm already sounded the best among the tested combination. OK, I have replaced all the resistors with this last change, but I don't think the resistors type made difference itselfAgree with ZM, most probably it's only a matter of taste (pardon, ears)
  16. sp300b
    Audio CD
    Imam bolju ideju. Postavite me za moderatora.Onda ukinem sve moderatore.Onda Banujem koga hoću i kad hoću:buehehe:
  17. Hi AR2, Sorry. It's counting 3W resistors values starting from Plus Vcc to Minus Vcc. There are 3 of them.Upper - Connected to Source of JFet conected to Plus Vcc = R29Lower - Connected to Drain of second JFet = R30Bottom - connected to source of second JFet = R31
  18. Edited Your edit :sarcastic_hand:Each Gypsy praises his horse
  19. Homework for tomorrow: why-use-the-kimmel-mu-stage Good night.
  20. sp300b
    Audio CD
  21. sp300b
    Audio CD
    Što više pratim ovu temu, sve više mi se više javlja da će neko da prodje kao Vule....
  22. sp300b
    Audio CD
    Simfonija - ako ovo nije, onda ni ja ne dosežem, al sumnjam da ne dosežem
  23. All Power resistors replaced with 0,33 (made in USA - 1 % - black ) in the following mannerUpper - 0,165 OhmsLower - 0,68 OhmsBottom - 0,33 Ohms.Too late to listen music right now.Will report tomorrow about (if any) change,So far, only noticable change is a "" during Power On on right channel (that's little strange ...bias and offset checked before without and with test loudspeaker and offset is steady on around + - 10 mV).Music tested and it's playing on both channels.5 points for generg for reporting test results today - 3 points to ZM not telling us about this game (change the resistors)
  24. So, I was playing a bit more for Today..So upper R is 0,33 Ohms, Lower is 0,5 Ohms and bottom one (connected to Sourse of bottom Jfet) is 0,33 Ohm.Sound improved in the right direction, too. Maybe a bit less than the previous noticable change.I measured Voltage over the Totem resistors and it is 1,77 V which means bias is set to 2,1 Amp.1,77V seems enough for CNY-17 functioning well.All in all,. seems that winning combination is to be:Upper R - 0,235 OhmLower R - 0,5 OhmBottom R - 0,235 Ohmor...Upper R - 0,165 Ohm ( 2 x 0,33 in parallel)Lower R - 0,68 Ohm or 0,5 OhmsBottom R - 0,165 Ohm Still this is to be checked, but definitely not tonight.
  25. generg, did You changed also a resistor over the bottom JFet Sourse (R37/R31) ?
    454.9k
    DusanJovanovic
    DusanJovanovic
