Beli_Ninja
Sve objavljeno od Beli_Ninja
  1. Verovatno ima Sparcos unutra
  2. Meni se strašno svidela kombinacija elektrolit Elna Silmic 2 || MKC 1uF, ali to je za manje napone. Wima za MKC i FLC kaže: The special feature of Polycarbonate (PC) capacitors is the almost constant course of capacitance drift versus temperature and the suitability for special applications in the field of higher frequencies respectively. http://wima.cn/EN/polycarbonate.htm
  3. To su MKT i nisu savremeni Orange drop ali zvuče prijatno. To jeste BC, MKT368. MKT368.pdf Savremeni Orange drop koje koriste u gitarskim pojačalima i gitarama pravi CDE/Sprague i ima da se kupe u Banzai Music, Mouser itd. i imaju finu cenu. Takav sam stavio u lampaša i paralelno ruski silver mica (onako, napamet ) i ništa nisam primetio da fali. Imate datasheets u gornjem postu za njih.
  4. @BANAT Moderne Orange Drop proizvodi CDE ( Sprague). Izgleda da je poliester potisnut 😁 Tipovi 715 i 716 nisu MKP (metalizirani film) već FKP (metalna folija). Film capacitor - Wikipedia EN.M.WIKIPEDIA.ORG 716 ima bakarne izvode.
  5. @BANAT Moraću da te ispravim Type 715P, Orange Drop®, Polypropylene Film/Foil Capacitors https://www.cde.com/resources/catalogs/715p.pdf Type 716P, Orange Drop®, Polypropylene Film/Foil Capacitors https://eu.mouser.com/datasheet/2/88/CDUB_S_A0009901649_1-2540179.pdf Što je pandan Wima FKP2 FKP 2 - WIMA - Competence in Capacitors WWW.WIMA.DE WIMA FKP 2 Polypropylene (PP) Film and Foil Capacitors for Pulse Applications. Capacitances from 33 pF to 0.033 µF. Rated Voltages from 63 VDC to 1000 VDC. PCM 5 mm. PDF-File A sve to su vrhunski i po izobličenjima kvalitetniji od MKP i MKT. Bolji su Stirofleks. Za MKC i Silver MIca ne ynam gde su na listi po izobličenjima.
  6. https://www.kupujemprodajem.com/elektronika-i-komponente/kondenzatori/polipropilenski-kondenzatori/oglas/5456388 Toma
  7. Ja u lampaško pojačalo ubacio Orange Drop 716P i pralalno stavio ruski silver mica SGM neki
  8. Beli_Ninja
    JC-80, UGS
    @zocky Koji je to reg, šema neka?
  9. Zavisi, meni su ovi taman koliko treba na prednjem panelu. Msm, nisam ja gadljiv ni na McIntosh pristup
  10. Malo sam se akao sa ploterima u životu, samo za tehničke crteže uglavnom. Ali mi je zanimljiva ta metoda štampe na alu-lim
  11. Ovo je crtano u AutoCADu tada pre 100 godina dok sam bio zapošljeni studenat Štampano na glatkom samolepljivom papiru na laserakom štampaču. Šta se imalo to se koristilo.
  12. A može i ovako DIY, ovo sam odavno pravio. Logaritamska skala, poludeo sam dok sam je nacrtao
  13. Ne bih da vam kvarim zabavu ali to što vi tražite treba da izgleda ovako Ovi lepotani idu na jedan projekat koji će da razbije monitoniju prednjih ploča celog sistema
  14. Kao i svemu ostalom 😡
  15. Sastavio probnu varijantu da bih ukapirao gabarite i nastavio uklapanje. Aauu, tek sad shvatam koliko je čudo
  16. Veoma dugih 18 minuta
  17. Na ti kad si zapeo, a ti sad spavaj mirno
  18. Samwha mi curela i imala ispod 180uF, 220uF 450V, kupljena kod tv servisera koji je nabavlja u Svilajencu....
  19. Misliš da su original?
  20. @Stale Ne odgovara mi ništa što iziskuje cimanje sa carinicima i drugim zajebanim ljudima poput njih
  21. Kako odgovoriti a preživeti
  22. Verujem da je ovo jedina slika na svetu džigerice Mundorfa
  23. UbiVa na mrtvo
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 146 Gosta (Pogledaj celu listu)
    453.5k
