Magura
Sve objavljeno od Magura
  1. Something tells me, that they will keep warm on their own. The foam sheets are in need of visiting the oven, to get into shape Magura
  2. Well, I hope to connect mine in a different configuration, within the next few days Magura
  3. Hey that's pretty cool ....and they're connected in the amp the same way as mine Now refresh my memory, they were like 2kVA?Magura
  4. It has happened before, but we decided to keep it a secret Magura
  5. Andrics,Still no mail from me in your inbox? Magura
  6. would 80g/m2 carbon be of use to you? I have found that for something like 30eur/m2.Did you get my email? Magura
  7. It kinda is secret by now, cause i can't remember what I copied. Magura
  8. No, I have simply copied a known design for the motor, and given it a bit more power. I made most of the parts for the motor yesterday, so in short time, I should be able to test.It's just like Christmas Magura
  9. I would think so too. What is it you have covered the face of your cones with? Aramid? Magura
  10. Magura
    Tranzistori?
    Matching the IRFXXXX N and P channels, is simply a no can do. Been there, done that, with no success, what so ever, even I had very many fet's to pick from.It is though correct that the 9140 and the 240 is your best bet.How many do you need? And for what? If you can convince me that your cause is noble, I may give you some IRF240 that I was given by Nelson Pass at BAF a couple of years ago Magura
  11. They claim it's suitable for FR drivers as well. Time will show if their claim hold true.Magura
  12. I would sure like a few sheets of 2mm thick ROHACELL® 51 for a test. And if possible a few small pieces of scrap for getting a feel for working with the material, as I'm new to this material. My cone is 150mm diameter. How much is 2mm sheet directly from the factory? CheersMagura
  13. Note the curvy options in eagle. It will make your layout look like a million.Magura
  14. Nice design, I feel like stealing a few ideas Have you made other drivers?I now have an ongoing correspondence with Nick at Clarisound about Rohacell. It sure could turn out to be interesting.Magura
  15. Hi Andrics,Thanks for the suggestion, I sure will try and see if I can get some of that material. To make a test should be quite easy, as the mold will actually work for thermo forming as well.Can I see the drivers you've made? Magura
  16. That's pretty much the plan for now. I may decide to use clean cloth for the spider later on, if not for other reasons, then just as an experiment.The cones could also be paper or Kevlar, as the mold is to be lined with film. For heating the molds, I'm simply going to mount an iron to each half, hence the thick block of aluminium for spreading the heat even.Magura
  17. Yes, that and then some.Magura
  18. Naah, it was 50$, not euro, and for matched JFET's.Not that it matters anymore, as that GB is closed now Magura
  19. WHAT???? Blasphemy! Magura
  20. Would you like PTFE board for a pair?Magura
  21. I could swear I've seen your name before :coffee:On a more serious note. What do you think about the outcome? I think that Serb board house is pretty good. Magura
  22. Not a bad idea We just might want some more boards like those sometime.Magura
  23. Yeah, maybe I should simply store half a m2 of PTFE board in Serbia. Not a bad idea Magura
  24. I should have sent you more of the raw PCB Magura
  25. They sure look real good. How is the through hole plating? Magura
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 257 Gosta (Pogledaj celu listu)
    453.9k
    DusanJovanovic
    DusanJovanovic
