aaa zmaju!
Sve objavljeno od aaa zmaju!
  1. Jel neko zna gde mogu da se kupe ovakve letvice za razvod?
  2. aaa zmaju!
    Woland
    Jedan za u dnevnu sobu, drugi u trpezariju
  3. Na ovome moze i kafa da se posluzi
  4. aaa zmaju!
    Nepoznati Zvucnik
    Ok, ok, samo sam naveo ako niste pogledali ponovo oglas
  5. aaa zmaju!
    Nepoznati Zvucnik
    Ne znam da li su bile slike i pre, ali u oglasu sad stoje slike sa skinutim drajverom gde se vide i oznake.
  6. Wolande odaberi neki od ovih slow-blow ako krenu da opominju
  7. Meni ta šema liči na ovaj filter: http://www.moxtone.com/MOX_MFS3.htm
  8. Ispade Zen u konstantnom DEFiSITu sa pojacalima, stalno mu neka stizu na kućnu adresu
  9. A kakva je to žička?
  10. Moze bit` nekom treba.
  11. Zaboravih linak: https://www.limundo.com/kupovina/Tehnika/Audio/Zvucnici/Veliki-Zvucnik-ISKRA-KRANJ-ez-605/60916329
  12. Mogli su da snime kako radi bar nesto.
  13. Ne zaboravi da metneš rukavice dok montiraš
  14. Ovih dana i 202 šušti
  15. Dobar ti taj oplet
  16. Pa jesi gledao na KP? Ima ovaj:http://www.kupujemprodajem.com/Leader-Wow-Flutter-Meter-LFM-39a-50682758-oglas.htm The LFM-39A Wow & Flutter Meter is a direct reading type instrument designed for measurement of Wow, Flutter and Drift characteristics of tape recorders, recordplayers and other playback/recording equipment. The effective values, peak-to-peak values and center frequency (3kHz or 3.15kHz) of Wow & Flutter are indicated on the meter in accordance with J1S, CC1R, DIN, and weighted specifications. Five full scale ranges, 0.03%, 0.1%, 0.3%, 1% and 3%, are used. The use of 0.03% range makes it possible to measure accurately the Wow & Flutter characteristics of high-grade tape recorders. The LFM-39A contains an oscillator with excellent frequency accuracy, which can be used to calibrate the drift meter and supply a recording signal. Moreover, this Wow &c Flutter meter is equipped with a TO SCOPE terminal for analyzing Wow & Flutter components and a RECORDER terminal for Wow & Flutter recording.
  17. Maa nesto mi mnogo... Pogledaj blog Zorana Karapandzica, ako vec nisi, mozda ti da neke smernice: http://zokiaudio.com/category/analog_recorders_players/?lang=sr
  18. Nisam dugo pratio oglase na KP, sad pogledah sta ima u ponudi... sta im je bre sa cenama, kad je to tako podivljalo????
  19. aaa zmaju!
    ZM
    ihh...
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 145 Gosta (Pogledaj celu listu)
    453.5k
