savan Napisano Septembar 12, 2021 #397 Napisano Septembar 12, 2021 Jedino od 12v da uzmem umesto 7.5v http://www.interhit.rs/100033-mini-15-va-ei-za-stampanu-plocu-hahn
Nesic Napisano Septembar 12, 2021 #398 Napisano Septembar 12, 2021 Uzmi u obzir koliko struje ti troši sve, pa možda knap prođeš i sa 7.5VAC shop.vremeplov.co.rs - pogledaj možda imaju 9V http://www.kelco.rs/katalog/komponente.php?q=1.9VA+9v&search= savan je reagovao/la na ovo 1
savan Napisano Septembar 12, 2021 #399 Napisano Septembar 12, 2021 (izmenjeno) Naruceno 2 komada http://www.interhit.rs/mini-19-va-ei-za-stampanu-plocu-hahn/17373-trh019-9-2000000182490.html Zamalo da narucim plocicu a zjb sam mesta, power dugme treba dole a ja sve kontra Izmenjeno Septembar 12, 2021 od savan
savan Napisano Septembar 12, 2021 #401 Napisano Septembar 12, 2021 (izmenjeno) Jlcpcb je zakon! Sad su nabavili ljubicastu boju, a poceli su da rade i na aluminijumu. Tri firme koje ja koristim: 1. Easyeda - za dizajn 2. Lcsc - za delove 3. Jlcpcb - za izradu Dali ima nesto bolje od ovoga, ne verujem. Izmenjeno Septembar 12, 2021 od savan
shonne Napisano Septembar 13, 2021 Autor #402 Napisano Septembar 13, 2021 Neke impresije kako svirala ova verzija sa BB...da se ima na umu da konverzija je isla preko HQplayer koja je najbolja moguca. Hi Nenad! After a few days testing DSC2 I have drawn some conclusions. This version with Barebone is much worse than the version of 2.5.2 that I had with Lundhal and a special amanero with 957 crystek, galvanic isolation, ldo regulators and separate power. That sound was very close to my philips TDA1541A dac (double crown chip and Abbas output stage) maybe 95%, DSC2 with Barebone gives 20% o less. I think even with Ivan's output stage won't be enough, I think RJ45 creates a lot of jitter. Best regards!
savan Napisano Septembar 13, 2021 #403 Napisano Septembar 13, 2021 (izmenjeno) Ne moze to da bude tako drasticno, tu je vise stvar toga da kada imas cristek, bolji amanero, sto kosta malo vise nego ono sto si imao pre toga, odmah ti se ucini da sve svira bolje a ustvari za koji dan ces da shvatis da nije neka razlika. Na prmer zvucnici, dva dana ces da uzivas u njima treci dan ti nesto fali na njima, to je sve stvar raspolozenja, vremena napolju, zdravlja... Troels je to lepo objasnio: I often have the quest for describing the difference in sound from two speakers. The thing is that describing sound just doesn't make sense. I might write a book on both speakers and still you wouldn't have a clue to how they actually sound. Potent bass is no bass to some people, smooth midrange may be harsh to others and some may find balanced treble is no treble. Adding percentages to sound is ludicrous. Is this speaker 90% of that speaker? It doesn't make sense. I know that magazines are filled with sound descriptions and still, you won't know what they sound like before you have heard it yourself. It's no different than describing the taste of wines: Subtle, Delicate, Elegant, Crisp, Thin, Finesse, Bright, Floral, notes of this, notes of that, etc. Rubbish! You won't know until you've tasted it yourself. Ja nisam mogao da verujem da klinac cuje 17-18k na ovom testu www.youtube.com/watch?v=h5l4Rt4Ol7M dok na primer ja cujem 15k, to je velika razlika Izmenjeno Septembar 13, 2021 od savan
shonne Napisano Septembar 13, 2021 Autor #404 Napisano Septembar 13, 2021 Cula se ta razlika izmedju Aya i Pure sa ovim setup-om... Tu tvrdnju i potvrdio spanac 🙂
savan Napisano Septembar 13, 2021 #405 Napisano Septembar 13, 2021 Stvar je u tome kada je nesto skuplje da bolje zvuci a zvuci isto, sve stvar psihe. Ne verujem u drasticnu razliku od 20% sto ovaj kaze to je nemoguce, ima mozda neka mizerna razlika. Jedes suve kolenice pa ti skoci pritisak u roku od sat-dva pa ti se ne svidja ono sto ti se svidjalo pre dva sata
shonne Napisano Septembar 13, 2021 Autor #406 Napisano Septembar 13, 2021 hahaha...suve kolenice. Pa nije bas tako. Dobro je da i on i ja imamo TDA1541A i mogli da uporedimo. jedino sta ja tu verziju 2.5.2 nisam cuo, ali verujem mu na rec. Ova moja verzija, je bila losa od tda...
savan Napisano Septembar 13, 2021 #407 Napisano Septembar 13, 2021 (izmenjeno) Ja cu da se drzim ovoga http://www.audiodesignguide.com/DSC2/Schematic1.jpg sa 2.5.2 pa cemo videti dalje dali neki dsp, fm radio, bluetooth, dali clasu D da ostavim na izlazu ili neku klasu AB . Imas kakav link za Ivanov output stage? Izmenjeno Septembar 13, 2021 od savan
shonne Napisano Septembar 13, 2021 Autor #408 Napisano Septembar 13, 2021 14 minutes ago, savan said: Ja cu da se drzim ovoga http://www.audiodesignguide.com/DSC2/Schematic1.jpg sa 2.5.2 pa cemo videti dalje dali neki dsp, fm radio, bluetooth, dali clasu D da ostavim na izlazu ili neku klasu AB . Imas kakav link za Ivanov output stage? Ta direktna konverzija preko chipa i konverzija sa HQ player zna da pravi razliku, imaj to na umu... Link, evo... https://www.diyaudio.com/forums/vendor-s-bazaar/327794-output-transformers-dacs.html savan je reagovao/la na ovo 1
savan Napisano Septembar 13, 2021 #409 Napisano Septembar 13, 2021 (izmenjeno) Probacu druge trafoe jednom prilikom kad bude viska para svakako! Imam ovaj fm radio chip to sam skoro narucio iz zezancije, isti je kao ovi sto se prodaju na kupujem prodajem stim sto je duplo veci i ima i2s izlaz https://www.lcsc.com/product-detail/RF-Transceiver-ICs_span-style-background-color-ff0-RDA-span-Microelectronics-RDA5807FP_C77689.html, ovo razmisljam da ugradim u ovo moje cudo, ne znam jel neko imao dodira sa ovim fm radiom, kako zvuci preko i2s? Izmenjeno Septembar 13, 2021 od savan
savan Napisano Septembar 14, 2021 #410 Napisano Septembar 14, 2021 Malo montaze na postolje sa nogicama https://ibb.co/sQcs2tc https://ibb.co/1LJBYZp
savan Napisano Septembar 18, 2021 #411 Napisano Septembar 18, 2021 Prednji panel ofarban https://ibb.co/HdLBCr0 https://ibb.co/9psr0rh
savan Napisano Septembar 18, 2021 #413 Napisano Septembar 18, 2021 (izmenjeno) Colormatic prajmer svetlo sivi, pa na to metalik siva, zapeceno pola sata. Stavio sam ovde materijal -> www.diyaudio.rs/topic/9706-pure-dsd/?do=findComment&comment=397167 Izmenjeno Septembar 18, 2021 od savan
Nesic Napisano Septembar 18, 2021 #414 Napisano Septembar 18, 2021 Ovako sa ne baš najboljih slika izgleda da je ispalo odlično
savan Napisano Septembar 18, 2021 #415 Napisano Septembar 18, 2021 Jako lepo uzivo, izgleda lepse nego eloks, bas onako kako ja volim da bude polu sjajna vise mat i kao fino fino peskirano kao od plastike da je
savan Napisano Septembar 18, 2021 #416 Napisano Septembar 18, 2021 (izmenjeno) Evo malo lepse slike mada ovde je sad uvelicano i izgleda krupniji pesak nego sto jeste i nije bas ta boja, mnogo lepse uzivo izgleda https://ibb.co/RQ085XM Izmenjeno Septembar 18, 2021 od savan krca44, vladd, Beli_Ninja and 1 član je reagovao/la na ovo 2 2
savan Napisano Septembar 18, 2021 #417 Napisano Septembar 18, 2021 (izmenjeno) Sta je dobro kod farbanja je kada ti dosadi siva ti kupis isto to sve samo crnu i prefarbas Ovo je lepse od eloksa ali eloks je jaci i postojaniji, ovo jeste cvrsta boja ali mora dobro da se pazi da se ne oguli kao i sve drugo mora bar jedno mesec dana da se pazi dok boja ne otvrdne kako treba. Ja bi postigao isto ovo eloksom ali nece to niko da radi, potrebno je finim peskom da se uradi priprema (sto niko ko radi eloksazu nema) pa onda da se eloksira i onda izgleda isto ovako, ali ovo zadovoljstvo bi kostalo puno vremena jer mora da se nosi kod nekog ko radi peskiranje (ne ono grubo sa jakom masinom nego specijanim pistoljem koji nece da obara ivice ) pa tek onda da se nosi na eloksazu, ja bas nemam zivaca da vijam ovamo onamo ovo mi je brze i jednostavnije a dobro Izmenjeno Septembar 18, 2021 od savan vladd je reagovao/la na ovo 1
