Ako nešto može da se iscedi iz donjeg texta, što bi bilo dovoljno za mišljenja o kvalitetu ove skalamerije (made in Swiss) tehničkim crtama, kao i nekim karakterističnim crtama u zvuku....?  Mislim da malko naginjem ka Mosfet karakteru zvuka. Pass XA mi je ponekad pre-analitičan...naravno, zavisi od ostatka sistema i muzičke produkcije...
POWERAMPLIFIER MIMETISM 45.2
2 x 180 Watts RMS at 8 ohms , 230 V - 2 x 360 Watts RMS at 4 ohms , 230 V 1'000 VA power supply - Inputs - 1 x unbalanced - 1 x balanced
From a purely technical standpoint, the challenge was to design a circuit that would be simple and yet uncompromising in terms of musicality and reliability. Using Surface Mounted with tight tolerance components associated with traditional ones at the most strategic places enabled to shorten the signal path length. The amplification uses the highly acclaimed Hitachi Lateral Mosfets 2SK1058 & 2SJ162 complementary power transistors, in a configuration of two pairs per channel.
The input section uses a cascode differential stage for the best performance. Both the pre-driver and the driver stages are based on High-Voltage Power Bipolar Transistors used in HF designs. The driver operates in pure class A. The circuit is fully direct-coupled but for a single ingress capacitor.
Each channel has its own power supply with a lefty 60,000 microfarads of filtration, achieved via high current diodes without switching peaks. A delayed start-up function linked to the D.C. protection circuit is built into each channel. The gigantic 1000 VA toroidal transformer has two separate windings for each channel. To avoid current saturation, a power resistor has been placed in the power supply. After a very short delay, this is coupled to a power relay that limits the current. The loudspeaker output terminals are fed by solid copper bars.
TECHNICAL DATA with AUDIO PRECISION analyser MIMETISM 45.2 AMPLIFIER Output power 180 Watts RMS at 8 ohm , 230 V Description 360 Watts RMS at 4 ohm , 230 V Power Amplifier Dual Mono Signal to noise 110 dB Power Supply 1'000 VA Input Unbalanced RCA Distortion at 8 ohm 0.005 % 80 Watts / 100 Hz Input Balanced XLR 0.005 % 80 Watts / 1000 Hz Speakers Bi-Wiring 0.010 % 80 Watts / 10 KHz Trigger In / Out Input impedance 47 Kohm Rise time 1.8 us / 10 KHz
  • Odgovora 29
pa , u textu izrecene sve prave stvari , ali nema necega sto bi moglo da iole informise kakav je karakter zvuka
ono sto se moze primetiti sa slike je da hladnjacici izgledaju pomaleni za deklarisanih 180W/8R a kamoli za 360W/4R, a bogumi dva para navedenih izlaznih mosfeta nisu garancija da to nece biti spepeljeno na prvoj ozbiljnoj zurci
veci hladnjaci, najmanje 4 para tranzistora po kanalu , i nemam onda nikakve zamerke
mozda konzervativno , ali to je moj stav
Vidi se iz opisa o čemu se radi klasična hitachi varijacija. Sve ok, s tim što je nelogično što ima samo po 1 par laterarnih mosfeta ako dobro vidim sa priložene slike.
Quote
Just now, Zen Mod said:
Pročitah ali na polčici vidim samo 1 par, ako nisam dibiduZ oćoraveo ?
e , ja na taj fakat uvek racunjam - i ja vidim samo jedan par , al znam da sam corav
Je, samo je jedan par na pcb definitivno. Sve što preko nekih 80W sinusa isporuči ovaj amp tera taj jedan izlazni par u danger zone.
Brate na pojačalu od 2x80W u A klasi možeš čvarke da topiš u loncu od 30 kila
Mogu da zamislim kolika je kutija 4x veča od moje kad j moja prevelika:smesna:
mani se A klase , lepo se vidi da je amp B klasa (ili AB kako neko zove )
zna se koliki je koeficijent korisnog dejstva takvog pojacivaca , iz cega je apsolutno jasno koliko pri nazivnoj snazi odlazi u toplotu
onda se iz toplote da skontati koliki hladnjak treba da ohladi traznsitore da se ne istope u roku od odmah
al dobro - ovaj amp sa slike po svoj prilici nece ni stici da istopi tranzistore , pre ce crci od struje po tranzistoru
4 tranzistora u izlazu. Sa ove se bolje vidi. Mada, zbijeni, uz grupisanu disipaciju, doticne brojke moguce u vrlo kratkom periodu.
Ima nova generacija hladnjaka. CarbAl
20% Aluminijum - 80%  kompozitni grafit - toplotna provodljivost je 425 W/mK
Možda su od toga :D
Eno ceo nov MAC je u CarbAl hladnjaku. :smesna:
Magura je napravio one svoje Big Donut ampove sa grafitnim elementima
nis' ga mog'o ugrijat' :Viannen_loungelizard:
Da, ovde se lepše vidi... Ok onda može kratko izbaciti, al da ne pričamo o snazi - miriše na neku varijaciju Crescenda (možda i preslikan šta ga znaš), a to je jako autoritativan amp. Precizan, moćan, sa vrlo malo šećera (taman kolko treba), nema muljanja, nema distorzije. Mnogo podcenjeno pojačalo.
Uz ovaj trafo i napajanje trebalo bi da je odlično pojačalce.
pa i nije bilo podcenjeno
bilo je ihaj toga ponapravljano po Jevropi , onomad kad je Elektor bio sila
mi smo taman u to vreme postajali sirotinja , pa nam se otelo
secam se jedne godine , kad su Ivas & Co. probavali da osvoje trziste Pro tehnike ovuda ( mali i veliki Dynaudio pasivni i aktivni monitori) , imali su u ponudi i pojacalo koje je bilo malo malkice umanjeni Elektorov Gigant ...... koji je opet bio puno uvecani Crescendo ..... sve to videh na Taktons-u
ne mogu da se setim kako nazvase firmu ...... al im se otelo, koliko se secam - ode trziste u propas......
Napisano (izmenjeno)
Hvala na komentarima.
Ideja je da koristim svoj Preamp NS10 Clone, i neki amp koji ima veći voltage swing, dovoljno i za niže efikasne zvučnike.
...ali za pogon područja iznad npr. 100-150 Hz. Za bass područje class D od barem 400W. Tako da bih imao 4 dB ili više sa istom pobudom iz preampa.
I naravno na class D active low pass filter i volume pot za udešavanje nivoa sa ostatkom. Tako da za kućni HiFi ovaj Amp ne bi trebalo da ima problema sa prevelikom strujom.
To je model od pre 10 godina, ali se jedan nov u kutiji i sa garancijom pojavio u ovdašnjoj HiFi radnji za 2kE. Bio nekada 5,5kE što verovatno ništa ne znači.
Ovde je recenzija za 15.2 integralac (isti amp). Može nešto da se nasluti o zvuku: http://stereotimes.com/amp101907.shtml
Izmenjeno od BokiTokiVoki
imam apex ax8 sa 2SK1058 & 2SJ162 u izlazu, ne znam da opisujem zvuk, ne znam teknikalije, meni je dobar, dobro radi, daje utisak da su ti fetsovi dosta sposobni, malo se greje bez obzira koliko ga zgaziš to je valjda osobina tia latfetova, pa verovatno i taj mimetizam amp se ne greje
Dovuci to Boki , će ga testiramo na žanjice :grino:
