Windows 10, Windows 7 i ostala WIN familija
shonne
9 racunar instaliram. sebi 4 sestri 2 - kumovima 2 - sad je jeb*e i komsija dosao sa kucistem.
na 2 racunara sam probao CLEAN installl ovo je permanentno aktivirano i guta svaki WIN 10 posle apgrejda.
 odnosno free je zaista
najslicnije mi je poredjenje sa androidom. jednom zapamti hardver i imas ga   vazda :buehehe:
Microsofts FAQ: http://www.microsoft.com/en-us/windows/windows-10-faq
1. Can I do a clean install:
Yes but you have to upgrade first then you can do a clean ISO install.
2. Is Windows 10 Build 10240 RTM?:
It doesn't matter. It will be updated to GA (and beyond) through windows update.
Yes just remember that RTM means release to manufacturer not release to market and also remember this is a new model WAAS=Windows as a service. Updates we are receiving since build 10240 will all be day 1 patch for the general public. (also note RTM and GA amounsgt others like Alpha, beta, RC1 and RC2 are outdated terms we need to stop using.)
3. What do all these different build numbers mean?
build 10240 is the release that will happen on July 29th. Insiders already got it. :buehehe:
Builds 10500 are in the TH2 branch and will be a future release.
i jos:
Once you have upgraded you do not need a product key, nor do you need a key when upgrading from a qualifying system (OS). Once you have upgraded at least once you are free to do clean installs, at some future point Microsoft will be providing ISO.
Ovo sam vec testirao na apgrejdovanoj masini. Samo skipujem kljuc kod Clean installacije. Cim se zakaci onlajn masina sa WIN 10 je aktivirana permanentno. probah 3 puta na jednoj i uvek je aktivirana . :guitarplayer:
8-10 Giga sistemski zauzima Win 10 - racunaj jedno 60 giga sa svim programima
stim sto na C:   postoji folder Windows.old
koji zauzima Win7 (cuva sistem) sa kojeg je apgrejdovano.. pa je zauzeto jedno 20GB
taj folder se moze obrisati kroz Disk Cleanup .
u principu sto je nakrcaniji Win7 to treba vise vremena za apgrejd.
fresh install W7 ultimate 32b ili 64b - svejedno , po pitanju upgrade na W10 ?
Ako imas 64bit  masinu a vecina masina jeste 64bitno (sem neke  starije)  savetujem  64BIT.
Ako je masina iz "naftalina" - jedno 6  godina stara onda 32bit :oke:
trenutno samo 1GB DDR3 RAM ......... ovo je ionako proba
  • RAM: 1 gigabyte (GB) for 32-bit or 2 GB for 64-bit
  • Hard disk space: 16 GB for 32-bit OS 20 GB for 64-bit OS
  • Graphics card: DirectX 9 or later with WDDM 1.0 driver
  • Display: 800x600
ovo je zvanicni minimum za WIN 10.
no instalirah i na masini komsije  i na 2GB DDR2
on sav srecan. no meni je presporo u odnosu da  imam vise rama od toga  i u telefonu  :buehehe:
Bas me kopka kako ce se odraziti na zvuk,  oklevam da li da i na kompu koji je samo za muziku  predjem na 10 :L3000:
Stigoste li malo da ga oslusnete?
Realtek ALC codek radi automatski . ne treba nikakav drajver - sam ga instalira. jaako  dobro svira :Laie_58:
Kakav je cener za mjuzu?
Ovakav:
:thumbup:  :guitarplayer:  :unbelieveble:  :L3000:  :guitarplay3:  :disco:
Još jučer mi se svidio. Ne znam razlike u odnosu na Win7. Možda malo manje tvrd u sredini manje "skršššš" gore. (onomatopeja u nedostatku riječi)
Tako da sam išao malo googlati što kažu ostali. Neki ga uspoređuju sa W server 2012. Ne mislim da je razlika dan i noć niti sam siguran da bih u blind testu bezgrešno detektirao kad svira na W7, a kad na W10, ali sam definitivno zadovoljan.
Malo sam procunjao i našao sam da više nema windows experience index merač... (ono sa ocenama do 7.9 pa ti kobajagi testira hardver )
Ostalo... pa recimo da ću se navići jer za sada sve izgleda kao da radi...
Zaboravih napisati onima koje zanima: JRiver radi sa desetkom, a radi i ESI [email protected]
Poslao sam neki dan mail  ESI sa pitanjem za drivere za desetku i rekli su da su u pripremi. Znači radi i sa posljednjom verzijom drivera za W7, a novi driveri dolaze uskoro.
