Windows 10, Windows 7 i ostala WIN familija
skidam en_windows_7_ultimate_with_sp1_x64_dvd_u_677332.iso :D
Jel su tu ubačene sve one zakrpe, 170-ak ih beše?
U pitanju je Windows 7 With SP1 Media Refresh Ultimate x64 English, mada sumnjam da su sve zakrpe unutra.
http://share-links.biz/_zz9kurnqdxker
3,09 GB (3.320.903.680 bytes)
CRC32: 992B8FCD
MD5: C9F7ECB768ACB82DAACF5030E14B271E
SHA-1: 36AE90DEFBAD9D9539E649B193AE573B77A71C83
mada se i kroz win10 vide repovi koji se vuku od sedmice, kroz okruženje. a i prvi prozor koji te dočeka za clean install je u win7 maniru. mogli su barem to da promene
Miko, kako se uključuje ta aplikacija?
najbitnije je da znam kako se iskljucuje - a ljudi panice zbog privatnosti jer uglavom  ne koriste mozak, vec splovilo  :buehehe:
 Disable-Telemetry.cmd:
@echo off
title Disable/Enable Windows Telemetry
color 1f
:Begin UAC check and Auto-Elevate Permissions
REM  --> Check for permissions
>nul 2>&1 "%SYSTEMROOT%\system32\cacls.exe" "%SYSTEMROOT%\system32\config\system"
REM --> If error flag set, we do not have admin.
if '%errorlevel%' NEQ '0' (
echo:
echo   Requesting Administrative Privileges...
echo   Press YES in UAC Prompt to Continue
echo:
    goto UACPrompt
) else ( goto gotAdmin )
:UACPrompt
    echo Set UAC = CreateObject^("Shell.Application"^) > "%temp%\getadmin.vbs"
    echo UAC.ShellExecute "%~s0", "", "", "runas", 1 >> "%temp%\getadmin.vbs"
    exit /B
:gotAdmin
    if exist "%temp%\getadmin.vbs" ( del "%temp%\getadmin.vbs" )
    pushd "%CD%"
    CD /D "%~dp0"
:Check the key:
(reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v "AllowTelemetry"|find /i "0x0")>NUL 2>NUL
if %errorlevel% NEQ 0 GOTO :KEYOFF
:KEYON
echo ============================================================
echo Windows Telemetry currently disabled.
echo Would you like to re-enable it? (Y/N)
echo.
choice /c yn /n
If %ERRORLEVEL% NEQ 1 GOTO :QUIT
Echo Deleting Telemetry Registry key
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v "AllowTelemetry" /F>NUL 2>NUL
IF %ERRORLEVEL% NEQ 0 GOTO :ERROR
Echo.
Echo Windows Telemetry enabled
Echo.
goto :QUIT
:KEYOFF
echo Windows Telemetry is currently enabled.
echo Would you like to disable it? (Y/N)
echo.
choice /c yn /n
Echo Changing Registry key
reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v "AllowTelemetry">NUL 2>NUL
if %errorlevel% equ 1 REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v "AllowTelemetry" /F>NUL 2>NUL
REG ADD "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v "AllowTelemetry" /D 0 /T REG_DWORD /F>NUL 2>NUL
Echo.
Echo Windows Telemetry disabled
Echo.
goto :QUIT
:QUIT
echo Press any key to exit...
pause>NUL
goto :EOF
:ERROR
echo The script ran into an unexpected error setting reg key.
pause>NUL
goto :EOF
Ništa ne kužim ovo što si uokvirio.
Tutorijal i objašnjenje zašto to treba? :D
evo ovde sta je Windows Telemetry
https://msdn.microsoft.com/en-us/library/windows/apps/hh967787.aspx
Telemetry
Telemetry refers to the data we collect about your app when it's running on customers' computers. If you enable this feature in your Windows Store developer account, your app will automatically send info back to Microsoft about how often it has been launched, how long it has been running, and whether it has experienced an error such as crashing or encountering a JavaScript exception. We collect this info for each app, analyze and summarize it, and provide reports in your Dashboard. You can choose to enable or disable telemetry data collection at any time.
ovim iskljucujes  da te ne prate i uhode. sakupljaju tvoj "DataCollection" elsewhere.
verovatno ce vec sledeci apdejt da pregazi registar. al kliknes ponovo  Disable-Telemetry.cmd  :buehehe:
A gdje kliknem?
Zaista je vin10 najbrži vindovz do sad, niedan se nije sjebo nepopravljivo za manje od jednog dana  :buehehe:    pokušao je nešto sa restore al džaaba...
post-1515-0-99578200-1438355992_thumb.jppost-1515-0-17069300-1438356011_thumb.jppost-1515-0-61716600-1438356005_thumb.jppost-1515-0-19845000-1438356017_thumb.jppost-1515-0-11665700-1438356024_thumb.jp
sad ce neki baja da se pojavi i da ti kaze - TAKOE strikane.  :clap:  :clap:
FUD majstori  :buehehe:
srecom ovo nije specijalizovani IT forum.  :thumbsup:
Vidi ono nije na tvoj račun, niti tebe zezam ili bilo šta uvezi tebe, ti si 101% ok lik i slažem se stobom da svi novi OSi izgledaju fensi i "deluju  kao da su brzi" mnogo je kraće butovanje i dobar je osećaj imati nešto novo na mašinama...   no neko koristi računar i za mnogo ozbiljnije stvari (od skupljanja slika s mora ili šta god već) pa ako nije u mogućnosti da stavi bilo šta drugo (ili ne ume) osim vindovsa :wavecry: kukala mu majka...
Po meni ceo smisao postojanja "besplatnog" vin10 je u onom STORE-u. Jednostavno su skontali App store ili Google play kako "odlično" šljaka i sad treba ljudima uvaliti neki klijent a da nije od konkurencije?! Kako ćemo, hmm....  lako podelimo ga za dž i ljudi će se primiti...
Ok za "naše" 99% pitratsko tržište ni ne računaju mada pejpal se primio pa možda kapne nešto i za mikroshit jer jašta nemaju dovoljno a gde će naivni ljudi kupiti komotno i jednostavno neko programče za "svega" dolar dva a da budu "sigurni" da je original (jel ondak radi sigurno bolje no pirat)  turiš mu pod nos STORE taster koji je automatski povezan s pejpalom ili nekim njihovim sistemom plaćanja...
Što reče neko pre par postova mogli su makar promeniti neke stvari čak je i aktivizacija ista kao kod prethodnika...   sramota!
 Priznaj da je ovo bilo jače od tebe :buehehe:
...ma nije :wink2: čak nije ni najgore to što se vin10 spušio nakon stavljanja par igara (radi realnog brzinskog testa) već što sam upisao (od Novembra) i MCSE  :wavecry:  već me hvata muka...
