RAAL - Eternity omni speaker
Mikorist
RAAL have been on the news!And here's why .... post-1-126436642453_thumb.jpg post-1-126436647045_thumb.jpg Construction and Assembly DetailsRAAL - Eternity omni speaker - 5 x 15" woofers and one hole. In the cylinder above the woofers, there is 18 x 3" cylindrical array of full-range drivers serving as a midrange and one omni tweeter with 15 ribbons. About 170 cm tall in total.post-1-126436644902_thumb.jpgpost-1-126436649866_thumb.jpgPouring the Eternity Mold
Eternity Assembly Processhttp://6moons.com/industryfeatures/roadtourserbia/raal.htmlRaal-Requisitehttp://www.raal-requisite.com/index.htmlContacthttp://www.raal-requisite.com/pages/contact.html"The Raal-Requisites are omni-directional speakers. They cost likea Porsche 911, unfortunately. The sound? It's kind of like driving a Porsche, and that's good."Ultra High Fidelity Magazine :blush:
  • Odgovora 64
The omnipolar true ribbon sports an aggregate surface area of 315 square centimeters as opposed to your garden-variety 1-inch dome tweeter. The crossover transition from bass sphere to midrange array occurs at 200Hz with a combined 1st/2nd-order lo/hi-pass. An equivalent transition is set at 2500Hz between mids and ribbons. The input impedance of the forthcoming 300-watt 8 x KT88 push/pull amplifier will be 16 ohms, the customer's amp to drive the mid/high array (and input of the included bass amp) sees 4 ohms for the direct connection. Frequency response is 30 - 40,000Hz and anechoic sensitivity is 90dB. Perceived sensitivity in a standard (echoic) room will naturally be higher because it adds the reflected energy. Alex estimates about 94-95dB. Recommended amplifier power is 10 - 500 watts and total dimensions are a surprisingly compact 63 x 63 x 155cm, with the diameter of the mid/hi cluster 20cm or slightly wider than a CD jewel case. The weight of each speaker is a rather manageable 85kg.
vidjene kolumne su sad - ako smem da kazem - u vlasnistvu dragog nam i postovanog AR2 :blush: gledajuci postovane fotke - mislim da su one upravo Vladino (AR2) delo .Aca je napravio sta je hteo , pokazao sta ume i - dace Bog - imace uspeha sa svojim mini zvucnickim sistemom , prezentovanim na sajmovima posle Eternity-ja .Eternity - mada bi meni licno bilo veoma drago da se nastave proizvoditi u znacajnom broju primeraka - su po svoj prilici bili/jesu izvanredna demonstracija sile (if ya drift my catch)...... ali su preskupi da bi se proizvodili u znacajnijem obimu :hyper:
Ne sumnjam da imaju dobar zvuk. Ali dizajn, oblik, forma su upitni. Atraktivno mozda je ali nije za svaku kucu i svaku sobu. Tesko da zamislim enterijer u koji bi ih stavio.Ona plavusa na slici je bas suprotno, odgovara svakom enterijeru. :blush::hyper:
That's real nice. Great that Alex has come so far, that he can now go all the way, and use his abilities.That he is a nice guy as well, only makes it even better. I had the pleasure of spending some time with him in San Francisco a couple of years ago. The clip of pouring the mold, sure brings back memories. The attached pic is showing the pouring of the mold for the main chassis of the Donut.Magura :blush:
Stavio bi ih ja u sobu pa neka priča ko šta hoće... Bole me brige, zli jezici :blush:
Sta reci a da to bude dovoljno da bi se opisao ovakav ULTRA HIGH-END. Acin uspeh je OGROMAN samim tim sto je uspeo da napravi konkurentan brend u svetu, a da je radio u, i iz Srbije. Sta reci sem svaka cast Aco !!!!!!!!!!!!!!!!!!
Ma čovek je legenda!! Mogu samo da ga mrze ovi što ga ne voleeeee.....šta je trebalo da napravi? = kocku od medijapana?
Citam ove komentare i ne verujem ocima. Zvuchniak me citira kao neki "zli jezik". Nigde nisam napisao da coveka ne volim. Cak ga ni ne poznajem, a nisam ga ni spomenuo. Moj komentar se samo odnosio na dizajn. Da li je trebao ili ne praviti "kocku od medijapana" u to ne ulazim. Isto tako ne ulazim u to da li nekoga treba da volis da hvalis njegov rad ili dizajn. Mnogo se palite verovatno iz te ljubavi.Ja sam dizajner vec 30g i komentar se odnosio samo na dizajn, bez ljubavi, bez mrznje, bez zlih jezika. Ako je nesto drugacije ne znaci automatski da je lepo ili ako je lepo da je prakticno.
...da, da....a što si mene citirao? Ja nikog ne prozivam samo izražavam divljenje. Ni ja ga ne poznajem. Mogao je da napravi najružniji najnepraktičniji zvučnik ja bih i dalje rekao da je car neko ko ima tolika muda da napravi nešto toliko drugačije od standardnih box-ova...
Na kraju mog posta je bio smajli za jezikom napolju. Kad sam rekao zli jezici nisam mislio na vas, nego na one koji bi rekli da je ružno kada mi uđu u sobu, ali hajde da se ne pravdam više jer nemam volje/potrebe za tim. Ko je definisao lepotu ? Meni jeste lepo, jer ja ne vidim dve kugle sa valjcima odozgo nego ultra dobre zvučnike. Po toj logici Monitor Audio je prelepo dizajniran. Kako zvuči, to je već upitno. Ovo je hobi u kom je zvuk malo bitniji od estetike (koju za mene ovi zvučnici imaju). To što se bavite dizajnom (recimo enterijera kao moja lepša polovina ili industrijskim dizajnom ) vas ne kvalifikuje automatski da definišete lepotu. Izvinite ako vam se odgovor čini malo oštrim, ali to je moje mišljenje na koje imam pravo bez ikakvih loših namera ili želje za daljim prepiranjem.
Samo polako ove bronzane "sfere" nije radio Aca vec :Prof. Nikola "Koka" Jankovic, sculptor; Zoran "Kuzma" Kuzmanovic, sculptor. The sculpture in the back is Nikola Tesla, made 30 years ago by Prof. Jankovic, who gave the Eternity name to our speakers. The bass sphere bronze is carefully cast in Kuzma's foundry and Vladimir Ivanovic is the designer of the speaker's appearance and the one that sculpted the bronze. He will also design our amplifiers to have a sculpted bronze top plate.post-1-126446133788_thumb.jpg post-1-126446136061_thumb.jpge sad estetika skulpture je nesto o cemu se moze raspravljati kao i o svakom umetnickom delu...Rukotvorine se mogu podeliti u tri opste klase:1. one koje su prakticno korisne, ali ne izazivaju nezainteresovano dopadanje;2. one koje su i prakticno korisne i izazivaju nezainteresovano dopadanje i3. one koje nisu prakticno korisne, ali izazivaju nezainteresovano dopadanje.Umetnicka dela spadaju u trecu klasu.Nije Filosofski forum da dalje laprdam....Ali da je RAAL filozof u to ne sumnjam :buehehe:
Ljudi, to sto vi slusate, ja znam kako izgleda na merenju. Pa, pobogu postoji toliko radova na tu temu od strane sivih eminencija zanata, cije misljenje ne biste bacali u vodu tek tako, kao moje. To sto nemate iskustva "s one stane zvucnika", ja to razumem, ali kako ne mozete da prihvatite da postoje ljudi koji ga imaju, i kazu: merenja tacno, ali TACNO reflektuju ono sto se iz zvucnika i pojacavaca moze cuti. Preslusavaju se samo varijante za finalne finese u karakteru nekog zvucnika, ali to tako malo odstupa od merenja, ako uopste odstupa. Kako vam je jasno da neko ko pravi pojacavac, mora da ima osciloskop, pa voltmetar, ampermetar itd. Zasto ne sednete pa preslusavate, nego covek zabode spravu i gotovo. Potpuno ista stvar je i sa zvucnicima, cak povoljnija, i sve je veoma objasnjivo, nema vudua, nema magije, ne postoje slucajnosti. SVE se vidi, ako onaj koji nesto meri ume da tumaci rezultate merenja, ako je izmerio SVE parametre. Analogija sa "komponentama u xy uredjaju" ne stoji, ako poznajes nacine uticaja parametara te komponente na ostale parametre sistema, sta je tu sporno? Jedino strucnost konstuktora koji se time bavi. Naravno postoje i nove metode merenja koje to olaksavaju, nekada nije lako bilo proceniti sta se desava u vremenskom domenu, ali danas imamo waterfall, ETC, pulse response. Pa upravo to kad vidim, tacno znam da li je zvuk tvrd, zaobljen, cist, prljav, brz, spor, zamrljan i sve sto treba. Znam i kakav stereo ce biti, i kako ce zvucati violine, vokali, cinele, dobosi.......Pobogu ljudi, pa utvdjene su egzaktne paralele izmedju auditivnog kvaliteta i metoda merenja koje to oslikavaju. Ne razumem kako mozete da tako lako potcenjujete necije naucnicko bavljenje nekom temom, a da preuvelicavate sopstveni laicki pristup, za koji ne kazem da je pogresan, vec da nije dovolno dobar. Postoje misljenja, ali postoje i argumenti. Lupetate svasta, a nemate tri ccuke o tome sta se i kako radi u svetu. Citajte malo AES-ove i Bruel-Kjaerove biltene, Linkwitza, Johna Atkinsona (This series of articles was initially written (in slightly different form), as a paper presented at the 103rd Audio Engineering Society Convention, New York, September 1997. The preprint, "Loudspeakers: What Measurements Can Tell Us—And What They Can't Tell Us!," AES Preprint 4608, is available from the AES, 60 East 42nd Street, Room 2520, New York, NY 10165-0075. The AES internet site, offers a secure transaction page for credit-card orders. )pa onda mlatite praznu slamu o tome sta (veoma dostupna) nauka moze, i sta ne moze, da objasni. Malo sam studirao i primenjenu fiziku, pa znam i o toj temi stosta. Da objasnim, ako neka sprava tacno izreprodukuje ulazni signal, to je to. Svako od nas cuje drugacije, ali ako je ispunjen prethodni uslov, svima nama ce to zvucati prirodno, i kraj. Nema tu neke mudrolije iliti preobimnih slusnih testova. Oni sluze da napravis najbolji moguci kompromis, ali ne da postavljas stvari iz fundamenta. Nemoj sada neko da mi pomene "beskompromisno", moram onda da navodim i literaturu koja se bavi pricipima postojanja. Vi mislite da se svi u poslu time bave na isti nacin, pa posto ste videli da neko mora da preslusava svaki korak u projektovanju necega da bi "znao" gde je, mislite da je to pravilo, i da drugi nemaju pojma sta rade. To, jednostavno ne mora da bude tako i nije tako. Pa nisam ja ovo o cemu pricam izmislio, bre. To sto je vama to avangarda, to je vasa stvar. Ja znam gde sam u startu, zato sto imam nacina da to egzaktno utvrdim. Dao sam jedinih 15000 $ koje sam imao za zvucnicarsku mernu opremu i 3D softver za projektovanje magnetnih kola, da bih se zajebavao, je li? Vama je toliko neverovatno da neko nesto bolje zna od nekoga ko je uspeo da prodaje, da stvarno zvucci ko da ste se juce rodili, i mislite da mu je krivo i da je glup i rigidan. Znanje i prodaja nemaju nikakve veze. Svako je za nesto dobar ili nije dobar, samo ovaj koji zna, moze tu prednost da iskoristi kad 'oce, i uvek je korak ispred (ovo pricam principijelno, ne poredim se ni sa kim). I dokle ce ovde da se kritike neke robe shvataju licno, pobogu?!?! I muka mi je vise da se uvredama branim od uvreda analfabeta, koji jos nalaze za shodno da me procenjuju kao coveka. Da znate nesto o tome sto pricate, videlo bi se, obrazlozili bi nesto, ne bi navodili citate iz prospekata, ovako kad dodje do uvreda, umem i ja(mozda sam malo preterao, priznajem, ali se ne kajem, kao ni druga strana, pa predlazem obustavu istih, 1:1 i kraj). Slusni testovi, drz-ne daj, pa nisam ja postovao merenja kao dokaz, ali kada sam dao svoje misljenje o tome, na osnovu ponudjenih merenja, odjednom to vise nije dokaz nego cemo da sedimo ko babe, i da slusamo, jer je to najbolje kad nemas kontraargument.Vladika Nikolaj Velimirovic:"Lako je nauciti passcce,lako je nauciti prostaka,ali je skoro nemoguce naucciti onogakoji je nenauccen postao uccitelj drugima."
Citat odavde:http://www.benchmark.rs/forum/showpost.php?p=1792991&postcount=437Inace sam se tamo uclanio samo da kazem da je ovo nesto najbolje sto sam procitao ikad tamo - i to je moj jedini post... :buehehe:
Лично ти ралови су интересантни!
Мада нико не рече колико коштају та два "Скулптурна" звучника !
Ипак бих више волео нешто овако:
Некако имају драж у боји дрвета!
стоН_Колд
