2825 -
34
Postovi objavljeno od neskor
vrati da bude tako, samo okreni kond
i proveri da li su oni redno vezani otpornici 790K zajedno
da li si izvukao dobar otpornik od 2M, posto imas dva komada u jednom kanalu
izvuci otpornike od 2M i 3M ,to su onda dva plava otpornika pored 0,1uF
i prespoji 0,1uF sa 100R otpornikom
a ovo je Thorsten RIAA
obrati paznju da su ovde vrednosti 100pF i 330pF i 750K u RIAA kolu
Ako si radio Roberth RIAA (C6=100pF i C7=270+33pF) onda treba ovo da uradis:
The 680k and 110k resistors are in a series in the 750k resistor position.
The 270 and 33pf silver micas are wedged in the 330pf position in parallel.
The 110pf silver mica has been replaced with a 100pf silver mica.
The 2M and 3M3 resistors are removed entirely. They do not require bridging.
The 0.1uf capacitor is replaced by a 100 ohm 1/4W carbon comp. resistor.
The Elna Silmic 2 100uf 16V capacitors are placed in their positions- take note of polarity.
The second 2M resistor that was located above the 2.2K resistor has been replaced with a 680k resistor.Note on the 2M replacement resistor: This area may effect bass response under 100hz with certain tubes. We are working on a solution to this, looking at more tube data and may have a recommendation of either an optimized value for the tube you are using, or a variable resistor which you can adjust if you do a lot of tube rolling.
The general consensus is:
680k for NOS tube examples
2M for new production chinese examples
3M3 for 6N2P-EV -
verovatno si nesto zeznuo u RIAA kolu
da li si radio Robert's optimized RIAA ili Thorsten RIAA?
izmeri jos jednom svaki otpornik i kond, negde je greska
koja je izmerena vrednost izlaznog/krajnjeg otpornika ?
obrati paznju na C7 i C6
ako se na mesto V3 stavi ecc83 treba promenit otpornik od 68k sa 120K
koliko vidim sa slika, grejanje 6,3V je nepovezano sa plocice napajanja na audio pcb
jedino ako ima neka veza sa donje strane plocice
a ovo je verovatno shema:
1 hour ago, prophet said:
Lepo. Sa kojom vrednoscu konda si merio?
Jos da ti je par ovih:
https://audio-heritage.jp/YAMAHA/unit/ja-6681.html
Sent from my SM-J530F using Tapatalk
Sam driver u sebi ima kond od nekih 16uF, ako se dobro secam, kao DC zastitu.
Za ovo merenje sam koristio 2,2uF
Inace ovaj drajver se koristi za opseg iznad 7K
ako nekom bude trebalo ima gotovo AN napajanje ovde:
pa dok se nakalemi PDV i carina od pocetne cene od $449 za jedan driver, dodje se do $930 u Srbiji
- aaa zmaju! je reagovao/la na ovo
1
3 minutes ago, revox said:
ovaj pleksi je pao fenomenalno ... ja planiram crni da stvim na plinth za lenka ... otprilike ovaj đir samo crni pleksi
daj malo detalja uklapanja rucke I sasije tanjira sa pleksijem ako nije problem
ja sam se dvoumio izmedju crnog i belog, ali sam ipak na kraju prelomio i uzeo beli
plexi je isecen potpuno isto kao i gornji sloj plintha,
inace plinth se sastoji od 4 sloja spera, ako se dobro secam
plexi zalepjen lepkom za drvo, a ivice plexia su poravnate pomocu kopir glodala
Trenutno na sajtu 0 članova, 0 Skrivenih, 43 Gosta (Pogledaj celu listu)
Ukupan broj tema436k
Bedini
in Solid State
da li neko zna cemu sluze ovi trimeri?
da li je to za podesavanje DC ofseta?
