10084 -
137
Sve objavljeno od zerowaf
Gospon Srecko, niste ni svesni da ste otvorili Pandorinu kutiju. Jos cemo sad svi da se izmirimo, i kako onda da idemo dalje?
De, dobro je! Mogao si da pises i na Klingonskom. Ko bi onda mogao da te razume?!
De dobro je! U redu. Osjecaj se kao kod kuce!
Nisam rekao da nema, ali se na zalost ne bih ni iznenadio da stvarno nema nikog za preporuku. Mozda Branko Bin moze preporuciti nekog kolegu iz HR? Branša ionako ne poznaje granice.
Jedini za kojeg znam u HR je bio, na zalost, pokojni Damir Ipcevski Senf. Nadam se da postoji jos netko. Zao mi je sto te ne mogu uputiti na nekoga tko bi ti pogledao te drivere.
Mora da si se vezao na dalekovod. Gornja je odvodnik prenapona ak´ bi, ne daj Boze, grom lupio u nj.
Zero happy! C/P Wiki: "Mingus is the tenth studio album by Canadian singer-songwriter Joni Mitchell, and a collaboration with composer and jazz musician Charles Mingus. Recorded in the months before his death, it would be Mingus's final musical project; the album is wholly dedicated to him. Mingus was released on June 13, 1979" Album tiskan 1979, Asylum, njemačko izdanje. Near mint, prodan pod mint, ali ne zamjeram. The personnel on the actual album were: Joni Mitchell – guitar, vocals Jaco Pastorius – bass; horn arrangement on "The Dry Cleaner from Des Moines" Wayne Shorter – soprano saxophone Herbie Hancock – electric piano Peter Erskine – drums Don Alias – congas Emil Richards – percussion ("wolves")
zerowaf je odgovorio/la Leonardo's temus u Muzika , Film i Fotografija
za ideju, tj. za priču! Restoran u kojem nije jedan Chef nego njih nekoliko. I nitko nije pravi chef nego su svi bake...osim jednog djeda! Enoteca Maria | WWW.ENOTECAMARIA.COM Enoteca Maria is an Italian wine bar and restaurant located in the St. George section of Staten Island, New York. Our two kitchens at Enoteca Maria will continue to serve regional Italian cuisine from the nonne of Italy, while offering a second menu of a different nonna every night from any and every country in the world. Start following the online book that is being generated at www.nonnasoftheworld.com -
Bluetooth stage monitor? Hell yeah!!!
Nisam kod kuce. To sam napravio jedan snipshot iz videa u kojem klinka pjeva nesto od Metallice. Zato ne stavljam video ovdje niti igdje javno. A sat je zapravo iz Japana. Seiko. Mislio sam da ce biti tih, ali kad sam stavio bateriju sam se vratio u djetinjstvo jer je glasan kao one vekerice kad dodjes kod bake. Istina! Najbolje kad se jos ugasi televozor. Jos samo veliki zvucnjaci. Pokrenuti su koraci. Koliko sam brz, mozda do ljeta..... Inace, stvarno jesam sretan sa sistemom, ali jasno je da uvijek negdje ima bolje jedino sto, nakon jedne granice to covjeku vise i nije vazno. Sve s cime se igram nije radi ikakvog poboljsanja. Stvarno sad to vise radim iz znatizelje nego zbog toga sto stvarno zelim ista bolje. EDIT: A moram reci i da je ovaj setup skoro kopija Wolandovog setupa u smislu da su Preamp i amp djelo ZM Labsa, Tannoy zvucnici koje je amenovao ZM, nemamo isti gramofon, ali je bas on okosnica sistema (bar tako mislim) i oba imamo LCR lampaski phono stage samo ne isti model (bar tako mislim). Oba ocito volimo muzikalnije zvucnice (EMT i SPU). O ovakvom setupu snivam vec preko 15 godina. Naravno, mislim na koncept ne na tocno te proizvode jer ih tada nije ni bilo, a buduci da stjecajem okolnosti sad imam mogucnost ostvariti si tu zelju sam si promasao i opravdanje da bas to i uradim. Ono kao, za pemziju jer tad necu vise moci. Uopce ne mislim hocu li tada ista vise i cuti.
Ovo svakako jest tocno! Usporediva storija je i kod mene. Zvucnici su doduse manjih gabarita, ali je hifa bila dio kako kuce, tako i moje osobnosti. Ovakva soba je zato nesto skroz normalno. Pomaze i to sto malena voli slusati na "velikom sistemu", pa onda iz kuhinje zena i ja slusamo Bohemian Rapsody u izvedbi sa pet glasova umjesto sa cetiri.
Jednom kad velike stvari dođu na mjesto počinje pravi show. Te žica, te zvučnica, te ručka, te gdje koja ploča, te nova vitrina jer u staru ne stane još ploča.... Sve onako neki sitniš osim vitrine, a bolest nikad jača! Dok se dovlače kutijetine još se i može kontrolirati. Kad dođe do ovih pica-boca počinje prava opasnost. 😎😂
Moguće, ali shipping iz Japana, pa dodatno davanja državi. Na žalost skupo. I ja sam ga neko vrijeme čekao na američkom, austrijskom i njemačkom ebayu. Na kraju se pojavio na austrijskom ebayu. Interesantno da ga američki ebay nije prikazivao u rezultatima. Dao sam ponudu koja je prihvaćena i kupio ga jer sam već bio kupio i čekao da stigne SPU AE. Možda ću do ljeta još nabaviti Wood A i mislim da ću tada sa 4 SPU zvučnice moći reći da je to to što se SPU tiče. Onda prelazim na EMT.
Jeste! Samo...jučer sam u šali napisao da ću ga možda čuvati za dan kad nabavim SPU Wood A, a kako sam prenoćio tako sam odlučio da mi ne stoji na nozi i da će mi biti praktičnije imati dva adaptera za dvije A zvučnice. Sorry zbog promjene mišljenja! Dobio sam ga bio prilično povoljno i ako ću ikad trebati još jedan više neću moći nabaviti po takvoj cijeni. Ne drži ga više niti Ortofon, a drugi prekupci su odmah digli cijenu sa ca 60€ na 120 €. Slično kao i Ortofon kutije za SPU. Nema ih više kod Ortofona, a prekupci su počeli tražiti po skoro tri puta više love za njih.
Ne tako davno se lampiziralo sve što ima D/A chip u sebi i to sa sve otpornikom na mjestu I/U konverzije. Čak sam i ja to uspio napraviti. Ima negdje tema na forumu. Nisam ni danas bog-zna-kako-pametan, ali tad sam bio baš ono pravi žutokljunac. Ukratko - veliko "DA" za lampe! Ima više nego nekoliko pravih majstora za lampe, a netko od njih će moguće dati i prjedlog za I/V konverziju. Tko zna, možda i s nekim prijenosnim trafoom....i da bude sve košer, neka bude i "WOT" izlaz. Netko na forumu reče da željezo pomaže očuvanju energije signala...ili sam ja sve pobrkao? Uglavnom, zašto ne? Spojite 21 stoljeće sa termioničkom lampom i imat ćete proizvod za sajam audio ezoterije! Svakako, nemojte zaboraviti full cijevno napajanje za izlazni stupanj i to sa sve živinom ispravljačicom. Ako može Oswald Mills Audio tako napajati motor svog gramofona i tvrditi da zvuči bolje, možemo i mi predstaviti R2R DAC sa full lampama!
Hard negotiator!
Pošaljem onu nesretnu EMT za koju mi je rečeno da je FUBAR ako složiš dobar ZML Phono sa puno željeza.
Pa i je! Zamisli da ti netko sa ekserom napravi crtu na disku u HDD-u. Naravno, da nema više naše trgovine. -
Nevjerojatno! (Samo mi se ne sviđa to što je izgrebao vjerojatno još dobre ploče. Hungaroton zna biti jako dobar! Bar su jako dobre ove dvije što su završile kod mene.) -
Ceterum censeo Carthaginem esse delendam....et quod PCM1702 sit lex -Marko Porcije Katon, oko 150 g.p.n.e.
Ma ako nas i pozatvaraju, nadam se da će nas razvrstati po žanrovima! Što se godina tiče, možeš me poslati po šibice! Nisam još napunio 50. Jurim prema jubileju, ali nije još zokružen.
Trenutno na sajtu 5 članova, 1 Skrivenih, 165 Gosta (Pogledaj celu listu)
Ukupan broj tema453.7k
