sp300b
Sve objavljeno od sp300b
  1. Kako li ce tek ovo da zvuci na passive I/V conversion My link
  2. Put putuje moj jaran ...
  3. :hi: ;)
  4. IGORE...a gdi ti mobilni ??? :clap:izvini se porodici u moje ime što zvah kasno...na tvoj mobilni ....
  5. Moj je još nevin - nije otvaran...ali biće - čim dodju trafoičići...
  6. Jok bre, ovako ;-) I šta se tu promenilo. Da li su stvarno pili limunadu samo
  7. http://www.primare.net/assets/_managed/products/files/cd31inside~hires.jpg
  8. Uzmi, uzmi, ne da se baci ;-)Ma ne cujem ti ja preko 15.000 Hz :hi:p.s. Odakle ti informacija da se koristi nesto drugo osim DSL 710 A? (slika je sa tvog CD-a)
  9. :clap:
  10. Nisi ti baš tako neuk, kakvim se predstavljaš (mnogo me podsećaš na p18)Piše power transformer...mislim da je za velike snage, ali teorija važi i za male snage (bar što se načina motanja tiče)
  11. vidim već, biće, Two bad, Miloš dead
  12. Zanimljivo...jako...
  13. Uči Ti, Uči Ti i samo Uči Ti...Lenji N...(1) 2-Section Wholly-WrappedPrimary winding:No. of Sections = 2No. of turn per section = 14 turnsStranded wire = 12 threads of AWG25Total Inductance = 3.5mH at 10kHz, Q = 46...Construction and Test Results:Primary windings were divided into 2sections, wound on the most inner and outer of thebobbin to enclose the secondary windingscompletely. Secondary windings were divided into4 sections wound inside the primary windings, andeach two sections were connected to form a centertab for output grounding.----However, the assembly procedures fortransformer no. 2 was much more complicated than thatfor transformer no. 1, so the simple 2-sectionwholly-wrapped technique was recommended, and theresults did also prove that the tighter the couplingbetween primary and secondary windings, the lower theleakage inductance, and the more stable the converterworks.
  14. Audio Transformer ...pa citati kasnije....sve su rekli jos 1953 godine...i jos malo
  15. Uputstvo za namotavanje Transformatora.
  16. Da Zen, hvala nesto ovako odprilike
  17. Kako se meri Induktivnost Primara? ozbiljno
  18. Pozdrav, Kako se meri Induktivnost Primara?
  19. OK, ok..
  20. A sad?
  21. Hey Zen...jesmo li pronašli odgovarajuće transformatore ?
  22. Ajde neka ostane ...malo teorije Dac & Transformer's output
  23. Mislis, "javlja ti se" ..vidi ovaj Thumb.... koji sam zakacio
  24. Moji su LL1636...Ovi tvoji izgledaju zanimljivo u "C" varijanti...hmm...
  • Trenutno na sajtu   2 članova, 1 Skrivenih, 189 Gosta (Pogledaj celu listu)
    453.5k
