naletim na vidoja reklamu eminentne prodajne kuce fifi uredjaja u Prestonici ....... ne bih ni gledao no rukama sam radio nesto a oci blude po ekranu
sve lepo na vidoju, polica lepa i siroka, pa sprave pa granafor pa zvucnjaci na stalcima pa sobu nisam ni stigao da vidim kakva je
vadi baja LP iz omota, ćapa prstima LP pa tek kad je stavlja na tanjir ufati kako treba sa dve ruke - prsti na samoj ivici
pritiska play na granaforu, locira rucku na pocetak, spusta lift i igla krene negde od vec centimetar pesme
jbm te zivote, i treba da crkne rokenrol kad ga svako svira ....... treba da verujem u elokventnost prodajnog osoblja koje ne zna da manipulise sa vinilom?
DIY je zakon
ajd uprosceno - BD137 je isto sto i BD135, samo malo visi napon
sumnjam da je tu na putu signala, sto ce reci da najverovatnije nije bitno koji si stavio, samo da je ispravan
10, 16, 25
razredi pojacanja
kad nema suffix, moze biti bilo sta po pitanju beta
dakle, ne beri brigu, stavi bilo koji, samo da su isti u kanalima- ako je put signala
ako nije put signala nego neki regulator, onda tek nije bitno
a dobro svira
eo, starci rekli :
https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8093424
https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8096104
copy-paste sa bigdiya
https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8333010
finally got time to put my own in case ..... as usual - industrial design - workshop/demo specimen
through years, amassed number of Dodo gadgets, and using those cases for traveling prototypes and demo units
two boxes ticked - nobody will buy those and there is no harm when denting elevator doors
this one put in case of some weird PA duty double cassette deck
and yes, this one is Bal, so serving as simple SE and Bal demo unit
even found use for slightly damaged/bad TFT - having dead vertical line; good enough for ZM's own
at least nothing is rattling in remote ...... as is case with someone I know ....... he said - "they are always giving me leftovers "
ene, cela situacija oko samih drivera nije problematicna (vise) - reseno je
kako razumeh, gorak ukus ostavlja prvenstveno odnos proizvodjaca ....... take money and run
ahem
pominjao si Izvor
kako ono bese nastade AN UK, pa onda originalni AN morao da doda Japan, da se razlikuje od firme koja je bila povezana, pa nije povezana .....
