stein
Sve objavljeno od stein
  1. stein
    Hafler 9505
    Ja sam mislio da slušate muziku... Preko zvučnika... Kako se slušaju zvučnički kablovi?
  2. Zarad izbegavanja prevoda sa engleskog, posle celodnevnog slušanja muzike, došao sam do zaključka da cevni stepen opravdava svoje postojanje, ovo je sasvim novo pojačalo, ali imam i problem sa predpojačalom, a to je činjenica da kvari sveukupnu lepotu koju su unele cevke. Kada se zaobiđe cevni stepen i ide na Quada direktno, onda NS10 popravlja stvari, a sa cevkama na putu signala, kvari. Ne znam još šta ću i kako ću, ali sada slušam direktno uvezan CD na cevni stepen. Veoma sam zadovoljan.
  3. Everything works fine, in fact, much better than expected. However, have a small problem. My NS10 preamp appears to be doing more harm than good in the signal path. Connecting the CD player directly to the active crossover (bypassing the NS10) does miracles to music. Clear, crisp, refreshing, amusing, and vivid... With the preamp back in the system everything becomes dull and somehow less fresh and clean, I would say fuzzy... With no tubes in the path, the preamp acts in a completely opposite way than described. That leads me to a thought that it's time to let the preamp let go since with the tube stage the Quad does more good to the joy of listening to the music than the NS10+Quad, straight up...The preamp was built as a match to the F5 I had, but since these were clipping at high levels of listening and I had some issues with cash flow at the same time... Had to let them go. Now it's time to figure the best way to sort the control section. Will see if there's anyone interested to become a new owner of the preamp, if not, I'll take it apart, still need the RIAA that's inside, OTOH, I just might build me one of those glowing in the night RIAA devices...
  4. Nisam skidao sa pločice jer na oba sekundara ima osigurače pa sam odstranjivanjem istih, omogućio neopterećeno stanje transformatora. Dakle ovako:Kod uključenja, trafo trgne otprilike nekih 1.4A na veoma kratko, a potom se struja koju vuče (neopterećen trafo) smanji na nekih 10mA Pošto je u pitanju klasičan trafo preseka (koliko mogu da smerim) malo ispod 10cm2 a matematika 230Vx0.5A daje približno oko 100VA, onda mislim da ovo može da bude informacija koju si tražio.
  5. stein
    Tannoy, identifikacija
    Dobro, kada dođe dotle, objasnićeš mi šta da radim i kako. Samo nemoj stavljati neki CCS u to...
  6. One more...
  7. Ili ja... Taman imam jedan iz Ricoh fotokopira... 230VAC/50Hz/0.5A Ako uspem da ga skinem sa pločice, smerim ga. Konačno, sada imam DVA instrumenta u kojima je 200mA osigurač ispravan
  8. To su oni sa kojima je spaljivao svoje Germanijume?
  9. Misliš li na ovako nešto? http://www.diyaudio.com/wiki/DN2450_based_CCS_used_as_sink_bias_block_for_an_output_tubeIli na DN2540?
  10. Ne znam u čemu je tako velika prednost CCS-a jer koliko sam uspeo da shvatim kako radi, opet na kraju zavisi od otpornika, i to još više, plus zavisi i od poluprovodnika, ovih opet, ima u zilijardama podvarijeteta unutar iste oznake tipa da je usklađivanje ispalo praktično prezahtevno za moje skromne sposobnosti koje se uglavnom svode na polu-originalne ideje i sirovu upornost... Verovatno je konačan produkt 3-4 otpornika i dva tranzistora stabilnije napajanje strujom, i nemam ama baš ništa protiv toga, ali sam u ovom slučaju jednostavno toliko puta bezuspešno pokušao da navedem sklop da radi da jednostavno nisam imao više živaca da pokušavam...Ova moja je "amber" ne žuta, i koristio sam ih i sa F5... Samo treba paziti. Unutar granica u kojima radi, veličinom reda struje koja joj se pusti, menja boju
  11. Nije još gotovo :)Treba da rešim spajanje prednje Alu ploče, stakla i inox ploče (sa natpisom i finalnom dimenzijom prozorčeta za lampe). Sve je tu (već prikazano) samo da to uradim kako valja. Pošto inox ploča nema predviđene rupe za vijke, a staklo takođe, ostaje mi da izvedem ili neku varijaciju na temu lepljenja ili neku verziju od onih sa prethodnih strana... Pošto Al ploča stoji uz pomoć 4 mala M3 vijka, možda se okušam lepljenjem...
  12. Indikator LED zamenjen...Ovako mi manje smeta, štaviše...
  13. stein
    Ma slobodno navali, evo, ja ti dozvoljavam...
  14. I da i ne. Kao pitanje, da li je WV ista firma kao i Audi? Audi je u vlasništvu WV. Fostex deo Foster kompanije, kao što je Technics bio deo Panasonic-a...
  15. stein
    Ne marim ja, nego mi bezveze da sve držim u dva primerka. Jednom do dva puta mesečno, menja se sadržaj SD memorijske kartice koja je zabodena u autoradio. Žena smisli šta hoće, ja to prekonvertujem i snimim joj na karticu, kompresovane fajlove brišem s kompa da ne smetaju.
  16. stein
    Ova godina donosi zanimljive momente a radi se o zameni kreveta i kupovina pisaćeg stola i još nekih stvari kod ćere u sobi (za komjuter nisam baš siguran) Uglavnom, planiram da joj skockam neku muzikicu, veoma izvesno će to biti TBGC (GC sa ECC88) koji bi trebalo očistiti od prsta prašine i pretresti i probati, doterati po potrebi i sklopiti sa nekim izvorom. Imam sijaset CD plejera, tuner, a pošto sam na ove zvučnike natrčao slučajno, novi su, nisu veliki, mislim da bi mogli lepo da se uklope u priču. Platio sam ih 50€ za par i čekam na par visokotonaca od iste osobe. Nije hitno, neće biti hajend, samo treba da lepo sviri. Veoma je izvesno da će ćera u neko dogledno vreme da dobije i komp pa bih ga sredio da može da sluša i muziku sa kompa preko njih. Pošto kod nas u kući mp3 može samo na zahtev da se dobije (ženi za autoradio sa čitačem SD kartica moram da konvertujem iz losslessa) onda je pretpostavljam jasno da će ćera da dobija samo kvalitetne snimke...Tako nekako. Ali mora i kod mene da dobro sviri, ako se bude koristilo u potkrovlju. Takođe postoji mogućnost da se pazari neki veći TV (TV/monitor) pa bih možda ove mogao da ubacim kao zadnji par... Mada, nije jako bitno, treba da budu pošteno skockani, da to za čega su sposobni rade pošteno i dobro, a to što ne mogu, ni ne treba.
  17. Sretan Božić :)
  18. stein
    Perverznjak, možda ti znaš šta se bolje od bookshelfa može s ovim malim prcvoljkom?
  19. SCH...
  20. Ovo je stereo izvedba pa mi ne treba još jedna kockica...Praviću još jedan, ali bez lampi, samo za subwoofer. Zapravo, pojačalo je napravljeno, samo treba da se strpa u neku kutiju. Ova je podosta skupa igra, a pošto mi sub-pojačalo nije važno da bude nešto extra posebno lepo (ekskluzivno), onda ide u diskretnu kutiju... Ipak, pre svega ostalog, još treba da pripremim tajmer za mrežni trafo Quada pa da zatvorim kutiju i finiširam prednju ploču.Elem, probao da isključim NS10 iz muzičke vrteške, samo sa regulacijom u CD plejeru, i moram reći da sam se baš iznenadio. Zvučno, bolje, a razlika čini mi se čak i veća nego između Quada sa i/ili bez lampi. Bojim se da upravo kopam novu jamu... :character13:edit: I da...Sada mi ova plava za indikaciju uključenosti baš onako... bljak...
  21. Eto, malkice slušanja, samo Quad pa malo kroz cevke, pa nazad i tako (lako se rešava, kratkospojeni RCA i interkonekti samo zamene mesta na ulazima, max 10 sec. posla) i prvi, još nesređeni utisci...Instrumenti su jasniji, vokali takođe, i sva muzika, manje više kao da je skinuta neka tanana koprena koja boravi ispred kada svira samo Quad. Da kažem da je zvuk "topliji"? Ne bih rekao, uopšte nemam osećaj više izraženih visokih ili niskih basova ili potisnutih visokih. Razlika je zapravo veoma delikatna, ali primetna. Trenutačno ne koristim subwoofere niti aktivnu skretnicu. Čak se razmišljam o opciji da izvučem i NS10 iz vrtloga i probam direktno sa CD-a (ima vol kontrolu) pa da čujem da li ima šta da se čuje...
  22. Treba još lajsne da poslažem :)Treba policu da završim :)Opremu da poslažem na policu... Ajoooj, nema ni smisla da nabrajam šta sam sve započeo...Biće fotke kada bude malo više svetla...
  23. Hvala svima, Thanks to all @zflazar: Koju drugu kutiju? @Živorad: music not just flowing, but somehow growing @Magura: I think yes, didn't get much of comparative listening (not much time to make an overall test) but at first sight, it's simply better with them glowing creatures inside. More as I get to listen to more than one album @Zen: A jel' mora? Mislim, ono me ubilo u tri pojma kad ne zna dete da kaže šta mu je i gde ga boli...
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 227 Gosta (Pogledaj celu listu)
    450.7k
    Alen
    Alen
