silentbob
Sve objavljeno od silentbob
  1. Nije sam AI problematican, vec oni koji prave proizvode od njega (openAI, google...). U prvom videu se govori o tome kako je OpenAI namerno dodao ljudske osobine masini, da poveca engagement, po principu socijalnih mreza. Takodje se govori o tome kako je Sam Altman svesno pustio nedovoljno testiran prozvod u upotrebu. Kad bi AI davao "samo" trazene podatke uz pristojan eticki layer sve bi bilo mnogo bolje.
  2. ‘There are no guardrails.’ This mom believes an AI chatbot is responsible for her son’s suicide | CNN Business EDITION.CNN.COM “There is a platform out there that you might not have heard about, but you need to know about it because, in my opinion, we are behind the eight ball here. A child is gone. My child is gone.”
  3. https://hackaday.com/2025/07/16/the-dew-line-remembered/
  4. https://www.planetanalog.com/timing-startup-seeks-sweet-spot-at-the-intersection-of-crystals-and-ppls/?_gl=1*10r9jvs*_gcl_au*MTg2MjgzMzUyMi4xNzQ4OTcxMzYy*_ga*MTUwMzk5OTQwLjE3NDg5NzEzNjE.*_ga_ZLV02RYCZ8*czE3NDg5NzEzNjIkbzEkZzAkdDE3NDg5NzEzNjIkajYwJGwwJGgw
  5. Transparent aluminum: Tiny acid droplets turn metal into glass-like material PHYS.ORG Transparent aluminum oxide (TAlOx), a real material despite its sci-fi name, is incredibly hard and resistant to scratches, making it perfect for protective coatings on electronics, optical sensors, and ...
  6. Main board, ideja mi je da radim switch i2s signala relejima umesto multiplexer-om, procitah da je tako bolje zbog jittera... Nadam se da nece biti problema sa MLCK signalom... LPF isti kao u datasheet-u za AK4497EQ. Single i dual varijanta.
  7. Meni na ovim snimcima bolje zvuci bez kutije ...
  8. i malo vise od RAM-a ili VRAM-a
  9. Ja sam zbog ovoga napravio svoj software za Ak4497 chip ali nikada nisam uspeo da čujem razliku promenom. Ako se dobro sećam 6 opcija ima čip... Po meni nije vredno truda...
  10. Pojavilo se neko blago brujanje na izlazu Dac-a (50-60hz) pa sam resio da napravim linearni PSU za streamer komponente: RPI 5v, digitalni deo 3.3v i 5V i analogni, +-12V i 3.3v. Ujedno dovedem u red shumu zica i plocica ... U digiitalni idu LT1084 za rpi, 1085 i 1086 za dac i reclocker za analogni +-12v ide TPS7A39 a 3.3v koristim ovo sa LT3042
  11. Joj, kad to krene da pada... Druga stvar je sto ce besplatna ili jeftina energija samo ubrzati potrosnju ostalih resursa, tj povecati ekoloski footprint. Istorijski, svako smanjenje cene energije rezultovalo je u prosirenju kapaciteta proizvodnje robe.
  12. Upravo bi hteo da izbegnem nabadanje, tj da znam koji je originalni format bio, i da nije manipulisano/konvertovano. Npr dosta nove muzike se izdaje u 24bit depth i vece od 44khz sample rate, a nesto je konvertovano sa vinila ko zna cime u isto to, tako da nemam pojma sta je original. Zbog toga uglavnom biram 16/44 u flacu, ali kad bi imao bazu sa originalnim izdanjima i formatima mogao bi da gadjam preciznije...
  13. Btw, jel zna neko kako da nadjem sva zvanicna digitalna izdanja nekog albuma, sa sve tehnickim podacima: sample rate, bitdepth, format ...?
  14. Perfect Days (2023) - IMDb WWW.IMDB.COM 2h 4m | 0
  15. Neil Rigole (@nicky2shoes_music) • Instagram reel WWW.INSTAGRAM.COM 56K likes, 385 comments - nicky2shoes_music on September 25, 2024: "If only there were subtitles at their live shows🤣🤣🤣🤣".
  16. WaveIO uspesno brikovan i zamenjen sa FifoPiMa(by IanCanada). Lanac je sada RPI4 I2S -> FifoPiMa -> AK4497 DAC -> Whammy
  17. silentbob
    IT razno.
    20 years later, real-time Linux makes it to the kernel - really WWW.ZDNET.COM The work done on real-time Linux has benefitted the open-source OS for years, but it was only this week that Linus Torvalds admitted its last piece into the mainline kernel. Exactly what took so long?
  18. Ucim malo da radim sa osciloskopom i izmerih whammy sa 8Ω opterecenjem na oba kanala (i signalom). Otprilike posle 10Vpp pocinje da klipuje, sto po mojoj racunici mu dodje oko 2x1.5w, pa ko vole i ima dovoljno osetljive zvucnike eto ga savrseno letnje pojacalce. Znaci leti kao amp, zimi kao pre i head amp E da, kod mene su 7815 i 7915 verzija od 1.5A i 2.2Ω u CRC i bez led pa je +-15v...
  19. Argh, copy/paste sa cloud-a ne radi.
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 120 Gosta (Pogledaj celu listu)
    453.5k
