Mikorist
Sve objavljeno od Mikorist
  1. Meni od Dijane Krall
  2. Pitao sam Japanca kako je postigao ono.
  3. Delovi sa gornje slike Antek AS-2222 200va 22v transformer: http://www.antekinc.com/as-2222-200va-22v-transformer/ Shielded IEC connector with power switch and fuse Power-86 https://www.neurochrome.com/product/power-86-2/ Neutrik XLR Hifi2000 case https://www.modushop.biz/site/index.php?route=product/product&path=204_205&product_id=725 Ima varijanta sa drugim napajanjem https://www.neurochrome.com/product/smps-86-2/ plus može da se doda softstart https://www.neurochrome.com/product/iss-intelligent-soft-start-2/
  4. kako izgleda gotovo
  5. Ja ovo mora da nabavim (ili je možda samo ideja nekome ko ne zna šta će da sklapa) https://www.neurochrome.com/product/modulus-86-4/ Ovo je Gainclone ??
  6. Slučajno naleteh na ovo... Circuit Description The Modulus-86 Rev. 2.3 is a composite amplifier providing true world class performance. This performance level is reached by using a specialized audio op-amp to perform error correction on a high-power chip amplifier. This Neurochrome composite amplifier topology results in a high-performance 65 W amplifier with vanishingly low distortion and phenomenal sound quality. The Modulus-86 is a turnkey analog subsystem. It requires no adjustments and it achieves state of the art performance using readily available off-the-shelf parts. The Modulus-86 uses one channel of an LME49720 precision audio op-amp to perform error control on an LM3886 power amplifier. An OPA2277 precision op-amp is used as a high-end DC servo with third order filtering for an ultra-low output DC offset and fast settling time. The DC offset is less than 200 µV and is reached within ten seconds of power-up. A THAT1200 differential receiver provides common-mode rejection rivaling that of a line transformer, thus, minimizing hum injection by eliminating ground loops in the signal path. The Modulus-86 is power supply agnostic, which is a unique feature to the Modulus-86. Due to the error correction provided by the Neurochrome composite amplifier topology, the Modulus-86 performs as well on a traditional unregulated linear power supply or a switch mode power supply (SMPS) as it does on a well-regulated laboratory power supply. Key features of the Modulus-86 Rev. 2.3: 70 W (4 Ω), 40 W (8 Ω) output power when using the Power-86 and recommended transformer. Mono construction: One Modulus-86 board per channel. On-board error correction circuit with local low-noise power supply regulators. Ultra-low 0.000054 % (-125 dB) THD (1 W, 8 Ω, 1 kHz). Ultra-low 0.000088 % (-121 dB) THD (40 W, 8 Ω, 1 kHz). Ultra-low 0.00042 % (-108 dB) THD+N (40 W, 8 Ω, 1 kHz). Differential input with nearly 90 dB CMRR eliminates hum and ground loop issues. Differential/balanced/XLR input can be used with single-ended/unbalanced/RCA sources as well. Power supply agnostic. The phenomenal power supply rejection ensuring consistent, high performance even with unregulated power supplies and switch mode supplies. Ultra-low -120 dB inter-channel crosstalk in stereo builds greatly simplifies the power supply requirements. Elaborate use of planes and copper pours to maximize circuit performance by minimizing supply and ground impedances. Low-inductance signal ground connects to power ground at one point only for maximum performance. On-board Zobel and Thiele networks for maximum stability even with capacitive loads. On-board EMI/RFI input filter and ESD protection. Power and output terminal blocks accept wire sizes up to AWG 10 (5.2 mm2). All thru-hole construction with socketed ICs. Easy to solder. 90 × 70 mm board footprint. Bill-of-materials includes a Mouser Electronics Project Link for ease of parts ordering. https://www.neurochrome.com/modulus-86/ bolest
  7. Ovde je jedino problem kako spakovati nuklearni generator struje od par kilovata u đepno izdanje... Sam pogon nije toliko velik. (nije veći od motora Boeing 747) Problem je napajanje
  8. Evo ga SIT u NASA EM drajv pogonu. Ovde je od par kilovata komad. Veći tranzistor nikad nisam video. Mikrotalasi su na izlazu ovog bakrača toliko jaki da proizvode potisakv 333mN/KW. Postiže se sa njim brzina 3 km/s u aero tunelu
  9. SIT koji svira na 4Ghz . 30W ima jedan sa gainom od 10db na 2Ghz
  10. SIT je Izmišljen za vojne potrebe . Evo pdf ovde sa detaljnim tehničkim osvrtom (završava se domen na .mil) http://www.dtic.mil/dtic/tr/fulltext/u2/a299605.pdf Teško se učitava pa ču da ubacim kao atačment. Nisu ni zamišljeni da sviraju u normalnim audio uređajima. Pošto svašta nešto zabranjeno možete da napravite sa njima povučeni su iz masovne proizvodnje.... Recimo sa par komada može da se napravi ometač signala od 20W da blokirate sve signale na 2Ghz u pola BG Ruski Krasukha-4 system za ometanje radara JE PUN SIT-OVA koji sviraju. Dabome Zato ih prave po potrebi i po nameni (narudžbini). SIT.pdf
  11. Ali i sa njim prave pojačala
  12. Samo je drugačije kućište za liftove
  13. Ovo je slika od Kineza ... Ima ih
  14. To je ovaj kapiram https://www.ebay.com/itm/1pcs-NOS-THF-51S-THF51S-TOKIN-V-FET-SIT-NEW-japan/123370081778 stavio sam i Japanca i Kineza...Kinez ima dve ponude
  15. Ovi kad rasprodaju Tokine....Ovo vade iz nekog magacina, zalihe od pre 20 godina. Možemo da duvamo u prste.
  16. Ovde veoma lako može da se naleti na fejk. Ako je Kina
  17. Ili ovo https://www.ebay.com/itm/1pc-2SK182ES-TOKIN-Hi-Power-Hi-Voltage-V-FET-NOS-Original/232917730732?hash=item363afa85ac:g:Y8MAAOSwnbZYDFkx
  18. Ima da se kupe... ali cena je sitnica https://www.ebay.com/itm/4-pairs-of-2SK60-2SJ18-V-FET-transistors-Original-Sony-Japan-NOS/162922560064?hash=item25eef0fa40:g:6wQAAOSw6gRZ41Lq
  19. Mikorist
    Beta 24
    Za mene je profi samo kad robot "švajsuje"
  20. Onde drugi zvučnik ne bi ni pomogao. Pruga je na 10 metara. Ovo nadjačava zvuk voza
  21. Kod njih svaka birtija ima paragone
  • Trenutno na sajtu   1 član, 1 Skrivenih, 33 Gosta (Pogledaj celu listu)
    452.7k
