pre 58 minuta, NIXIE reče
još fali odozgo i biće ko Iskra
Identično brate haha :laugh1:
Samo što se razlikuje veličina, vešanje, papir, konstrukcija, način izrade, motor, magnet, princip, phase plug...
sve ostalo je isto :laugh1:
Princip se ne razlikuje ni malo, imaš magnet i kalem i  imaš 3way, gde je FR na open baflle.
Sredinu ti vozi jedan driver, to je uglavnom ono što čuješ.
Ono što ne čuješ, to radi jedan bas i jedan super tweeter recimo. :laugh1:
Koliko vidim, samo je bitnija razlika u ceni.
244385802_10227230622419291_6805827873423540985_n.thumb.jpg.b078a82f12bc4c975a9d280ef403ac45.jpg
243906618_10227230622899303_6676301223327898860_n.thumb.jpg.1a22d4dceef7b92bc245e78937e57ad5.jpg
243988931_10227230623299313_3803284371290809985_n.thumb.jpg.d7fcb2dc4349f902d1303d3341995cc8.jpg
243943286_10227230623419316_3451062169782255546_n.thumb.jpg.08399924fc6396ef5013fe36958cb1a8.jpg
The voice coil for the field coil driver now uses copper-clad aluminum wire. The cone and whizzer shapes have been improved. The motor geometry is a little better too, and the solenoid has been updated from a 6 Ohm to an 8.5 Ohm coil for about 1.7 Tesla in the gap. The phase plug is milled aluminum, with a faraday ring in its base, just above the gap. The moving mass is now down to 12.25 grams. The most recently completed drivers have a Qts of 0.43 and Fs is 17Hz. The open baffle pairs up the field coil with an Acoustic Elegance LO15-D16 with a custom phase plug. The LO15 is port constrained, much like slot loading. The field coil is magnet mounted. The baffles and sides are internally reinforced with aluminum. The baffles are santos mahogany (cabrueva), and the sides and bases are eastern hard maple. The current crossover is a simple 2nd order low-pass at about 400Hz, with the field coil running full-range.
Friends have shared some great insights recently though, on how I can refine the crossover design. I'll be working on applying some of those ideas over the next couple of weeks... I'm hopeful that effort will include crossing at a bit lower frequency.
Jbg kad vec ima takav drajver, mislim na F coil, koji ce mu bas helper i OB?
Da ti budem iskren, i ja sam se isto zapitao. Drajver je 12 cola, Fs 17Hz, al možda za ljubitelje OB-a, a ima takijeh među ljubiteljima FR-a.
Opet, možda zauzima manje mesta od bass reflexa, koji je oko 140L za njegov drajver, a i OB bass ima drugačiju dinamiku od ostalih - pa kako kome, po ukusu.
pa treba mu bass helper zbog fizike
nije napravio Perpetuum Mobile, nego FR driver
Napisano (izmenjeno)
Sva sreća te košta ko nov omanji hibrid. Tako da ne verujem da će se tako skoro pojaviti u nas. I to nazvati full range je čisto preterivanje. :grino:
Izmenjeno od NIXIE
ja malo znam o predmetnom driveru, a to malo mi kaze da je jedan od naprednijih u aktuelnim desavanjima
no, cini se da neki ojovud znaju mnogo vise ..........
:Viannen_loungelizard:
Kako to svira off axis? :nananana:
Pošto kapiram da mu taj kompjuter pozadi lepo pegla on-axis
Izmenjeno od Koja
Jeste, odlican drajver. Ja bih ga tako posedovao. No, govorim o primeni ne o drajveru.
Malo i o samom drajveru. Jasno mi je da velika vecina ljudi ne ume da uklopi tweeter kako treba i da se zbog toga ide na fr varijantu. Verovatno je to i ciljna grupa ukoliko drajver ide u solo prodaju. Ali, mnogo je bolje imati poseban tweeter. Naravno, adekvatno primenjen. Danas ih bar ima odlicnih. Zbog toga bi verzija bez wheezer-a bila pozeljna. Pogotovo ako se pledira da se ume napraviti dobar zvucnik. Vidi se i na tim merenjima kako se wheezer ponasa. To je uobicajeno za taj tip drajvera. Sa druge strane sa ovakvim drajverom ne ici na tqwt je greota. Moje misljenje naravno. Sveukupno, dobio bi se mnogo bolji zvucnik u oba ekstrema. Mislim i da bi footprint bio tu negde.
O koncepcijama:
OB je bolji za sobe sa paralelnim zidovima. Ulazi dublje u sobu ali zato neverovatno rekreira prostor. Mislim da je u prikazanoj varijanti to poprilicno labavo sa jednim 12" helperom.
TQWT trazi vise prostora oko zvucnika sa bocnih strana a ide blize zadnjem zidu. Neverovatan bas kad se dobro uradi. Poprilicno pojednostavljuje skretnicu.
Treca varijanta bi bio hibrid, 3-way umesto 2-way ali sa ovakvim drajverom to bi bio overkill.
IMO je ovo dobitna koncepcija za ovaj drajver. :thumbsup:
Dobro urađen TQWT sa vrhunskim FR drajverima je - penzija.  :worship:
Govorim iz ličnog iskustva ( dodatna sreća jednog audio "penzionera" je i još bar jedan par ESL-57, ako se nema prostora ili finansija za stakovanje istih :Viannen_loungelizard: ).
Membrana 12", a pokretna masa  nekih 12g. Pa to je ekstra tanko, nežno i suptilno. I verovatno isto toliko trajno. Mogu da zamislim one bele membrane kako lagano žute i postaju prašnjave i musave.
Zaebo se on tu nešto definitivno oko Mms, ili tim parametrom smatra samo samu težinu membrane, izmerenu na vagi. Ne postoji teorija da izmereni Mms bude 12gr, pa sve i da je od paus papira, jer u Mms se računa i težina kalema, pola spajdera (jesu konci ali i oni su nešto teški), pola vešanja i sav vazduh koji se nalazi u zamišljenoj zapremini membrane.
A Niksi, piše lepo da je papir tretiran, što se žutenja tiče, ebaga sad :D Nije ti to Lauder :risitas:
Sade im je (opet) moderan onaj koper klad aluminijum za kalem, upravo iz tezinskih razloga, pa je i on lak kao konac.
Ma ko zna šta je radio. Zeznuti su ti washi japanski papiri, lako a nije krhko, još je on to nešto krivio. Kako, ne znam, možda pretpostavljam, a u suštini možda jako prosto... I tako dobio laganu, a snažnu membranu.
Pređe damarom i večno.
Ko što rekoh, ne treba bas helper. Ova numera je opštepoznata i koristi se često u svrhu ovakvih demonstracija. Ali, to je samo jedna numera. Trebalo bi to svakako ozbiljnije testirati i slušati sa različitim muzičkim materijalom. Meni lično bi više značila druga vrsta demonstracije, ovo mi nije bilo sporno.
Izmenjeno od prophet
