NIXIE Napisano Septembar 21, 2018 Share #67 Napisano Septembar 21, 2018 40 minutes ago, mutayu said: Pa sta konkretno predlazes? Ma stavi sve tri diode, nek ide život. Link to comment Podeli na ovim sajtovima More sharing options...
mutayu Napisano Septembar 21, 2018 Autor Share #68 Napisano Septembar 21, 2018 1 hour ago, vladd said: Mislio sam na ovo https://ece.vt.edu/files/undergrad/tutorials/Preventing_Voltage_Regulator_Latch-up.pdf U sustini, isti posao radi dioda paralelna tantalu(ima relativno mali otpornik prema izlazu), uz to stiti tantal koji ne trpi obrtanje polariteta i moze da se zapali od inverznog napona. Pri ukljucenju, iskljucenju, prelaznim pojavama uspostavljanja napona. Jasno mi je zasto ali nije mi jasno kako. Pogledaj na crtezu pa reci 1 ili 2 ili da uradim kako ONSemi predlaze na semi gore, posto po njima obe diode stite Cadj. Sto kaze @NIXIE mogu da stavim i sve tri, imam dioda, ali mislim da je poenta da naucim nesto pa da resavam probleme samostalno. Evo sta kaze ON Semi o diodama na gornjoj semi: Protection Diodes When external capacitors are used with any IC regulator it is sometimes necessary to add protection diodes to prevent the capacitors from discharging through low current points into the regulator. Figure 18 shows the LM317 with the recommended protection diodes for output voltages in excess of 25 V or high capacitance values (CO > 25 mF, CAdj > 10 mF). Diode D1 prevents CO from discharging thru the IC during an input short circuit. Diode D2 protects against capacitor CAdj discharging through the IC during an output short circuit. The combination of diodes D1 and D2 prevents CAdj from discharging through the IC during an input short circuit. Link to comment Podeli na ovim sajtovima More sharing options...
NIXIE Napisano Septembar 21, 2018 Share #69 Napisano Septembar 21, 2018 25 minutes ago, mutayu said: Jasno mi je zasto ali nije mi jasno kako. Pogledaj na crtezu pa reci 1 ili 2 ili da uradim kako ONSemi predlaze na semi gore, posto po njima obe diode stite Cadj. Sto kaze @NIXIE mogu da stavim i sve tri, imam dioda, ali mislim da je poenta da naucim nesto pa da resavam probleme samostalno. Evo sta kaze ON Semi o diodama na gornjoj semi: Protection Diodes When external capacitors are used with any IC regulator it is sometimes necessary to add protection diodes to prevent the capacitors from discharging through low current points into the regulator. Figure 18 shows the LM317 with the recommended protection diodes for output voltages in excess of 25 V or high capacitance values (CO > 25 mF, CAdj > 10 mF). Diode D1 prevents CO from discharging thru the IC during an input short circuit. Diode D2 protects against capacitor CAdj discharging through the IC during an output short circuit. The combination of diodes D1 and D2 prevents CAdj from discharging through the IC during an input short circuit. Ranije sam pravio stabilizatore za pretpojačala sa LM317/337 i uvek sam stavljao one dve diode, onu treću nisam, osim jednom na LM317 za pogon nekog ventilatora. Sve to i dan danas radi koliko znam bez problema. Pošto je preamp u pitanju, nema tu puno verovatnoće da se desi nešto nepredviđeno, ali stavi sve tri diode da ne strada LM slučajno tokom probanja, one dve obavezno, treću po želji. Link to comment Podeli na ovim sajtovima More sharing options...
vladd Napisano Septembar 21, 2018 Share #70 Napisano Septembar 21, 2018 Da to je taj deo price. I to se desava i kada se ulaz kratkospoji, i kada je na izlazu reaktivni potrosac koji moze da vrati veci napon na regulator, pa je izlazni veci od ulaznog. Sto kod tebe nije slucaj, a ako se kratkospoji ulaz, imaces vec skupi kvar sa trafoom, LM manje ili vise.:) Ono sto je na umu je sum mase i desavanja na njoj u prisustvu neg regulatora, a dioda paralelna kondu je prakticno ista kao i na slici 2 samo sto na red ima otpornik 240 oma. Link to comment Podeli na ovim sajtovima More sharing options...
NIXIE Napisano Septembar 21, 2018 Share #71 Napisano Septembar 21, 2018 13 minutes ago, vladd said: Da to je taj deo price. I to se desava i kada se ulaz kratkospoji, i kada je na izlazu reaktivni potrosac koji moze da vrati veci napon na regulator, pa je izlazni veci od ulaznog. Sto kod tebe nije slucaj, a ako se kratkospoji ulaz, imaces vec skupi kvar sa trafoom, LM manje ili vise.:) Ono sto je na umu je sum mase i desavanja na njoj u prisustvu neg regulatora, a dioda paralelna kondu je prakticno ista kao i na slici 2 samo sto na red ima otpornik 240 oma. Nađoh ovo, zanimljiva konstrukcija sa dodatnim mosfetom na izlazu OP. Hajend nije sigurno, a ima phono i line. Zanima me da li stvarno svira bolje kako tvrdi konstuktor nego OP. LM317/337 ima samo jednu diodu. http://www.huennebeck-online.de/diy/pre-1.eng/pre-1.pdf Link to comment Podeli na ovim sajtovima More sharing options...
mutayu Napisano Septembar 21, 2018 Autor Share #72 Napisano Septembar 21, 2018 Dobro, diode su jasne. Sta uciniti da bi se smanjio sum mase? Vidim razna resenja, vezuju GND preko kondenzatora na sasiju, prave plivajucu masu bez direktne veze... Link to comment Podeli na ovim sajtovima More sharing options...
NIXIE Napisano Septembar 21, 2018 Share #73 Napisano Septembar 21, 2018 14 minutes ago, mutayu said: Dobro, diode su jasne. Sta uciniti da bi se smanjio sum mase? Vidim razna resenja, vezuju GND preko kondenzatora na sasiju, prave plivajucu masu bez direktne veze... Može preko 2 ili 4 diode, paralelno otpornik par stotina oma i 0,1uF. Taj 0,1uF je možda sporan, nekad može da izazove oscilacije, kod mene sa tim nema problema, vidi AIKIDO šeme. Kako je sad uzemljeno? Link to comment Podeli na ovim sajtovima More sharing options...
mutayu Napisano Septembar 21, 2018 Autor Share #74 Napisano Septembar 21, 2018 Srednji izvod sa sekundara na plocicu i to bi bilo to. Sasija je samo oklop a napojni kabal nema masu. Link to comment Podeli na ovim sajtovima More sharing options...
NIXIE Napisano Septembar 21, 2018 Share #75 Napisano Septembar 21, 2018 1 hour ago, mutayu said: napojni kabal nema masu Onda verovatno može direktno na šasiju da se uzemlji. Ili da dodaš uzemljenje napojnom pa uzemljiš preko dioda. Link to comment Podeli na ovim sajtovima More sharing options...
vladd Napisano Septembar 21, 2018 Share #76 Napisano Septembar 21, 2018 Pa valjda je to Rus uradio. Sasija na uzemljenje, a masa sa nekim izdizanjem ili ne. Link to comment Podeli na ovim sajtovima More sharing options...
mutayu Napisano Septembar 21, 2018 Autor Share #77 Napisano Septembar 21, 2018 To moze da se proba tokom radova ne zahteva nista posebno. Moram sad da nacrtam plocicu. Dimenzije su otprilike 35x70mm i ima oko 35mm prostora u visinu za kondenzatore i hladnjake. Posle toga ide i finalno resenje RIAA korektora sa semom i plocicom. Link to comment Podeli na ovim sajtovima More sharing options...
NIXIE Napisano Septembar 21, 2018 Share #78 Napisano Septembar 21, 2018 1 hour ago, mutayu said: To moze da se proba tokom radova ne zahteva nista posebno. Moram sad da nacrtam plocicu. Dimenzije su otprilike 35x70mm i ima oko 35mm prostora u visinu za kondenzatore i hladnjake. Posle toga ide i finalno resenje RIAA korektora sa semom i plocicom. Neće ti stati hladnjaci za LM? Link to comment Podeli na ovim sajtovima More sharing options...
mutayu Napisano Septembar 21, 2018 Autor Share #79 Napisano Septembar 21, 2018 18 minutes ago, NIXIE said: Neće ti stati hladnjaci za LM? Stace obavezno, ali bice cupavo! Link to comment Podeli na ovim sajtovima More sharing options...
NIXIE Napisano Septembar 21, 2018 Share #80 Napisano Septembar 21, 2018 25 minutes ago, mutayu said: Stace obavezno, ali bice cupavo! Ako napajanje ne opterećuješ dodatno onda ne trebaju veliki hladnjaci. Ako to ipak hoćeš probaj da montiraš LM na kutiju, to će da ih hladi domaćinski. Link to comment Podeli na ovim sajtovima More sharing options...
vladd Napisano Septembar 21, 2018 Share #81 Napisano Septembar 21, 2018 Bolje da hladnjaci plivaju, nego da se pravi kapacitivna veza sa gnd-om. Link to comment Podeli na ovim sajtovima More sharing options...
mutayu Napisano Septembar 22, 2018 Autor Share #82 Napisano Septembar 22, 2018 "Floating cooler", za neku godinu to ce biti hype u audiophiliji! Link to comment Podeli na ovim sajtovima More sharing options...
vladd Napisano Septembar 22, 2018 Share #83 Napisano Septembar 22, 2018 Pa vec je trebao, poznata su prenosenja impulsa kroz istina mali kapacitet izmedju tranzistora i hladnjaka zasrafljenih na sasiju, prema gnd-u, pa ako nije dobro uzemljenje, suske plivaju po zelji u svim pravcima... Ali tada nastupaju magicne seme, kablovi i trikovi.. Link to comment Podeli na ovim sajtovima More sharing options...
mutayu Napisano Septembar 22, 2018 Autor Share #84 Napisano Septembar 22, 2018 E u ovom slucaju ce hladnjaci biti pinovima zalemljeni na plocicu ali bez veze sa GND... Mozda da izlijem samotne hladnjake? Link to comment Podeli na ovim sajtovima More sharing options...
stojke Napisano Jun 25, 2023 Share #85 Napisano Jun 25, 2023 Želim samo reći da sam kupio ovo predpojačalo i njegovo pojačalo ODA 102. Uz jedan recap sa ozbiljnijim kondezatorima i zamenom ton bord opampa sa 741 jer je neko već menjao, uz zvučnike Iskra OZ-40 u izvornom stanju ova kombinacija "uništava" koliko dobro (Precizno, detaljno, dinamično, *biraj izraz*) radi i ko kaže da to nije Hi Fi , bez uvrede, treba da pređe na slikanje. mutayu, Beli_Ninja, Vix and 2 ostalih je reagovao/la na ovo 1 2 2 Link to comment Podeli na ovim sajtovima More sharing options...
Zen Mod Napisano Jun 25, 2023 Share #86 Napisano Jun 25, 2023 jedna je Iskra mutayu, mileni16, LightMatic and 1 član je reagovao/la na ovo 4 Link to comment Podeli na ovim sajtovima More sharing options...
