DIY-Σ
lukaluka
  • Odgovora 218
A ovo, čini mi se da bi moglo i ovo... http://www.eminence....l=Delta_Pro_15AEmi. Delta15 pro :THIELE & SMALL PARAMETERSResonant Frequency (fs) 42HzDC Resistance (Re) 5.71Coil Inductance (Le) 0.83mHMechanical Q (Qms) 4.73Electromagnetic Q (Qes) 0.44Total Q (Qts) 0.4Compliance Equivalent Volume (Vas) 243.5 liters / 8.6 cu.ft.Peak Diaphragm Displacement Volume (Vd) 368ccMechanical Compliance of Suspension (Cms) 0.24mm/NBL Product (BL) 14.5 T-MDiaphragm Mass Inc. Airload (MMs) 61 gramsEfficiency Bandwidth Product (EBP) 95Maximum Linear Excursion (Xmax) 4.3mmSurface Area of Cone (Sd) 856.3 cm2Maximum Mechanical Limit (Xlim)
Vrlo lepo :)Može i lepo da se namikeri br kutija (dobro, možda malo veća) ali ne bi falilo basa :)
  • 2 nedelje kasnije...
