Putnam—unhappy with the sound of the Altec 604 monitors in his United Western Studios—worked with UREI’s Dean Austin and Dennis Fink on ways to improve the 604. They replaced Altec’s multicell horn with a wider dispersion design and added a 15-inch Eminence woofer to boost LF output. Ed Long applied his Time-Align™ crossover techniques to achieve time- coherent, true point-source performance. Engineers and producers mixing on the system were so enthusiastic about its sound that UREI started producing the monitors as a commercial product, with the first UREI 813 debuting in 1977. Typically soffit-mounted, these large, double-15 monitors were ideal for the larger, higher-SPL control rooms of the time.
Postavljena slika UREI founder Bill Putnam Sr. tests a very early 813 prototype.
Two years later, Altec replaced its Alnico 604-8H with a ferrite model, requiring modifications to the 813 design, including a foam diffraction buffer, crossover mods and small Helmholtz resonators in the horn flare. This 1979 model was the 813A, followed by the 815A (a 604, plus two extra woofers) and the single-driver 811A, but the 813A was far more popular.
Financial and QC problems at Altec led UREI to find a new driver source, now mating PAS coaxial 15 to a JBL 2425 compression driver. The new 813B version debuted in 1983. Later that year, Putnam sold the business to Harman, with UREI becoming a division of JBL Professional; the 813C, a new model with all JBL drivers, launched in 1984. But in its various incarnations, the UREI 813 was the most successful large-format studio monitor ever made.
takodje koristan link :
http://www.audioheritage.org/vbulletin/showthread.php?21472-Great-Plains-Audio-Repair-of-Urei-801
Iz majstor Leonardove kuhinje, sada u seriji 'Red' ('Red' kao 'Crveno' jelte) pristiglo novo ruho za...post-9-098009900 1274531996.jpg post-9-065643200 1274532027.jpgSvetlece Otpornike ! :rofl:post-9-014107900 1274532043.jpgMajstor Leonardo (kao i uvek) uradi i vise no sto neko zamisli! Hvala jos jedared majstore, :rofl:
ma pusti Leonarda - nema on pojma Postavljena slika
rasporedjuj pcbs da vodovi budu sto kraci , i da ti i selektor bude sto blize ulazima
E kad ti budes tako nemao pojma, moci ces da se javis po pitanju heavy metala :rofl:
Do tada, na Lea nema senka da padne, jel' jasno ?! :rofl:
vidim ja - Munze protiv celog sveta , cak i kad ih niko ne dira
...rasporedjuj pcbs da vodovi budu sto kraci , i da ti i selektor bude sto blize ulazima
Cige na kvantas nocu merkaju papriku, spavadu Leskovcani
pored robu pa kad osetu mrdanje vikaju:
- Kogi-mica-tie-dzaci?
- Aaa? Niki-negu-mica-dzaci!
A cige ce
- Uuu bate, ovi sve po japanski, ovi znaju karate, da begamo mi!
E takoj vreme doslo: Zen, begaaaaj! :rofl:
Zamisao jeste da gu turam releji blizo (odma' iza konektori) a zicke na kontakt valja nece smeta da proturim
do prednju plocku? Tako si imam na cevnati uradak ( i to iz Zemun grad! :rofl: ) - zicke vodilje su upredene do selektor.
Bejasmo mi zapoceli temu konstrukcije i GB plocice na selektor al' negde stadosmo, nedovrseto stoji ...
Ne brigaj se Zen, dokle god ti je veličanstveno " Z " na početku imena i dostojanstveno " n " na kraju, svi će morati da te poštuju. Zen, zajeban, Zemun, Zoran ... nema šale. Postavljena slikaPostavljena slika
Dodao bih da je adaptacija prednje ploče bila vruć kesten.
Jedva se ucentrirale ose Vol i Sel. mada može da se podešava sa unutrašnje strane ali ispod prednje ploče. Veri komplikejted.Postavljena slika
Naročito mi se svidelo kako je Dj Nik želeo da se uredi zadnja ploča.
Verujem da će do kraja uspeti da finišira kako treba.
Dodao bih da je adaptacija prednje ploče bila vruć kesten. Jedva se ucentrirale ose Vol i Sel. mada može da se podešava sa unutrašnje strane ali ispod prednje ploče. Veri komplikejted.Postavljena slika
E jesam te namucio, priznavam! Al' pogledaj slozenu zadnju plocu (ovi RCA samo za slikuvanje). PoeziJa. WadiJa (e ne vadim, Bogu mi!) :Viannen_loungelizard:
DakleM:
Z.M. & SP300b uradak onako kako mislim da treba da bude realizovan:
- Balansirani izlazi, voljti sa buffer-om, voljti bez.
- Tri ulaza meni dovoljno: dva balansirana, jedan ne.
- Motorizovani pot, daljinska komanda (Hvala G.K. na razvoju i implementaciji istog)
Eto, nadam se da cu finalizaciju uraditi u skladu sa iznutricom.
PS: malo ce da svajsujemo, tu i tamo :sarcastic_hand:
:buehehe:
ne zaboravi dugacke pecaroske gace - za to svajsovanje Postavljena slika
A to obavezno. Ja sam covek u godinama, to mi je i doktor preporucio! :Viannen_loungelizard:
DakleM:
:buehehe:
Samo napred ...PSMLS CookBook ;-) Postavljena slika
