Windows 7
chakija
Evo, posle par dana nekoliko utisaka...U odnosu na stari XP, ovaj win deluje mnogo zivahnije. Novi grafički interfejs mi se dopada i po meni je praktičan. Sviđa mi se što ima ugrađen disc-burner tako da nema potrebe za programima poput nero-a(koji me inače jako smara) kada je potrebno na brzinu narezati nesto. Stabilnost je veoma dobra-nije se zapucavao do sad a maltretirao sam ga silnim multitaskingima :rofl: . Igram jednu igru na kompjuteru i jedino mi je bitno da ona dobro radi wc3-DotA . Mnogi se hvale kako im igrice mnogo bolje rede na win7 nego na xp-u .Uz malo promene prioriteta u task menageru i to je proradilo ko san. Sve u svemu, kad se uzmu u obzir prednosti i mane, ovaj win deluje kao zaokruzen sistem, po meni dosta bolji od xp-a. Igrom slučaja je mom xp-u trebala reinstalacija(pojeo sam sebe posle godinu i po) i drago mi je da sam probao ovaj windows umesto standardne xp-SP2.Moram se doduse ograditi u neku ruku jer sam stavio novi sata disk umesto starog i to je sigurno doprinelo boljitku performansi.
  • Odgovora 107
Evo za chakija :to_become_senile:Chuck Norris can walk on Fissure.Chuck Norris absorbs Finger of Death and shoots it out through his big toe.Chuck Norris has a 100 % chance for multicast. With Aghanims its 200 %.Chuck Norris can stop Reincarnation by ripping the cross out of the ground and snapping it in half.Chuck Norris doesn't have Doom. He has Dead!!Chuck Norris makes his own Sentry wards out of grass, twigs, and index fingers. They have 12000 sight and can see into the next game.Chuck Norris is the reason why Pudge has three arms.Chuck Norris is the reason why Leshracs Soul is so Tourmented.Chuck Norris is neither Hero, Creep nor Ancient.When Chuck Norris uses BKB he stays the same.Attacking a unit with Frost Armor makes Chuck Norris move faster.Chuck Norris can use Helm of the dominator on Enemy HerosChuck Norris doesn't visit the Secret Shop. The Secret Shop comes to him.Chuck Norris comes with a Dagon 50 every game.Chuck Norris can catch Tinkers Missiles and throw them back.Chuck Norris gives Atropos Nightmares.Chuck Norris can outrun Deathpulse and make it hit Necrolyte instead.Chuck Norris can re-use Consumables.Chuck Norris doesn't Timewalk. He is already there.Chuck Norris is NOT an orb effectChuck Norris' power treads stack with boots of travel.Chuck Norris can dominate Roshan.Chuck Norris made Tiny tiny.Backdooring was outlawed after Chuck Norris repeatedly destroyed opponents healing fountains.In older versions of DotA, Chuck Norris farmed wood.Chuck Norris can break heroes bones, permanently slowing them and reducing their attack speed.All images run away from Chuck Norris.Invisibility stacks on Chuck Norris.Chuck Norris demanded that he be a hero in DotA. Icefrog turned him down, meaning that if Norris became a hero, its power would constantly cause the game to crash due to the overload. Icefrog is the only living creature who lived to tell the tale of the day he talked back at Chuck Norris.6 divine rapiers gives you the Chuck Norris Orb.Buriza is the name of Chuck Norris' hamster.Chuck Norris gangs alone.A public player who once called Chuck Norris a n00b was found dead the next morning, his screen had smashed his face in.Chuck Norris is immune to your banlist.Chuck Norris has 7 slots.Chuck Norris shops in the opponents base.Chuck Norris doesn't need WTF mode.Chuck Norris is safelisted everywhere automatically, bots do not wish to make enemies with him.Chuck Norris' refresher orbs refresh themselves.If you leave Chuck Norris' game, you won't play DotA... ever again.Chuck Norris can win DotA alone, without picking a heroChuck Norris can posess enemy's courier without them knowing. range is set to total map.Chuck Norris can alternate his collision size, from lane blocking to zero collision.Treant's forest watcher eye's will shut down at the sight of chuck norris. Weaver's shade's will turn visible due to fear! Wards are said to change position and hide in forests.Chuck Norris once threw his sacred relic away. It's damage bonus was not enough.Chuck Norris is the only one permitted to use godmode, as there is no known command to make him vulnerable!Ultimate orb turns blue when in chuck norris' hands.Chuck Norris can manipulate blinkdaggers, being able to reverse enemies blinkdirection. This way he doesn't need to chase down or throw trees as enemies will pop up right next to him.Ironwood branch gives +100 stats to him. They also stack in his inventory to a total amount of unknown size.Chuck Norris' blademails will work on ranged opponents to.Chuck Norris can autospawn power ups.Chuck Norris can hit tree/throne without killig towers.Chuck Norris gets gold from each dying creep, even without last-hitting them.Chuck Norris' splash damage effects the whole map, thats why he always has ateam kill when creeping gnolls in the jungle.Chuck Norris' bottle is always full.If cast on Chuck Norris, rhasta's ulti-wards attack rhasta for being blasphemic.Chuck Norris' inhuman powers drop on death, giving the player who picks 'em up a permanent aegis aura. Too bad he never dies... ever.Chuck Norris' Tangos dont eat trees, they eat woods.Chuck Norris can't use the Necronomicons, they would run away in fear!Chuck Norris can deflect a Laguna Blade on an enemy with his fist!Someone maphacked on Chuck Norris. His body was never found.Chuck Norris can dodge assassinate!Putting a Blink Dagger on Chuck Norris is like putting wheels on a bullet.Chuck Norris has a 1-hour Chronosphere with 12000 AOE.Chuck Norris leeches with spell damage.Chuck Norris base MS ist 521.Chuck Norris has a blink with 0 sec cd and 12000 range.Illusions of Chuck Norris deal 100% dam.Chuck Norris can pick a hero in -ar mode.Chuck Norris gains gold if the fountain kills a creep.Chuck Norris gains +50 to all stats every lvlup.Chuck Norris hates Rikmaru. If he manages to get to lvl 6 before Chuck Norris hunts him down, he has a slight chance to escape from him. Too bad Chuck Norris has truesight.Chuck Norris pulls Pugde next to him if he gets hooked.Every time you get double damage Chuck Norris gets triple armor.Every Hit Chuck Norris does is a lasthit.Chuck Norris has 100% Evasion.Chuck Norris can use all Spells with one hotkey.Chuck Norris gets quantity discount at the secret shop.After GODLIKE only comes CHUCKLIKE with an amount of 100 kills in a row.Chuck Norris doesen't need boots of travel. If he wants to be somewhere every enemy unit at that place just teleports to him.If Chuck Norris types -di and hits enter Warcraft III will throw an exception anytime cause the amount of kills doesen't fit into integer value anymore.Chuck Norris uses Lone Druids' bear only as Chicken.Chuck Norris doesen't need Banlist. No one will leave until Chuck Norris allows him to leave - even if game is over.
  • 6 months later...
Vako, sa distance... RC (Evaluation Copy) me je obavestio da imam još 13, potom 12 dana... Ok, rekoh, fair enough, i odoh do omiljenog mi distributera hardvera gde sam bezecovao OEM izvedbu sedmice. Sve do sada pozitivno izrečeno i dalje stoji i za razliku od svih windowsa koje sam do sada probao, ovaj je prvi kojemu ne mogu naći ni jednu ozbiljnu zamerku. Dok sam čekao da mala odradi trening, prošao sam kroz članak o 35 laptop računara sa preinstaliranim win7 testiranih uporedno, i ni na jednom win7 nije bio najslabija karika. Konačno! :buehehe:
Ja jos uvek koristim Windows 3.1. Pretpostavljam da vecina vas nije uspela jos da ga upozna.
He, he... pa Windows 3.11 for workgroups nije čak ni operativni sistem. Ja sam ga koristio kada sam imao procesor na 16MHz, sa 1MB RAM-a i HDD od 20MB! Taj računar nije čak ni imao matematički ko-procesor! (286) a da ni ne spominjem Hercules monitor, žuto-crno.... Praistorija...Inače, koga zanima koliko je potrebno za win7...Već dve godine sam na integruši Foxconn/AMD690G sa AM2 gde je zaboden AMD LE1600 (2.2GHz) + 2G DDR2/800MHz, sistem je na 5400RPM 2.5" Hitachi HDD/160G, a juče sam se proširio sa drugim externim 500G HDD, ovaj put Toshiba. U mašini je još i 3.5" WD od 500G pa to čini malo više od 1.5TB prostora za lagerovanje (uz već postojeći 500G externi Fujitsu). Inače, pošto je sistem na malom hardu, ostali se ni ne vrte (za to je zaslužan i win7) dok se ne zahteva neki podatak sa nekog od njih pa je za hlađenje procesora zadužen pasivni deo Cooler Masterovog Gemini IIs... Dakle, hardverski gledano, ne treba ništa posebno novo ili specijalno a ni jednom do sada nisam primetio da bi mi mašina sporije radila nego sa XP ili nekom od Linux distribucija. Koliko cenim, najsporija karika je sada hard disk, ali dok cene ovih novih ne dođu na razumniji i prihvatljiviji nivo...
A za DOS? Imam sve to tu negde, plaši me čega sve nema... Naravno, i moj favourite: Desqview... 5.25" diskete, naravno... Joj, jednom, kada budem uzeo da čistim, biće to tsunami...
Postoji teorija da su dinosaurusi izumrli od meteorita koji je pogodio zemlju, onda, druga teorija da su izumrli zbog klimatskih promena, ali kako ja vidim, nisu oni ni izumrli... :buehehe:
Vredelo bi pomenuti dsa se neko ne predje...Na mojoj masini imam instaliran W7 32 bit, na posebnom disku W7 64 bit, RAID diskove i poseban hot swappable disk - svi SATA drives. Na ovom hot swappable disku sam pokusao da instaliram XP (pokusavao sam i na drugim diskovima) tako da imam mogucnost da startujem bilo koji system. To je bar ideja bila, sta cu ne mogu da se oslobodim Mac analogije, jer sam prvenstveno na Mac-u, PC koristim samo za audio programe. Nazalost to nije moguce sa W7, koji absolutno ne prepoznaje starije systeme i na neki nacin to izbrise iz BIOSA. Tako da ukoliko pokusavate isto, budite obazrivi jer necete lako moci da se vratite na svoj stari disk ukoliko Vam je to plan.Ukoliko ste imali vec taj problem, i ako imate workaround, voleo bih da cujem jer mi se ne svidja da run XP preko virtualne masine, a sta Microsoft nudi kao varijantu za podrsku starog sytema.
Napomena: Win7 nisam, još, video, osim na TV... Dakle, nemam ličnog iskustva oko toga. Dal' radi il' ne radi, navedeno na stranici gore, nemam pojma... Pošto sam pročitao šta piše, sudeći na osnovu diskusija na Ubuntu forum-ima, ima smisla i ne vidim neku veću mogućnost zabalabućkivanja... No, M$ nikada ne spava... Za vreme dovoljno za dve do tri install-acije Ubuntu-a, sa sve prilagođavanjem mojim željama, dansa sam uradio ciklični upgrade i čišćenje Vista-e, u koju, inače, ne ulazim već godinama, osim u tu svrhu. Dakle, 2.5 sata i još preko toga, bačeno... No, to mi je navika, kao bajagi safety net, iako je dovoljan LiveCd, al' 'ajde... Tu mi je backup i slično, za ne daj Bože. Naravno, nije samo tu... Veoma je blizu dan kada više neću imati M$ particiju odvojenu ni za tu svrhu... No, kao što, još, imam i diskete, tako imam i M$ particiju...
instalirao sam na 2 racunara pomenuti win. posto bejahu starije ploce bese i problema sa zvukom ali nadjoh drivere negde po netu i racunari lepo rade. sta ti ja znam? windows k'o windows. skacu mi neki programi tamo, iskacu mi pozadine i plasim se ja toga. da li radi stabilno? e to vec ne znam. nisam dugo radio na pomenutim masinama. imam jednu zamerku sto battlefield heroes ne radi lepo na win7
Ua preletači... No, neću ovo pominjati na UFSR...
