zerowaf Napisano April 20, 2021 Autor Share #67 Napisano April 20, 2021 Volumio mi je na USB-u, a na HDD imam ca 1,5 TB muzike u raznim formatima. Ako ne moze naci HDD onda, na zalost, meni Volumio ne igra. A kako da ga instaliram sa HDD? Ne znam. Cuo sam za rijeci poput "particija", "boot" i sigurno jos neku koje se ne sjetih sada, ali to je znak da za mene nije nesto sto cu raditi danima da bih na kraju odustao. Ja sam neandertalac za PC. Na zalost, Volumio ovakav kakav je kod mene nije za mene ovakvog kakav jesam. Hvala svima na trudu i iskreno mi je zao sto sam nekoga razocarao, a ulozio je trud, dobru volju i vrijeme da mi pomogne. Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano April 20, 2021 Share #68 Napisano April 20, 2021 Polako, sredićemo... Evo ja ću da podignem i da probam sa nekim komandama... Ovo za share foldera mislim da je potrebno kad se pristupa preko mreže. Za lokalni disk bi trebalo biti drugačije. Naravno, Volumio možeš da spustiš i na HDD, ali gubiš sve podatke: Quote NOTE: you will loose ALL the data on your HDD. - Flash Volumio 2 to a usb stick - Format another usb stick wit FAT32, and copy the unzipped downloaded x86 image to it. - Then boot from your usb volumio 2 stick. - Will until the UI is showing, the press ctrl-alt-F1 to open a terminal session - Log in with volumio/volumio - Type Code: Select all sudo blkid and check the output. - You should see /dev/sda, /dev/sdb and /dev/sdc (presuming you only have one disk in your x86 pc) The device with the labels "volumioboot", "volumioimg" and "volumiodata" is the one you booted from. The device with the single vfat partition is the stick with the volumio image, assume it is /dev/sdX (X being a, b, c...) The other device is your netbook's hdd, assume it is /dev/sdY (Y being a, b, c...) - When sure about the devices, type Code: Select all mkdir usb sudo mount /dev/sdX1 usb cd usb ls -l sudo dd if=fullnameofthevolumioimage of=/dev/sdY bs=4M sync cd .. sudo umount usb sudo rm -r usb poweroff - remove the usb sticks, reboot et voila zerowaf je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #69 Napisano April 20, 2021 Ljudi, cijenim vaš trud više nego što znam pokazati. Stid me je samo zato što se brinem da se uzalud trudite. Ja sam stvarno IT neandertalac i ne znam koliko mogu naći vremena da pohvatam sve što trebam da uradim da ovo proradi. Za računala i još masu toga sam, ma najbolja usporedba koja mi pada na pamet je, ja sam kao žena koja ima vozačku dozvolu, ali ne zna kako se toči gorivo u auto, a kamoli što sve ima pod haubom ili kako provjeriti tlak u gumama. Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano April 20, 2021 Share #70 Napisano April 20, 2021 Ama mora čitati lokalni disk. To je kao kad namestaš brisač stakla na vlaku zerowaf and Nesic je reagovao/la na ovo 1 1 Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano April 20, 2021 Share #71 Napisano April 20, 2021 Da se izlistaju svi diskovi koristi se komanda lsblk Onda mora da napraviš putanju za HDD tipa sudo mkdir /mnt/Muzika disk od 931GB je Muzika i Filmovi nemož da promašiš veličinu onda ideš sudo mount /dev/sdb1 /mnt/Muzika kod mene je sdb1 kod tebe možee biti i nešto drugo gledaš gde je 1T onda ideš ln -s /mnt/Muzika /var/lib/mpd/music/Muzika pa mpc update prosto ko pasulj Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #72 Napisano April 20, 2021 pre 11 minuta, Mikorist reče Da se izlistaju svi diskovi koristi se komanda lsblk Onda mora da napraviš putanju za HDD tipa sudo mkdir /mnt/Muzika disk od 931GB je Muzika i Filmovi nemož da promašiš veličinu onda ideš sudo mount /dev/sdb1 /mnt/Muzika kod mene je sdb1 kod tebe možee biti i nešto drugo gledaš gde je 1T onda ideš ln -s /mnt/Muzika /var/lib/mpd/music/Muzika pa mpc update prosto ko pasulj Hvala Mika! Nego, ja nemam pojma što da radim s tim! Zamisli da si pračovjeku dao mikrovalnu, kabel, utičnicu, frižider i u njemu konzerviranu unaprijed pripremljenu hranu. Pogledao bi u to, pa u tebe, slegnuo ramenima, uzeo močugu i otišao tražiti sabljastog zeca. Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano April 20, 2021 Share #73 Napisano April 20, 2021 samo ti nađi terminal na tom Volumio - ostalo ćemo lakho Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano April 20, 2021 Share #74 Napisano April 20, 2021 to ga buni ctrl + alt + F1 volumio/volumio --- Will until the UI is showing, the press ctrl-alt-F1 to open a terminal session - Log in with volumio/volumio --- prati Mikine korake... Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano April 20, 2021 Share #75 Napisano April 20, 2021 hmmmm... meni javlja read only. ntfs particija... možda treba "sudo apt install ntfs-3g" Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #76 Napisano April 20, 2021 Okay. Slika 1: Pobjegao sam glavom bez obzira od toga. Slika 2: Poslusao sam savjet i ukucao ctrl+alt+F1 i dobio ovo na slici. Zapravo sam prvo ukucao "lsblk" i stisnuo "Enter" Nakon toga me trazio to sto se vidi. Na zalost, ne da mi pisati, tj. kad pisem nema slova da se vide. Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano April 20, 2021 Share #77 Napisano April 20, 2021 na tom crnom prozoru kucaš volumio/volumio kad dobiješ volumio@volumio :~$ onda tek kucaš one komande Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #78 Napisano April 20, 2021 pre 8 minuta, Mikorist reče na tom crnom prozoru kucaš volumio/volumio kad dobiješ volumio@volumio :~$ onda tek kucaš pone komande A kako dobijem kosu crtu na tipkovnici???? EDIT: Na numerickoj tipkovnici "podjeljeno". Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano April 20, 2021 Share #79 Napisano April 20, 2021 Upravo sada, zerowaf reče A kako dobijem kosu crtu na tipkovnici???? ne treba ti kosa crta username = volumio password = volumio Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #80 Napisano April 20, 2021 pre 5 minuta, Mikorist reče ne treba ti kosa crta username = volumio password = volumio Vjeruj mi da sam prasnuo u smijeh. Nema sto nisam istipkao jer sam vidio "volumio/volumio". Okay. Dobio sam logotip na crnom ekranu. Znaci sad ide "lsblk"? Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano April 20, 2021 Share #81 Napisano April 20, 2021 aha Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #82 Napisano April 20, 2021 pre 5 minuta, Mikorist reče aha Link to comment Podeli na ovim sajtovima More sharing options...
vinko Napisano April 20, 2021 Share #83 Napisano April 20, 2021 Cekajte ljudi Zero, aman snimi na volumio usb 3 pesme koje ti prave problem. ovde cilj da vidis gde je problem dal gw ili sw Nemoj odma mountovanje to ako zelis posle samo linux Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #84 Napisano April 20, 2021 Kad sam dosao dovdje ide Linux! Sad je valjda lakse dodati put do hard diska nego traziti jos jedan USB, kojeg nemam, kopirati fajlove i ispocetka dizati Volumio, pa onda opet zapeti jer, kakve sam srece, nece htjeti sam naci gdje su pjesme. Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #85 Napisano April 20, 2021 Pre sat vremena, Mikorist reče Da se izlistaju svi diskovi koristi se komanda lsblk Onda mora da napraviš putanju za HDD tipa sudo mkdir /mnt/Muzika disk od 931GB je Muzika i Filmovi nemož da promašiš veličinu onda ideš sudo mount /dev/sdb1 /mnt/Muzika kod mene je sdb1 kod tebe možee biti i nešto drugo gledaš gde je 1T onda ideš ln -s /mnt/Muzika /var/lib/mpd/music/Muzika pa mpc update prosto ko pasulj Znaci sad ide ovo? Tim redom i sa tim razmacima? Osim sto je kod mene SDA5 taj sa najvise prostora, pa je u njemu i sva muzika? Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #86 Napisano April 20, 2021 Idem se izranjavati.... Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano April 20, 2021 Autor Share #87 Napisano April 20, 2021 Zapravo...idem pronaci masan strik i odoh u sljivik.... Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano April 20, 2021 Share #88 Napisano April 20, 2021 meni ne prolazi mpc update ni sa sudo kaže da je mreža nedostupna Link to comment Podeli na ovim sajtovima More sharing options...
