prophet
Sve objavljeno od prophet
  1. Pogledaj nešto iz car audio segmenta. https://www.kupujemprodajem.com/search.php?action=list&return_url=&data%5Btip_oglasa%5D=all&data%5Bcategory_id%5D=1251&data%5Bgroup_id%5D=533&data%5Blocation_id%5D=&data%5Bcondition%5D=&data%5Bperiod%5D=&data%5Border%5D=&data%5Bkeywords%5D=&submit%5Bsearch%5D=Tra%C5%BEi U kombinaciji sa: https://www.kupujemprodajem.com/Behringer-MicroMix-MX-400-10873951-oglas.htm?filter_id=7343869 Za zvučnike ima ovakva varijanta, stereo, kompaktna sa 10" full range drajverima (mada na slici deluje da ima i visokotonac): https://www.kupujemprodajem.com/Pi-Vi-mini-monitor-zvucne-kutije-8616459-oglas.htm?filter_id=122 Ili pogledati neki stage monitor.
  2. prophet
    USB DSD dac
    Ovo podseća na: - Opet mi se ide u New York - Bio si u NY? - Ne, ali i juče mi se išlo.
  3. 12 godina ropstva - jako težak film.
  4. Jel ima ventilator ili nema?
  5. prophet
    Act Audio?
    http://www.hi-files.com/forum/index.php?/topic/25429-pomoc/
  6. Ovako se to radi: https://www.youtube.com/watch?v=flC---s2moA#t=0
  7. Morris Kessler je bio dizajner pre Bongiorno-a. Citat: "Above is a Mark 23 amplifier. This is a very rare amp. Personally designed by Morris Kessler, this amp was rated for 300 watts and was intended for professional use. However, it had stability issues and was cancelled after a short production run when James Bongiorno was hired on as Director of Engineering. "
  8. James Bongiorno je došao u firmu posle ili baš sa ovom serijom. Prethodna serija je bila jako nepouzdana, ne znam da li se to odnosi i na ovaj model. Što se elektrolita tiče mislim da znam gde bi mogao da nađeš. Samo pre toga uradi ono što ti je ZZZ rekao.
  9. Još da čujemo uređaj koji će zvučno nadmašiti cenu samog čipa i super.
  10. Stereo Ja ću 4, za celu porodicu.
  11. prophet
    Amp Camp
    Šteta
  12. Suba aka Rex Ilusivii - Satie (demo tape 1987) (longer version of "Thanx Mr. Rorschach") https://www.youtube.com/watch?v=hK6oPFMBN9I
  13. prophet
    Amp Camp
    Napravi mono blokove.
  14. prophet
    Amp Camp
    Ja bih stavio trafo na trafo a kondove na mesto drugog trafoa, ako visina hladnjaka dozvoljava.
  15. Interesantna saradnja Pass i Sony povodom 40 godina V-fet: http://blog.sony.com/press/sony-demonstrates-pass-laboratories-40th-anniversary-commemorative-vfet-amplifier/ Sony’s VFET devices, also known as Static Induction Transistors (SIT), were smaller, less costly and much more efficient than conventional vacuum tube designs and were widely acknowledged for their “Triode-like” sound quality. Additionally, these transistors serve as extremely fast switching devices, which enabled Sony to introduce the first high-powered Class D audio amplifier in 1976. This exclusive Pass Laboratories commemorative amplifier employs complementary matched pairs (2SK82 and 2SJ28) of Sony VFETs, which were in storage for nearly 40 years. The mono block amp operates in Class A mode, with a balanced circuit from input to output and no feedback required. The amplifier also includes a highly regulated stable power supply, which enables it to achieve 250 watts peak power into a 4 ohm load, with relatively low distortion (less than 2%).
  16. Sa Ninjinog linka:
  17. Ninja postoji li način da saznaš čime je ovo lakirano: http://i1285.photobucket.com/albums/a585/krille1981/Diverse%20bilder/Cool%20speaker%20systems/IMG_0517_zpsa9eb050e.jpg
  18. Nešto manje komponente po dimenzijama:
  19. Jel to preamp ili volume kontrola?
  20. Jedan basić ti je par db osetljiviji. Mada izmeri sam spl. Izgleda i kao da su dva različita para, sudeći po mms. Izgleda da je to posledica starog vešanja na tom jednom, ima manji cms. takođe ima i manju induktivnost kalema. Biće to dobri zvučnici.
  21. prophet
    Ikea Expedit
    Isti takav kao tvoj moj sin probušio flašicom za vodu. Unutra kartončići.
  22. History of Talkbox, Vocoder, and Autotune I jedan zanimljiv intervju sa Framptonom:
  23. prophet
    Ikea Expedit
    Pa napravi lepšu.
  • Trenutno na sajtu   1 član, 0 Skrivenih, 315 Gosta (Pogledaj celu listu)
    452.8k
