prophet
Sve objavljeno od prophet
  1. The DRD (direct reactance drive) isn't a new concept. The Welborne DRD design is actually a derivation of an old Loftin-White direct coupled design. Granted, Jack Elliano of Electroprint and Ron have made some adaptations, but the basic design concept is still in tact. The DRD concept is to directly couple the driver tube to the output tube. The Terraplane is the same basic design as the DRD with a few notable upgrades. Ron has (almost) completely redesigned the power supply adding more filtration for an even lower noise floor. He's also eliminated many of the electrolytics within the amplifier. As you can see from the schematic, there is exactly one passive component in the signal path, one resistor on the input. After that, there are just two tubes (the driver and output tubes), then Jacks custom wound output transformer. This is about as close to straight wire as you can get in an amplifier. Koji su benefiti odvojenog napajanja?
  2. Potrebno je da bude u formi mono bloka. Meni na pamet padaju ove dve varijante: http://www.diyhifisupply.com/opcart/index.php?route=product/product&path=192&product_id=521 i http://www.enjoythemusic.com/magazine/equipment/0206/welborne_laboratories_300b.htm u Terraplane izvedbi.
  3. Svaki komentar je dobrodošao, sa tvoje strane pogotovo. Šaljem pp.
  4. Ozbiljni smo ljudi Samo sam pratio tvoje upute
  5. prophet
    Prigušnice
    Evo i preciznih merenja:
  6. Evo ih u predmetnim kabinetima: http://www.ebay.com/itm/pristine-pair-of-1948-RCA-LC-5A-studio-broadcast-monitors-MI-11406-MI-11411-LC1A-/181365978767?pt=Vintage_Electronics_R2&hash=item2a3a41368f&nma=true&si=aoTvG8PxUXfkonk%252BN39F5M8Z%252Bt0%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
  7. Ceo kombo znatno više od toga. Mislim da vredi pogotovo u ovakvom stanju. Nisam video ovako dobro očuvan uređaj. Glava je nova, sleduje detaljna provera. Ovako na oko se vidi da nije korišćena.Sve u originalnom pakovanju.
  8. Technics SL-10: Ortofon MCP-100 Super NOS: (Thanx Guja).
  9. Nisu za poređenje.
  10. Ja bih se vratio po te kabinete. Za stambeni prostor mi deluje kao moguće najbolje rešenje. Jesi li bio u prilici da ih čuješ u tim kabinetima? Da ne pričam da u originalnim kabinetima imaju dvostruko veću vrednost ako si ispratio aukcije na ebay-u.
  11. Uh bog te, trebao si. Koji su kabineti, podni ili zidni?
  12. Super. Jesu li bili u nekim kabinetima?
  13. WOW Jesu li grbe originalne? Po slici ne bih rekao da jesu.
  14. Vodite računa sa debljinom tih ploča, ona koju vode da je 24mm je u stvari oko 22mm.
  15. Dobro radi Bujodragov lepak a i dobru je masinu napravio.
  16. Steta sto je srebrna verzija Japan only. Disc dugme je za gramofon.
  17. Da, SL10.
  18. Sve poznato. Imam tri ALPS Black radjena na paladijumu i srebru u sistemu kao i ELMA selektor. Poenta je otici iznad HK medijale. Svaki od predlozenih svira bolje od toga. Preporuka za Crescendo je delom i zbog univerzalnosti, upotrebe sa sirokom paletom konvencionalnih kutija. Zasto prepravljati uredjaj kad se moze napraviti bolji i pritom mu umanjiti trzisnu vrednost?
  19. Kako vam izgleda ova MC:
  20. Nemoj dirati fabricki uredjaj. Napravi novi prodaj stari.
  21. Crescendo nije los izbor.
  22. Za pocetak AK nije najbolji izbor.
  23. Valjda ce u novom veku izmisliti nesto bolje...
  • Trenutno na sajtu   0 članova, 2 Skrivenih, 313 Gosta (Pogledaj celu listu)
    452.8k
