guja011
Sve objavljeno od guja011
  1. pokušaj da izbegneš te 2 šeme sa e-laba. što se tiče benč napajanja, pošto nije fifi napajanje, onda ti i neka buka nije bitna, sačuvaj pasivne hladnjake za nešto pametnije tj tiše a benč napravi sa "duvanim" hladnjakom/hladnjacima.
  2. komplikuješ, reko ja. da tebi popis pa komu treba pita tebe na pp. ti onda znaš ko je valjator a ko nije. ako treba taj uslov da se ispuni. aapropo zakeranja, jel bi ti pazario duška lokina ili slično?
  3. ideja je ok, ali 2 kutije ploča i ne znači puno. nadje se i ovde ponekad preprodavac, kako će on da ga prepozna? imho: prekomplikovano.
  4. da je taka filozofija koju pominješ, ne bi bilo ovoliko pokojnika
  5. zavisi za koji A, ima ih više
  6. taj toj primer izduva nije prazan. primer oblika možda
  7. ma ti si u nedoumici. more prslo zarad gramofona, sad je i izduv problem. moraćeš da definišeš prioritete
  8. au, ludilo. http://www.thevintageknob.org/tvk_talk/viewtopic.php?f=1477&t=2395
  9. otkad je roland rotel? edit: prosvetljenje: Rotel was originally called Roland Electronics until around 1971 when they made a push to expand worldwide—they realised they couldn't trademark the Roland name overseas, so they changed it to Rotel. They never had anything to do with Roland DG. Most sources online (including Rotel themselves) will tell you that Tachikowa-san founded the company in the 60's, but it goes back further, to the 50's when he was the Japanese distributor and assembler for Sylvania TV equipment. It merely became an audio company in the early 60's, when he won over the Americans with his efficient, reliable, competent operation and started OEMing on contract for Scott, Marantz, Harman Kardon and other American brands, growing the OEM business throughout the 60s and 70s. The company only started making its own Rotel-branded products in the late 60s. What makes Rotel rather unique is its UK connection, initially with that odd British conglomerate, the Rank Organisation. Rank distributed Rotel gear and Rotel manufactured gear for their Leak and Wharfedale brands. By the late 70's/80's Rotel had UK co-headquarters with English designers designing Rotel components in a more Occidental fashion with the focus on strong power supplies, simple signal paths, etc, and that's the Rotel that we know today (which Alex Encel has had so much success with in Australia.) Although it's easy to ignore Rotel because of its general focus on simple, good-value equipment, it's actually a rather unique company, becoming a kind of Anglo-Japanese hybrid over the years. From the outside it looks like they made a lot of good business decisions. And you could call it one of the few intact survivors of the 20th century Japanese audio story—although B&W owns it, Bob Tachikowa, heir to the throne, still runs the company from its Tokyo and UK HQs.
  10. na putlokeru serija ko blata. ima i svitac, naravno. posle Merlina, naravoučenije: odabereš neku epizodu pred kraj pa protrčiš. ako čemu valja-valja. ako ne, skipuješ celu seriju.
  11. ima i ova http://www.diyaudio.com/forums/attachments/digital-source/250008d1321635358-meridian-207-tilt-error-board-back.jpg
  12. ja juče nabaso na jednu temu na velikom DIYA gde se neki lik žalio da mu treba pcb od serva a drugi okačio slike čime raspolaže, tu sam vido. valjda ću opet iskopam. edit, ovo sam mislio http://www.diyaudio.com/forums/attachments/parts/271145d1331462568-wtb-meridian-207b-bottom-board-meridian-207-parts.jpg
  13. prvo ti uradi napajanje. ploče ti imaju svoju stabilizaciju, kako je rečeno, samo trafo, grečevi i par elektrolita ti treba. slike šta je iza transporta, imaš na netu - toruščić i jedna štampa ispravljanja.
  14. a štaće ti šema? teo sam da kažem, bitniji su ti rasporedi na konektorima...
  15. neka navala kumova koji imaju sve i svašta
  16. da, stabilizatorima je sigurna zaliha bar 3 volta iznad izabranog izlaza, meridian nisam imao na autopsiji pa ne znam koliko sekundara trafo ima, ali ne verujem da je sve izvučeno iz 2 sekundara, to bi bilo cicijašenje preko svake mere, trebalo bi negde naći šemu mrežne sekcije
  17. ne grešiš, priča kaže da je na gornjoj ploči sa analognom buranijom, ali obe ploče traže sirov ispravljen napon a imaju svoju stabilizaciju. znači ona trula digitalija prosledjuje +5v na gornju ploču a gornja ima svoj konektor za +/- sirovi napon. znači 2 ploče u kompletu = 3 napona potrebna
  18. ne verujem da su stabilizatori na ladnjacima zarad ogromne struje već pre zbog velikog ulaznog napona(pa je na njima pad napona), možda je baš i bilo 12 volti. kakogod, od one 3 linije koje si napomenuo, treća je prolazna tj sa konektora na konektor, možda nešto za napajanje samog transporta itd. na ploči imaju ta 2 elektrolita ali nisam zagledao dal je onaj veliki za 5voltne stabilizatore ili za prolaznu liniju a onaj manji za stabilizatore, to se da upratiti. analogna ploča ima +/-stabilizaciju, nešto tipa lm317/337 to ukazuju oni otpornici izmedju njih, i ima filtracione elektrolite, tu treba znači +/- sirov ispravljen napon. fino je ako imaš razna napajanja za laptopove, ali je ovde dovoljan trafo i grec
  19. to na ladnjacima su stabilizatori za +5 volti, oba imaju paralelno vezan ulaz, tu ti ide jedan dc napon na ulazu, od 9 ili 10 do 12 volti, i to je napajanje za digitaliju, jer tih 5 volti izlazi i na druge konektore. pločica sa puno sitnih delića ima svoju filtraciju i stabilizatore, koji su bez hladnjaka, pa ih ne uočavaš. zajedničko za obe pločice je što se nešto ne vide diode ispravljača, to je verovatno u originalu na nekoj pcb uz trafo
  20. da, taki bi baš bio zgodan na izvolte u trgovačkoj da se drži..
  21. baš ti i nije zrikav izduv ko ovaj kod sax-a. a i ne umeš da spičiš ok šrafove kroz tablicu.
  22. u , nije ti loša ideja. razvalim trafe pa okačim ovde u oglase, što plekane što livene dekle. taman za morski džeparac da se dopuni
  23. snake oil se odnosi na utjecaj trafoa u ravni a ne na poklopce. nisam ja ništa nudio, okačio sam link reference dranja radi a neskorov je još bolji, naravno, mada mi ti poklopci deluju hamondastije tj izduženo. kakogod, cena na komad je uvek velika, za nekoliko parova i dobac se deli sa tim brojem pa je podnošljivije. što se tiče Melektronika, bio sam u prilici da radim sa njima i naravno da je sasvim druga priča kada se tamo pojaviš u odnosu na mailovanje ili telefoniranje.
  • Trenutno na sajtu   2 članova, 1 Skrivenih, 211 Gosta (Pogledaj celu listu)
    453.6k
