BANAT
Sve objavljeno od BANAT
  1. Beli_Ninja + Girl of White Ninja Woland Ninja (ljeto) Zvu (ako nije preblizu ispitnih rokova ) Zerowaf (ako me ne ubije struja i ako do tada uspijem rješiti tekuće probleme) Banat
  2. Ovo je originalan Ralph-ov text preuzet sa Audio Asylum sajta koji se tice implementacije Atmasphere M60 OTL Amp-a na Westrex masinu za rezanje vinilskih ploca : `` Those of you who have been watching the blog on our website may have noticed that we mentioned using a set of M-60s for LP mastering with our mastering lathe. I thought I would post this for those interested. We chose a Westerx cutterhead, as it has a nominal 10 ohm impedance and the stock transistor cutteramps for it only make 125 watts. So it seemed like we would have no worries with a set of MA-1s to drive it. However saying that the cutterhead is 10 ohms really glosses over the subject. It starts on the low end at about 8 ohms, has a peak of impedance due to mechanical resonance in the midrange, then continues up from about 9 ohms to about 25 ohms at 25KHz. Now in an LP mastering situation you have to apply the RIAA pre-emphasis; this means that you have to make a fair amount of power at high frequencies because so much emphasis is added. That is why the transistor amps are rated for so much power (the cutterhead itself cannot handle anything near that power level) because the transistor amps lose power as frequency increases due to the load, being capable of only about 40 watts into this load at 20KHz. So as a result our M-60 works out to be an ideal amplifier, as it actually is capable of more power/less distortion into the higher impedances. The cutter system employs a feedback module that adds about 30 db of feedback around the head and amplifier. This is required; without it there would be no channel seperation due to the mechanical suspenions in the head itself. It also controls head resonance. So we set up a set of M-60s without feedback, and a speaker protection fuse, since you can toast the head pretty good with only 20 watts or maybe a little less. So far the results have been excellent and the operation is keeping quite busy! The cutting system is capable of cutting grooves without distortion that no cartridge or arm combination could ever track! In addition, the lathe cuts are considerably quieter than the best vinyl, rivaling digital in terms of dead silence. The bandwith is amazing, good from about 5 Hz to well over 40KHz without effort; with some mods to the electronics and a different needle installed on the cutterhead we could cut a 50KHz subcarrier in the groove with FM stereo modulated on the carrier! I can't say how well an OTL would work on other cutterheads like the Neumann, but for the Westerex its ideal. ``
  3. Zero Moram da dodam i ovo : Pre nekoliko meseci je Ralph osposobio svoju Westrex masinu za rezanje vinilskih ploca , ali je izbacio originalni Westrex SS 120W /Ch Amp sto pogoni i vodi rezni Westrex-ov cutterhead i ubacio svoj M60 OTL na to mesto , postignuti zvucni rezultati su mu vise nego Odlicni !!!
  4. Tako je ! Ta prva u sredini prihvata signal , ona iznad je Kaskodna signalna cevka , o ona ispod je CCS za obe gornje , cetvrta je od DC kuplovanih drajvera . BTW , Covek se zove Ralph Karsten i uspesno pravi ove OTL vec jedno 30 i kusur godina ! , skroz je OK lik ! , i sto je najbolje pomaze medjunarodnu DIY zajednicu koliko god moze !
  5. Zero Druze Za Atmasphere M60 OTL Iskljucivo koristiti Ruske 6H13C za izlazne cevi , relativno se povoljno mogu naci kod Ruskog trgovaca cevima & ostalom slicnom opremom GS Tubes : http://www.gstube.com/catalog/1/ gde trenutno vrede 7,70 $ . Nisu lose ni originalne 6AS7G ali su mnogo skuplje i teze se nabavljaju . Varijante 6080 Ne Koristiti jer nece dugo izdrzati na tom mestu ! Neku originalnu 6sn7gt nije lose staviti na mesto prve ulazne cevi ! , sve ostale tri mogu biti i Ruske 6H8C !
  6. Van Reitz Obecao sam Dobrivoju da cu da ga obidjem cim zavrsim sa svojim prolecnim poslovima u Banatskoj preriji !!! BTW , prilazem i schemu PSU sa virtuelnom masom kojeg planiram da upotrebim kod ovog SS amp-a, kod ovog sistema DC zastita zvucnika nije potrebna , jer vidim da slican sistem radi lepo kod svih tih matorih Revox-a , 5W Zenerke 1N5373B ( 68V ) sluze da zastite PSU Elkove od prenapona u slucaju da dodje do proboja nekog izlaznog tranzistora . Pozdrav !
  7. Ruznog li Zvucnika za 7000 Yura !!! Sa svih tih 160 Kila podseca me na neki motor koji je ispao iz nekog pokvarenog UFO -a !!!
  8. Van Reitz Verujem da je tako kao sto si i napisao ! , tako da mislim da cu da ubacim i kalemce namotano na manjem otporu ( 2R2) na red sa ( + ) kablovima ka zvucniku , da spreci prodor RF unazad kolko tolko . 100R / 2K2 ce biti startni otpori u GNFB petlji ! Ps , Stari nabudzani Revox A78 koji svira 24/7 kod mene u kuhinji je zvucno zakon za ovog rasturenog PA snagasa ! , kao i za mnoge druge na papiru mnogo ( neuporedivo ) bolje SS Amp-ove !
  9. Van Reitz Ova topoplogija mi je privukla paznju jos odavno ! , jos kada sam procitao white paper od pok. Bruce de Palme ! Dosta je retka , samo je Madjarska firma Weed koristi jos uvek i dan danas u njihovim Canopus BJT Amp-ovima snage . Recimo da sam ovog Japanskog PA donora delova bio opravio 100% , ukjucio i poslusao ne vise od 10 minuta i rekao : Sranje zvuk ! , snage kolko oces al kvaliteta zvuka nigde ! , recimo da zvuci kao svaki tipican zvuk dobijen iz SS pojacala B klase koja imaju Diferencijalni pojacavac na ulazu ,( sa zadovoljstvom sam ga raskupusao ! ) . J fetove ne bih ubacivao jer ih i nemam , a i oni traze kaskodiranje pri ovom naponu napajanja od + - 62VDC , za ovaj par A970 / C2240 cu da pogledam svakako ! Velike hladnjake cu da uzemljim svakako inace ! , posebnim vodom u centralnu` star point ` tacku mase , ako budem stavljao VAS Tr. na poseban hladnjak i on ce biti uzemljen svakako ! Ali mislim da bi i oni mogli da idu djuture na veliki hladnjak , primera recimo da kod ovih hibridnih STK kola snage sve od aktivnih elemenata jeste ugurano dzumle unutra pa nista ne smeta . Sto se ispravljaca za tvoj VSSA Amp tice mogu ti reci bar iz perspektive kako sam ja dosao do dobrih trafoa , na otpadu ! , platio sam ih kolko par flasi piva ! Odnosno ako se negde snadjes za par snaznih ispravnih toroida nemoj da gledas sta imaju na sekundaru nego to pokidaj , primar izoluj PVC izolir trakom pa namotaj preko bakrenu foliju ( eventualno Alu. ) , ali tako da se ne kratkospoji nigde sve pomocu iste izolir trake , to ce biti elektrostaticki oklop ! ( zalemiti izvod tanjom zicom ) Preko toga za sekundare mozes da namotas i sa obicnom PVC izoliranom licnastom debelom zicom onoliko navojaka kolko ti je vec potrebno od napona u sekundarima . Licno nemam nista protiv dobrih Chopper ispravljaca ali po mom misljenju i dobro odradjen obican ispravljac zavrsava tu posao 100 % . Eto i seme koju sam skinuo sa tog Japanskog lose zvucnog rashodovanog PA donora :
  10. Van Reitz Moje je misljenje da za tvoj projekat VSSA sa lateralcima u izlazu bitno da je ispravljac napravljen sa kvalitetnim i superdimenzionisanim toroidnim transformatorima ! , + da imaju elektrostaticki oklop izmedju primara i sekundara koji mora biti spojen na centalnu tacku mase , + da ih posebno oklopis u neko gvozdeno kuciste da i ono malo rasipnog polja bude tako ponisteno . Upotrebi snazan grec od bar 50A , isto tako po mom misljenju je najbolje da se ubace vise manjih Elko-va spojenih paralelno za svaku granu tog bipolarnog napajanja , recimo 3 x 10000uF za svaku granu najmanje , tako se dobija nesto malo na brzini odziva ispravljackog filtera .
  11. Ispravljac za svaki monoblok ce biti sastavljen od po dva 300W C tipa transformatora svaki sa 44VAC sekundara vezanih na red , grec ispravljac ce biti od 120A svaki . Elkovi ce biti za jedan kanal 2 x 37000uF / 75V , a za drugi 2 x 61000uF / 75 V sto mi je poklonio kolegion Dobrivoje !!! Ps , imam neku ideju da srednji kraj sekundara trafoa uopste ne vezem izmedju Elkova nego da idem sa virtuelnom masom rada preko par otpora .
  12. Van Reitz Tacno tako ! , ovaj Amp sam bazirao na VSSA topologiji ! Mogu da ubacim po dva para 2sk135 & 2sj50 u svakom izlazu i tako izbegnem drajvere i temperaturnu stabilizaciju ali su mi hladnjaci vec pasent izbuseni za ove snazne originalne Toshiba izlazne tranzistore koji isto poticu iz tog starog rashodovanog PA snagasa , diode za temperaturnu stabilizaciju bile su isto tako vezane i u originalnom PA snagasu tako da tu ne ocekujem problem drifta mirne struje. Hladnjaci su inace relativno izdasno napravljeni . Drajverske tranzistore planiram da postavim na te ogromne hladnjake izmedju izlaznih BJT , ne znam da li da postavim tu i VAS tranzistore isto ? Nikakav PCB ne planiram da upotrebim, sve ce biti PtP spojeno kao kod lampasa ! Sto se tice vrednosti pojedinih elemenata tu cu morati malo da experimentisem `` in vivo `` ( naravno sa ubacenim zastitnim 10 ohma otpornicima u kolu kolektora izlaznih Tr. ) Recimo za pocetak cu ici sa 3K9 otporima u kolu baza VAS Tr. , Trimeri sto odredjuju struju kroz VAS stepene bice smanjeni na 47K . , ostaje mi samo da se poigram sa vrednostima emiterskih GNFB otpora kod ulaznog stepena ! VAS & Drive stepeni svakako moraju da rade u A klasi ! , mislim da cu za pocetak na ulazu da ubacim B716AE / D756AE par jer su nesto jaci nego A872AE / C1775AE , oni ce biti zasebno termicki da budu spojeni ( zalepljeni ) .
  13. Nikad cuo za tu knjigu ! Sta je sadrzaj ? i od kakve koristi moze biti u konkretnom projektu ovog SS Amp-a ? ima li je negde na NET-u za skinuti ?
  14. BANAT
    Open baffle za 20 minuta
    2a3 Iskreno se nisam nikada bavio takvim tipom open bafle zvucnikcog sistema ! Ali sto pa i da ne experimentises sa tim krilcima ! BTW , licno sam ljubitelj zvuka dobro dampiranih kompresionih kutija , ( sto ne znaci da i njima ne moze da se dodaju ta spoljna horn krilca ! , sta levo i desno , sta i gore i dole ) .
  15. BANAT
    Zoki U stara vremena prapocetaka razvoja Cevne Radio & Audio tehnike industrija je bila neverovatno bogata sa razlicitim specificnim pristupima i resenjima kada su razlicite zvucnicke jedinice bile u pitanju ! , cini mi se cak bolja nego danas . Siguran sam da su nekada postojali i dinamicki zvucnici sa izuzetno velikim DCR otporom reda sve do nekoliko Kohma , a opet motani izuzetno tankom bakrenom zicom ! Na zalost takve zvucnike danas pronaci je skoro nemoguce ! , ali od preostalog stocka pre svega mislim na Ei Nis okrugle 800ohma / 3W fullrange -ve moguce je upotrebiti za 2a3 OTL tako sto se po cetiri takva vezu na red da se dobije 3,2Kohma , takvu sam kombinaciju jednom probao vezanu onako na astalu bez ikakve zvucne kutije i mogu reci da to radi i zvuci Odlicno ! Pozdrav ! Ps . Izvinjavam se kolegionu 2a3 ako mu otimam temu offtopikom !!!
  16. BANAT
    Kolegione 2a3 Hvala na Pozivu !!!
  17. BANAT
    Zoki Druze Samo da napomenem da nacelno postoje dva tipa dinamickih visokoohmskih zvucnika ! Oba tipa su predvidjena za OTL pogon ali na dva sasvim razlicita nacina . Prvi tip je gde je spulna motora motana ultratankom Bakrenom zicom , sa relativno mnogo navojaka sve do zeljene DCR otpornosti , i najcesce su se nalazili ugradjeni u starim crnobelim cevnim TV- ima , poznaju se po onom magnetu postavljenom od napred , i obicno su bili vezani u kolo OTL Amp-a preko speznog Elka ( Philips & EI Nis SRPP sistem ) . Drugi tip je ovalni, i on je malo redji , motan je debljom Otpornom zicom sa relativno manje navojaka spulne , i taj je tip bio predvidjen da ide vezan direktno u anodno (ili katodno) kolo manjeg SE OTL A klase Amp-a . Recimo da sam mnogo godina koristio jedan takav ovalni ugradjenog direktno u kolo anode triodno spojene 84-ke u svom MW komunikacionom cevnom prijemniku , i zvucao mi je odlicno ! Moja poenta je ipak sledeca : Ja se zaista nisam sretao sa tim Philips AD9710 tako da i ne mogu reci sa 100% sigurnosti o kakvom se tipu visokoohmskog zvucnika radi ! BTW , Evo i jednog takvog primera , mislim da potice iz nekog ultrastarog Philips manuala za 2a3 cevku : Pozdrav !
  18. Ajd i ja da predlozim jedan moj omiljeni film ! Nevinost bez zastite - Dusan Makavejev
  19. BANAT
    Kolegione 2a3 Ispada da tako imas dva izlazna trafuljka izmedju 2a3 cevke i tog 600 ohma zvucnika , ako je tako ta kombinacija ti tako odvlaci dosta `muzike`, jer ti izlazni transformatori obaraju kvalitet reprodukcije muzike , satiru ti i bas i soprane , pogotovu u najfinijim mikro detaljima ! Po mom misljenju imas dve mogucnosti : 1) Da naviklujes neki izlazni trafo sa 600 ohma sekundarom 2) ili da ides na neki omanji OTL , koji bi se po mom misljenju tu i najbolje uklopio uz taj 600 oma zvucnik . ( nadam se da imades i njegov par ) BTW , nemam neka iskustva sa tim open bafle daskama ! , tako da ne mogu da komentarisem taj sistem rada . BTW ` , Skroz gore slika desno , kao stari TV mehanikus ti savetujem da sklonis tu cvecku od te bele tehnike , jer oce da navlaci vlagu i da tako izazove proboj struje , pogotovu kod tog CRT TV-ia ! Pozdrav Willy !
  20. Druze Svi SS Ampo-vi su odavno vise / manje OTL ! , ima nesto jako malo izuzetaka koji su WOPT SS Ampo-vi , recimo McIntosh , Susan Parker Amp ..... itd . Sto se uskladjivanja impedanse SS Amp-ova prema teretu zvucnika ni svi oni nisu bas idealni , recimo da jako malo njih moze da se dostojno izbori sa nominalnim teretom od 2 ohma ili nize ! , svi prosecno dizajnirani B klase SS ampo-vi koje sam do sada povremeno koristio najbolje su mi zvucali na nominalnom opterecenju od 16 ohma ! Ovaj sto ga sada sebi pravim za pocetak ce da radi na 8 ohma , a nedugo zatim iskljucivo na 16ohma ! Krajnja postignuta maximalna snaga me ne interesuje toliko , vec koliko da izvucem maximalan kvalitet zvuka uz minimalnu potrosnju struje i ujedno nepotrebnu razvijenu toplotu , bicu zadovoljan ako dobijem da prvih par Watt-i po kanalu bude radilo u cistoj A klasi , sve ostalo iznad od razvijane snage neka sljaka u ekonomicnoj B klasi .
  21. Druze Isti slucaj !!! Jer uglavnom sam sklapao cevne skalamerije , a ove SS samo popravljao i budzao ! Ali nesto mi govori da ce i ovo da proradi ! , i to mnogo dobro !
  22. Kolegione Sta te muci kod tog tjunera ?
