356 -
1
Sve objavljeno od zoranzu
Jedan mali bolesni interkonekt zasnovan na NEI-3001
zoranzu je odgovorio/la SHAVIJA's temus u Hi-Fi audio
Pa odakle se stvorilo ne udavljeno bas podrucje kod 99% lampaskih pre ampova,a imaju 100n i manje na putu signala? Mora da je prvo pao dupli placebo sa ledom... -
Ako ti je jos do probe sa 3001 nabavi za + u centralnoj cevcici https://www.acoustic-revive.com/english/index.html https://www.acoustic-revive.com/english/cable/spcav.html za - sva 4 provodnika iz 3001 u paralelu Šild otkačen na oba kraja -
Kako za koga...koga on opismeni,zavrsice na Ei HSR-u 48 Tip je pukao na strujnim kablovima -
Sto vise zica to ima manje R i L -
Soltanus
Sredinom 80 u TAA je bila shema za cevni pre amp sa 4kom ECC83 imena Aurora a baziranog na Luxmanovom kitu Linijski deo je bio sa 2kom ECC83 i to je radilo dosta dobro. Povukao me je komentar autora,da ga napravim, da je Aurora ostavila iza sebe AR SP10 Ako negde shema moze da se nadje?
Finel
Bar ovo nije, puno kosta,za DIY Bare Wire Neotech 26 gauge upocc silver/teflon solid core$5.79 Neotech 26 gauge occ silver/gold alloy$9.15 Neotech 24 gauge upocc copper/teflon solid core$1.27 Neotech 22 gauge upocc copper litz$2.00 Neotech 20 gauge upocc copper litz$2.50 Neotech 14 Gauge upocc copper litz$8.59
Electrical conductors[edit] Single crystal copper has better conductivity than polycrystalline copper.[3] As of 2009, no single crystal copper is manufactured on a large scale industrially, but methods of producing very large individual crystal sizes for copper conductors are exploited for high performance electrical applications. These can be considered meta-single crystals with only a few crystals per metre of length. A single crystal or monocrystalline solid is a material in which the crystal lattice of the entire sample is continuous and unbroken to the edges of the sample, with no grain boundaries. The absence of the defects associated with grain boundaries can give monocrystals unique properties, particularly mechanical, optical and electrical, which can also be anisotropic, depending on the type of crystallographic structure. These properties, in addition to making them precious in some gems, are industrially used in technological applications, especially in optics and electronics Mislim da je takodje copy/paste iz Wikipedie...nema nigde pomena o bojlerima i cevima za etažno grejanje...
samo ako su hladno ceđena,
Tri puta meri,jednom seci ...
Vrlo rado bi posedovao nekoliko metera sa ovih livada i pašnjaka Internal Wires Harmonic Technology is proud to introduce internal wires, the best sounding quality and special materials – OCC Single Crystal Silver and Copper, for personal or engineer’s project. Also, HT design team provide OCC Silver wire with gold molten, and another unique one is OCC Silver w/ Gold plated wires for hi-end audio market. OCC Copper Internal Wire P/N# Conductor Material Insulation Length OCI-16AWG Solid Single Crystal Copper *Teflon 328ft/100M OCI-18AWG Solid Single Crystal Copper *Teflon 328ft/100M OCI-20AWG Solid Single Crystal Copper *Teflon 328ft/100M OCI-22AWG Solid Single Crystal Copper *Teflon 328ft/100M OCI-24AWG Solid Single Crystal Copper *Teflon 328ft/100M OCC Silver Internal Wire P/N# Conductor Material Insulation Length OSI-16AWG Solid Single Crystal Silver *Teflon 328ft/100M OSI-18AWG Solid Single Crystal Silver *Teflon 328ft/100M OSI-20AWG Solid Single Crystal Silver *Teflon 328ft/100M OSI-22AWG Solid Single Crystal Silver *Teflon 328ft/100M OSI-24AWG Solid Single Crystal Silver *Teflon 328ft/100M OCC Silver/Gold Internal Wire P/N# Conductor Material Insulation Length OSGI-24AWG Stranded Single Crystal Silver/Gold Polyethylene 328ft/100M OSGI-26AWG Stranded Single Crystal Silver/Gold Polyethylene 328ft/100M OSGI-28AWG Stranded Single Crystal Silver/Gold Polyethylene 328ft/100M OCC Silver with Gold Plated Internal Wire P/N# Conductor Material Insulation Length OSGP-24AWG Stranded Single Crystal Silver w/Gold plated PVC 328ft/100M OSGP-26AWG Stranded Single Crystal Silver w/Gold plated PVC 328ft/100M OSGP-28AWG Stranded Single Crystal Silver w/Gold plated PVC 328ft/100M * Teflon is a registered trademark of Dupont FILED UNDER: INTERNAL WIRE
Da li ti je nesto iz teme proslo kroz ruke,ili sistem, da li si imao prilike da im vidis creva,pa to tvrdis?
U svetu preskupih (Hi End) kablova, koaksijalnih kablova skoro da i nema, Amphenol je jedan od retkih,koji se ne pravi u Kini,
Nepotrebna i ničim izazvana količina metala za konektor fono kabla. Kako moze sa slike da se proceni Amphenol, sta je low end,po ceni možda?
Godinama sam slusao EAR 859 sa malim Omega kutijama,kod prijatelja , u sobi 2x3m,milina od zvuka. Prelaskom u veliku sobu i na Yamahe 1000 M,EAR je prodat...
https://www.passdiy.com/project/articles/speaker-cables If, like many audiophiles, you have spent a small (or large) fortune on your hi-fi system, money spent for high quality cables and connectors is a reasonable investment.
Tek bi tada nadrljali od aspida, em unose krs,em jos da im se vide i zmijarnici
Ni Nestorovicevo, Laboratorijsko pojacalo 25W. nije bilo namenjeno za Hi+iFi. @ crni Da se ne naljute vlasnici PBJa,ima previse lufta izmedju bakra i teflona,idealno za oxidaciju licni.
Ako vam je za uzivanje tj slusanje muzike dovoljan samo 1W iz kojeg uredjaja bi ga trosili? HSR 48 Sony mini linija Pass First Wat 211(u izlazu) 300B(u izlazu) OTL 2SK/2SJ 49/50 Hitachi(u izlazu) Sankeni RingEmiteri(u izlazu) Krell KSA 50
Pas progutao činčeve,ili ih zakopao u bašti?
*Cela Super Cables Industry je nastala i bila rodjena, zahvaljujuci eksperimentima i istrazivanjima (na nekom) univerzitetu u Americi. Tehnicku opremu,ukljucujuci i kablove,radio je Robert Fulton,sve se to desavalo oko 1975 godine. Najobicniji zvucnicki kablovi,(lamp cord) unosili su veliki fazni pomeraj ,licne unutar kablova su oksidirale i nisu bili adekvatni za ta istrazivanja. Robert Fulton je napravio(konstruisao) zvucnicki kabel koristece sva moguca teh.znanja vezana za RF tehniku i tako uspeo da prenese 95Khz sa minimalnim faznim pomerajem. Napravio je jos jedan i probao ga kod sebe u svom audio sistemu. *slobodan citat iz Alan Wright/ Super Cables Cook Book Citirani deo posta vvlad + * = samo kao tema za razmisljanje, sta se desava sa kablovima tokom godina,..
A gde su slonovi, koje su marke i tezine... Ni okrugla ni ravna,nesto trece,kao i kod kablova.
I oko toga,lome koplja.
Trenutno na sajtu 7 članova, 0 Skrivenih, 472 Gosta (Pogledaj celu listu)
Ukupan broj tema454.9k
