Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. usipusti njih da odluce
  2. that way - he'll even more open lower SS and offset will go neg. even more
  3. set R25 to minimum - before increasing R26then go up turning R25what's , on earth , value for R35 at your pcbs ?
  4. naah - he's probably sleeping now
  5. ma ja cu mom djeticu sa prelepim jezikom biti i prvi , ako treba
  6. Zen Mod
    Sta je ovo
    interfon , telefon , sta godzicani konferencijski toki voki
  7. to mu dodje šjestia ti mu dodjes sjedmi
  8. 3. ako nemas sa lakocom 1. - da to uradi neko kako valja
  9. ja ti objasnihako hoces tako - onda svaka mora imati svoj vezni kapacitet sa katoda , koje onda udruzujes na samom izlazuprimecujes bitnu razliku ?
  10. don't try to confuse me - thats pretty easy these days if offset is negative - that means you need to more open upper SS so - scenario is : if - with R25 on max and R12 on min offset is negative - then increase R26 - to 470 or 510 ohms
  11. stvar resena
  12. a sto ne bi moglo ......ako imas gotovo komercijalno resenje - zasto da pravispod pretpostavkom da orman nije bio skup
  13. @ Teanegative bias means that lower SS is more open than upper SSif you can't in same time to increase bias and null offset - with trimpot R25 , increase R26 to 470Rleave R28 as is - you need minimal voltage for led operation , and that resistor is set for that - minimal needed voltage
  14. znas li gde su akusticki centri za svaki ponaosob ?
  15. some local fucker tried to post schematic on big diya http://www.diyaudio....tml#post2395204 now - I'm going to delete all important schematics in thread ( meaning on those "almost finished " and finished) ........ and it will be available only via e-mail
  16. ili sve tri ili nijednavidis da sa spojenim katodama imas stalno sve otpore ispod katoda - imao ubodenu jednu dve ili tri cevi .........
  17. za sta ti oci sluze ........
  18. imaju one ubacoke sa 5 ili 6mm unutrasnjim masinskim navojem , a spoljni navoj (za drvo) od nekih 15mmvidljive u FFL temi - tako je montirao Tannoye- sad - gde ih ima ........ snalazite se u Prestonici - trazite dobru prodavnicu opreme i alata za obradu drveta
  19. principijelno da .
  20. Zen Mod
    Aleph 5
    mea culpamaxima ......ide me nesto ovih danasad cu da se banujem .........
  21. a krenulo vas danas ......
  22. - "jes' ti muzicar "- "nisam ....... ovaj , jesam ......... ovaj , nisam ......."
  23. a naravno Ziko - izljubimo se mi ucelo svako malo - ni Bonzita nam ne treba kao povod :sarcastic_hand:malo mi bilo onako - predadoh na reciklazu vernoga mi keca - u zadnjoj iteraciji 1400ccm , 85KS , spusten , rasiren , sa udobnim opel sedistima , petak talijanac menjac ........al' sad ga stvarno izdade skoljka ..... a ja ledja nemam za overhauling iz hobijanaslo bi se 200-300 ojra za drugu kantu za reciklazu , al' to sa ledjima je na zalost istina .......
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 158 Gosta (Pogledaj celu listu)
    453k
