stein
Sve objavljeno od stein
  1. Ondak je ovaj bolji https://www.youtube.com/watch?v=oHQJeNFChzQ
  2. E da vidim mangupa koji ovo može da ugura u svoj Golf dvojku!
  3. Grešiš, ovaj, grešiš šinko, traženi pojam je bio "bigger is better"
  4. Ponekad tražim nešto određeno, ponekad ne, pa tu i tamo naiđem na ponešto da pročitam šta mi se učini zanimljivim. Zaobilaženje dnevnopolitičkih tema i vesti o lošim i "ozbiljnim" stvarima mnogo je relaksiraniji metod opuštanja (otpuštanja stresa) nego što to može da deluje na prvi pogled. Nekad sam tokom rada pravio pauze tako što bih odigrao partiju šaha ili karata protiv kompa. Sad odem na gugl i ukucam neki izraz, pojam ili deo rečenice pa šta nađem... Desetak minuta neobaveznog "blejanja" tu i tamo značajno mi je povećalo efikasnost i produktivnost.
  5. http://thoughtcatalog.com/christine-stockton/2013/08/50-women-on-does-dick-size-matter/ "Amanda, 31 I honestly don’t really notice. I’ve seen a ton of dicks in my life and they all pretty much look and feel the same."
  6. Otprilike, s tim, da ovde gospodin (poreklom) iz Rusije ima deblje kablove Zvanična adresa mu je, naravno u USA... nedaleko od uošingtona ... (tako ga nekako izgovaraju, ualjda...)
  7. Stealth Audio Cables: Power: PRICING Suggested retail prices for the M-7000 cord are: $1230 - for 1.2 meters and shorter ($1750 with STEALTH solid silver V10 IEC and wall plugs) $1330 - for 1.5 meters ($1850 with STEALTH solid silver V10 IEC and wall plugs) $1700 - for 2 meters ($2,220 with STEALTH solid silver V10 IEC and wall plugs) and $740 for each extra meter after 2 meters; PRICING: Suggested retail price for a 1.2 meters long Dream V12 cord is $4,200; $4,400 for a 1.5 meters cord, and then - $1,200 for each consecutive meter; Suggested retail price for a 1.2 meters long Dream V12 UNI cord is $4,800; $5,000 for a 1.5 meters cord, and then - $1,200 for each consecutive meter; Speaker: PRICING Suggested retail price for the Dream Royale is $28,500 for a 2 meter pair, and $22,000 for each consecutive meter. (1.5 and shorter pair of Dream Royale speaker cables is $22,000) Bi-Wiring adds $2,500 regardless of the cable length; Interkonekti: PRICING Suggested retail price for a 1 meter RCA-terminated Śakra pair is $12,000 ($7,600 for each extra meter). Suggested retail price for a 1 meter balanced XLR Śakra pair is $16,000 ($9,600 for each extra meter). http://www.stealthaudiocables.com/ Lepo objašnjeno kakva se tehnologija krije iza proizvoda. Vlasnik firme pokazuje ko zapravo ima veći i deblji...
  8. Apsurdno je doduše, kada se ispostavi da struja u uređaje kod takvog stiže iz neke termolelektrane.
  9. Sve, sve, ali dok se ovo ne doveze u kuću, mislim da neće biti mira...
  10. Možda ću da lupim, ali DVB-T/C ili DVBT2? Mislim, ako nema DVB-T2, onda se mora potrošiti još dodatnih 3-4 hiljade pa onda možda i nije toliko povoljno (a pride moraš dodati još jednu kutiju, zauzeti još jednu utičnicu itd) osim ako te ne zanimaju domaći kanali...
  11. Elem... ako je TV ispravan, skoro pa greota ga rasturiti zbog dve ili tri lampe... Znam, niko više danas ne gleda okrugle 17" ekrane, al' opet, to je komad istorije, pogotovo ako je funkcionalan... Ja bih, da ga imam (a ne treba mi) krenuo od pokušaja da ga dam, prodam, poklonim nekome ko bi ga cenio takvog kakav jeste, a recimo u zamenu uzeo nešto delova od kojih je smislenije sklopiti nešto... Ponekad je manje - više...
  12. Ako ništa drugo, onda možeš naći šemu (pomaže, uvek) i iskoristiti izlazni trafo (ako je audio izlaz cevni) i jednu ili dve lampe koje su u tom delu. Ako me sećanje služi, taj TV je ili isti ili skoro isti kao Philips 17TX291 (što može da pomogne u pronalaženju šeme) Probaj ovde: http://static.elitesecurity.org/uploads/1/1/1142259/rr865-11.tif http://static.elitesecurity.org/uploads/1/1/1142259/rr865-12.tif http://static.elitesecurity.org/uploads/1/1/1142259/rr865-13.JPG Ako je ova šema okej, onda imaš PCL82 i PL84 u audio izlazu ali nema izlaznog trafoa jer ide zvučnik od 800 oma..., pride je tu jedna ECC82 i PL36... malo ili nedovoljno da se osloniš na delove iz samo jednog TV-a za neki stereo audio uređaj...
  13. stein
    Lepota dizajna
    Mislim da je ovo samo čisto iživljavanje. Al' eto, ko ima vremena i malo para te viška resursa... Neka ga, nek' se zabavlja
  14. stein
    Lepota dizajna
    Naravno Ovo i jeste kutak za takve stvari. Zanimljivo i drugačije.
  15. stein
    Lepota dizajna
    Mene i ne kopka kako svira nego čisto sa "inžinjerskog stepena izvodljivosti"... Ponekad je loše implementirana, ali dobra ideja vredna za "ukrasti" i implementirati je negde drugde na primereniji način gde dobija na vrednosti
  16. stein
    Lepota dizajna
    Pa kažem, ploča je nagnuta nekih desetak stepeni u udnosu na vertikalu, taman dovoljno da se može primeniti princip gravitacionog naleganja igle na ploču. Teg je verovatno ultralagan ali to i nije bitno ako sprava radi. Simpatično, ali ću se zadovoljiti svojim Tehniksom, pa sve i da nije najbolja sprava
  17. stein
    Lepota dizajna
    Video na kikstarteru pokazuje nagib same ploče (nije vertikalno postavljena) pa onda još i može da radi... Recimo da je izvodljivo. Sa potpuno vertikalno postavljenim tanjirom bi naprosto bilo
  18. stein
    Lepota dizajna
    Zanimljivo, doduše, nije mi jasna svrha protivtega na ručici jer je u ovakvoj poziciji ručice apsolutno kontra-produktivan. Gazna sila igle mora drugačije da se reši (ovde gravitacija nema šta da radi po pitanju gazne sile) pa je nešto drugo posredi, pride, nešto mora da pomera ručicu i da kontrira težini tega sa donje strane. Dakle, ručica izgleda kao, ali ako ova skalamerija uopšte radi, ručicu oko pivota pomera nešto drugo a ne gravitacija + brazda ploče. Al' ajd da vidimo gde će da završi, hoće li ga biti u decembru ove godina kada bi trebalo da bude u prodaji... https://www.kickstarter.com/projects/gramovox/floating-recordtm-vertical-turntable Ko još misli da ga dobije za 389 dolara, ima još par komada da se rezerviše (u redovnoj prodaji, cena će biti nekih 500 usd veća)
  19. Ono što je Neskor ponudio je veoma dobra cena. Predlažem pokretaču teme da ne žuri, nego da recimo, možda razmisli o grupnoj kupovini tj da se istovremeno, na istom mestu kupi više komada a po prispeću u Srbiju podele komadi između onih koji su naručivali tj kupovali. To je jedna opcija: više komada na istom mestu, više kupaca - manja poštarina po komadu (paziti da sveukupna vrednost ne probija 100€). Možda ima nešto slično na Aliexpresu - mi smo sada kupovali nadzorne kamere (HIK) po ceni od cca 85€ (iste koštaju u Srbiji oko 28-29 hiljada/kom) i paketi su slati na razne adrese u razmacima po 4-5 dana, svaki put bi carinska nadoknada bila oko 450 dinara (u zavisnosti od trenutačnog kursa dolara) a stizale bi u roku od desetak dana. Pošto mislim da je reč o ličnim potrebama/hobiju, čekati deset dana nije neki problem. Problem je što trenutačno nema ništa sa free shippingom, sve ide na 56 dolara poštarine za 5-15 dolara cene... Evo šta se trenutačno nudi sa besplatnom poštarinom: http://www.aliexpress.com/w/wholesale-transformer-covers.html?site=glo&SearchText=transformer+covers&shipCountry=srb&CatId=63701&isrefine=y (nije sve besplatno slanje) - po tim cenama (cca 30€/kom) može ovde da se odradi i još da i ostane para ihaj. Dakle, možda bi vredelo kopati po KP pa čak kupovati stare trafoe i adapter trafoe sa 110 na 220V, oni su obično dolazili sa tim štancovanim limenim poklopcima, čak sam i imao nekoliko komada, no mi bilo žao rasturati fine američke trafoje... Ovako nešto: http://www.kupujemprodajem.com/Trafo-2x29vac-6-3A-i-8vac-1-6a-23334108-oglas.htm?filter_id=20407231 ili http://www.kupujemprodajem.com/Step-Down-trafo-21343612-oglas.htm?filter_id=2289 http://www.kupujemprodajem.com/trafoo-220-11ov-100w-rezervisano-23164293-oglas.htm?filter_id=2289 http://www.kupujemprodajem.com/trafo-220-110v-300VA-23163356-oglas.htm?filter_id=2289
  20. ja sveo (*svodim od svoditi - sumnjiva radnja, od zanimanja poznatog kao svodnik, podvodač iliti narodski "kuplermajstor" ) (**sveo - nije u cvetu mladosti, uveo, sasušen)
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 208 Gosta (Pogledaj celu listu)
    453.5k
