16080 -
57
Sve objavljeno od stein
Khm... I'm usually getting some of my music from a shop known as avaxhome.ws once you copy and paste this into your browser and go to music, fileformat lossless, you'll see it's taking you to RS where the files are. Then, you download it, unpack (unzip, unrar, whatever) and then it's either ape, wv, flac... however, often recorded/made as a single lossless file with added *.cue file which contains info how to split that single file to single tracks. I need them single tracks to be able to listen to separate songs... Clearer now?
Ne znam šta se podrazumeva pod terminom "ubijen"... Znam da je po pitanju svega, bar što se tiče muzikalnosti sistema, zvuk dobio priliku da se raširi, razmaše i u svakoj varijanti je ovo neuporedivo bolji ambijent za slušanje muzike. E, sad, što ja možda očekujem nemoguće, da dobijem nivo pritiska koji ovi emiteri ne mogu da proizvedu, to je već druga stvar. Možda je samo to u pitanju. Prostorija je osnove oko 70m2, nema zidova osim dva zabata i tu definitivno treba energije da se vazduh zaljulja, pa sve ovo što činim možda nema mnogo šanse da uspe, ali neću znati ako ne pokušam. :buehehe:Ko redovitije prati forum zna da sam ponekad rastrzan između sijaset projekata, ideja i želja, ali i to da sam jedan od najupornijih da što počnem i završim (bez obzira na sve...)
It seems I'm stepping with one foot into one, then, with the other into next one. Doggie poop, of course (that's what happens when walking in a public park...)Downloading and unpacking doesn't really finish the job. Getting the file to the proper format adds up to complexity of the task (oh, it was so simple in win, doing it all with a single app...) The converter offered in the software package does the job of converting an *.ape or *.wv file into FLAC, however, it can't handle *.cue files which I personally dislike because it's not necessary that I want to burn an audio CD... Most of the time I do, but then, not every time. Total Audio Converter that I used in win doesn't seem to work properly under wine, so, I'm all ears when it comes to automatic or semi-automatic splitting one huge file into separate files, that is, tracks contained on the album...
Pa dobro... Imam ja tri garniture 4/19 mimo CD plejera koji su upotrebi.Kada bi mene pitali, a ne pitaju me, ja bi sve Chakiju pitao kako mu stoji Shigaclone. Stoji li kao da će ga završiti ili stoji kao da neće. Drugo, opet, kada bi mene pitali, a ne pitaju me, druga opcija bi mi bila potraga za nekim solidnim, tj ispravnim starijim CDom od Filipsa... Nešto sa veoma ozbiljnom mehanikom. Često se na ebayu (znam, znam...) pojave "fur bastler" mašine za manje para nego koliko je poštarina... A ni klinac im ne fali ako mehanika treba da se iskoristi... trenutačno ima jedan CD104, još pet dana na aukciji, ispravan...
Ne znam da li je recimo CDM4/19 dobar kandidat? Imam jedan u poklon sa sve laserom...
Tamo gde znam da inače uspevam, ništa. Sorry.
Vidi...Treba da bude dobro za mene, treba da bude dobro i za druge, treba da bude BORG... Collective effort in translation... Ovako..Lampe , checkpodnožja, checktrafoi, razni, checkprigušnice, checkotpornici, tranzistori (Si/Fet), checkŠta bi moglo da zafali? (pliz, nemoj mi uturiti one 600:600 trafoe, toga nemam, a koga znam da ima, taj zajebava...)
E, sada, tj posle trećeg dana, "dumb Choky" će mi pomoći da usaglasim duplu triodu i povučem sa dve anode dva identična signala. Koliko sam razumeo, jedna rešetka jedne triode bi trebala da dobije neinvertovan signal a druga trioda u istom balonu bi trebala da se spoji svojom rešetkom na masu, odnosno na invertujuću stranu ulaznog signala. Dve katode bi trebale biti spojene preko nekog otpora ili možda još bolje preko dva fiksna i jednog središnjeg trimera pa na masu (ili negativni potencijal napajanja)...Ostaje da se sada odradi neka vrsta genijalnog načina spajanja dva stepena i potrebne manipulacije za isto. Koliko razumem, ne bi bilo globalne negativne povratne sprege sa izlaza za zvučnike na cevni stepen što je valjda dobro... Valjda... Ajd, sad malo pljuvanja po mojoj sposobnosti da pratim...
After a few days, the re installation of the newly installed system proved to be what I had to do from the first attempt. JDL works fine now and because I used the proper way, I got the option to open the *.jar file with 32bit version of Java. Thanks to all who tried to help
Ej, dogovorili smo se da do četvrtog prvog sledeće ništa ne pametujemo ovde.
Ne nađoh bolje mesto pa ću ovde...Posle odvajanja šuta od đubreta, sveo sam količinu komponenti na neki razumniji nivo. Ostalo mi još nešto sitnih stvari za oglase a sledi redefinisanje sistema.Kao što je poznato, u fazi gradnje imam gramofon a zbog nekih sitnih praktičnosti zbog kojih sam kupio Behringerovu aktivnu skretnicu sada, nakon što je odradila posao za koji sam je trebao, prelazim na sledeću etapu, a to je gradnja dedicated AFXO i to najverovatnije Juminu (Sipijevu) iteraciju B1 sa BF-ima (ako ih Sipi ima dovoljno na prodaju, koliko sam nešto zbrojao prste na rukama i nogama, valjda nekih 20 komada...) Elem, ne znam da li je do SSDAC-a ili NS10 ili Behringera ili čak F5, ali kada malo ozbiljnije želim da poteram statike, dolazi do čujne distorzije. Posebno u najosetljivijem, srednjetonskom području. Pošto po onome što znam, NS10 može da se ne zagrcne bukvalno do one granice gde dobija 24VRMS na ulazu, njega ćemo isključiti. CD630 je još uvek na operaciji pa ne mogu nikako osim sa Marantzovim CD38 ili CD303 da pokušam da izvučem neke dodatne procene jer sa SSDAC-om koji je totalno u sirovom stanju (na originalnoj DAC i napajačkoj sekciji nije bukvalno ništa menjano, Phil. CD460) teško mi je biti realan. I naravno, ili F5 dolazi u zasićenje tj klipping zbog neosetljivost panela, ili sami paneli dobiju previše pobude i izlaze iz granice maksimalnog zvučnog pritiska koji mogu da ostvare. Zanimljivo je da sam probao sa potpuno isključenim sub zvučnicima (isključen amp)i poterao sam visoki propust na nekih 250Hz-a i distorzija na velikim glasnoćama i dalje je prisutna. Naravno, reč je o baš velikim glasnoćama sa kompleksnim muzičkim materijalima. Nisam probao bez Behringera jer postoji opasnost da oštetim folije ako poteram u FR režimu na tolikoj glasnoći...Ostaje mi još jedna alternativa, a to je da konačno očistim radni sto i završim A5 klona i vidim da li je možda F5 u klipovanju...
aktuelno...
Dobro, ajd onda da tema odmori još par dana, sretno vam bilo dočekivanje! i odmaranje posle...
Ma čitam ja, ali čitam i arapski i kineski, ali brate razliku ne uspevam da nađem
Vidim ja da ste obojica isto toliko glupi kao ja. Najmanje zajedno toliko. Ne mora šema biti ni danas ni sutra, ni prekosutra, može sledeće godine, ko što reče Zen, svakako neće se ni praviti ovih dana, jebiga, prošla me volja kad nisam ni beton u stanju da izlijem a da ne pukne odmah :rolleyes:Vi ste samo toliko bolji od mene koliko razumete kako se nešto može ili ne može spojiti. Jebo me Akerman kad samo takve stvari razumem. A i to donekle... Ja sam totalno vizuelan tip, manje mi treba da nacrtam nego objasnim rečima, ali me jebe što nisam našao ni jedan forum koji umesto tekst editora nudi paint kao opciju za komunikaciju svejedno, kako god bilo, ja bih sad pitao da li se recimo, principijelno gledano, može deo cevnog arangementa, dakle princip sa cevkom, dve triode i dva bipolarca u anodama, te bipolarac u bazi iskoristiti da se spoji sa Cirklotrolom? Q1 sa kolektora šalje signal na Gate Q5, što bi recimo išlo ili preko konda od 1u5 a druga polovina signala sa baze Q3 na drugu polovinu umesto na Gate Q4... Znam da samo tako, 1:1 ne može jer je ovaj hibrid sa moje šeme DC kaplovan ali sigurno da postoji neka fora, izmena nekog detalja koji bi olakšao izvedbu?
Pošto je prošlo dva dana, reših da izvadim probni komad valjka za kućište motora iz kalupa. Nakon presecanja spoljašnjeg omotača krenuh da vadim unutrašnju košuljicu i prc... raspade se beton. Ne valja. Prerano, očigledno... Ajde Jovo, nanovo...
Pa mene je to i zbunilo u preporuci, čemu komplikovati sa full simetrijom kada su cevke "najpametnije" sa jednom ulaznom i jednom izlaznom tačkom... Nisam ni mislio da će SRPP biti najbolje rešenje za bilo šta, ali kako god i okrenem, opet je "kvaka" sa potrebom za dva identična aprotivfazna signala. To se može i sa jednom triodom ali onda katodni otpornik mora biti dovoljno "jak" da odigne potencijal od mase dovoljno da dobijem željeni swing u odnosu na ??? potencijal napajanja ?Da budem iskren, nisam hteo da kopiram postojeća rešenja, ali ako je tako jednostavnije doći do finalne verzije, ja sam na umu imao nešto ovako:Ono što se meni ne dopada je opet rad u A klasi sa ogromnom disipacijom, preporuka je upotreba hladnjaka sa 0.2K termičkim otporom... Mada...
Ja sam to sve u najboljoj nameri. Baš si me podsetio na jednog prijatelja, okorelog TV servisera kada je dobio ruski TV na popravak. Otvori on poklopac sa zadnje strane, zabode pipalicu na šasiju, uključi ga, gurne ruku na šasiju i zadimi se, i pade na policu iza leđa... Šta bi? Pametni Rusi vezali +300V na šasiju...
Dobro, vidim... Nego. U Cirkustrolu ostaju pozicije ispred kondova od 1u5 a to su R27 i R28 (15E) i pošto sam nepismen, kako bih, recimo sa SRPP stepena uopšte mogao izvući dva adekvatna signala? Pada mi na pamet opcija da sa recimo jedne triode izvučem signal sa anode a drugo pola sa katode iste triode, međutim, tu sam već zapeo zbog proračuna adekvatnih vrednosti otpornika i napona napajanja cevi. 6922 može da radi sa relativno niskim naponima u odnosu na većinu drugih duplih trioda, ali je to daleko iznad napona za cirklotron. Recimo da to nije problem. Ok... Nego, meni, a verujem ni ostatku ne bi baš bilo ni najmanje zabavno graditi sa SK135 kada je već svima jasno da ih nema... Onda se menja sve pa smo skoro opet na samom početku, možda mali korak iza...
...dobro, a kako?
Bataljujem ja šta god da treba, samo reci
Dugo me čačka ideja o jednom pojačalcetu sa cevnim ulaznim i mosfet izlaznim stepenom. Problem je što sam ja totalni vezer kada treba nešto potpuno novo da se napravi... Po ovom pitanju sam već gnjavio Zena i Sipija pa da radost podelim i sa ostatkom članova foruma... Rekao bih da je cilj dobiti pojačalce snage do nekih 50W/8 ili 25-30W na 4 oma, nešto što se neće grejati kada svirucka a neće ni kuvati ako se malo "potera"... Primer takvog pojačalceta prilažem na šemi, ali bih recimo, ponešto odavde i eliminisao i zamenio cevkom, recimo sa 6922 (ECC88) Napon napajanja je +/-37V za izlazni stepen, a cevka može da dobije svoj zaseban napon napajanja... Pojačalo koje je na šemi, svira divno ovako kako jeste, a svi delovi lako dostupni... Kopka me slična ili prerada ovakve konstrukcije sa cevkom na ulazu... Bastard, anyone?
Trenutno na sajtu 3 članova, 1 Skrivenih, 204 Gosta (Pogledaj celu listu)
Ukupan broj tema453.5k
