703 -
8
Postovi objavljeno od stefaca
Koji Linux
in IT
Mislim da ne treba praviti hype tamo gde ne treba. Instaliran Ubuntu i to je to. Nista vise, nista manje i eto. Cak i ceo kernel je cist Ubuntu. Mislim ne treba preterivati bas da je to najbolje za multimediu. Cak i ti sto napravise Pop rekose da se za development Znaci, jedna lepo ispeglana distribucija sto se UI tice.
Isto i sto se grafike tice. nVidia config je sasvim normalna UI alatka. Sve ono sto i X -configure izgenerise.
Pop probao pre 2-3god kada je i izasao. Ubuntu sa lepom temom i fancy izgledom.
Quote“Isn’t it just a re-skinned Ubuntu?”
This is a common question to come up, and one that makes our engineers cringe. Yes, Pop!_OS has been designed with vibrant colors, a flat theme, and a clean desktop environment, but we created it to do so much more than just look pretty. (Although it does look very pretty.)
To call it a re-skinned Ubuntu brushes over all of the features and quality-of-life improvements that Pop! developers work diligently to create. For an in-depth look at the effort and manpower that goes into updating and maintaining Pop!_OS, take a look at our Roadmap documentation and the This Week in Pop! series on Pop!_Planet. Below, you’ll find a general list of improvements that make Pop!_OS stand out.
2 hours ago, _MM_ said:
@Leonardo i njegova magija
Gdi nadje ovija pokazivaci?
https://www.linsoul.com/products/tinhifi-t2-pro?_pos=4&_sid=f01449c83&_ss=r
Par godina ovo vozim da kazem za poslovne svrhe. Meni mi OK. Doduse ne znam kako su nabavljive kod nas.
Sent from my POCO F1 using Tapatalk -
On 2/21/2021 at 11:37 AM, Doktor said:
https://mi-srbija.rs/smart-home/preciscivaci/mi-preciscivac-vazduha-3c Happy hour poceo
2 hours ago, Aleks said:
Okumica, nije loše Koje je štapče, ne vidim, kontam nešto 5-10 gr tb?
Ovo uzmi za bandara na jezeru, ako već nisi: https://www.ribolovackipribor.com/proizvod/fairy-river-dzigovi-crni/
veruj mi Lagani džig, mada meni radi i cimanje uz sporo ravnomerno povlačenje, po dnu naravno.
Kontaktiraj slobodno Danka Aleksića: https://www.facebook.com/Dankraftlures on rastura bandare na Adi, a proizvodi i fenomenalne varalice (ručni rad od balze), em će te uputiti šta i kako em će ti prodati neki komad - rade provereno.
Nisam neki bandardžija, al kad pređeš na smuđa i bucova na reci, javi se
Stapce je Okuma Psycho Perch UFR Spin, 1-8gr, 230cm. Po preporuci iskren da budem. Isto tako i masinicu. Od 3 nadjoh taj poslednji tip.
I da, hvala za savete. Poslusacu obavezno
53 minutes ago, ManicP said:
Pa tad je najbolji provod
Kasnije kreneneš mrsiš muda, filozofiraš o strunama, high end... ...poznata priča
Iskreno secam se pecanja kao dete. Odem i kazem: dajte mi strunu 0.15 i to je to. Sad nema strune kako ja to vidim svojim ocima. To monofil, fluorokarbon, pletenice. Ja se zbunio. Pa jel pletenica od 4 ili 8 niti. Tu krece stvar da se lomi. U svakom slucaju istrazio. Uzeo pletenicu, fluorokarbon za predvez. Voblercice nabavio, gumice narucene
16 minutes ago, Leonardo said:
^ Na šta ideš kad varaličariš?
Trenutni nivo mog varalicarskog znanja je ispod amatera. Moze se reci nivo duduk. Plan je bandar ili grgec kako ga zovu. Kontam za pocetak Ada jer je tamo stajaca voda pa da se naucim tehnici pecanja. Kasnije reka.
Oprema je UL kategorije sto sam i zeleo. Eto posle 25god da se vratim pecanju.
A da li neko moze da mi objasni razlike izmedju 3H i 3C? Vidim ovaj ima lasere i detektore svetla. Cemu to? Mislim, dal ima OLED ili ne mi bas ne igra ulogu. Vise razlike u filterima, koji je bolji, efikasniji?
36 minutes ago, Mikorist said:
Da uzemljene su sve šasije na zajedničko uzemljenje ...
A jbg ta eto trece zice.
- Mentok and gluv_i_udaren je reagovao/la na ovo
- 1
- 1
Ili do jednostavno standarda kako USB radi. Ne znam da neki uredjaj moze da detektuje neki USB uredjaj samo sa spojenim data pinovima.
Mislim meni nije problem da grunem jedan kablic za +5V i GND i to da ide na napajanje i drugi sa D+, D- i GND koji ide na izvor.
1 hour ago, NIXIE said:
Ne znam, ne mogu toliko da eksperimentišem, nije moj DAC. Odvojiću fizički parice za signal i napajanje nekoliko mm nekim distancerima koliko dozvoli prostor u snake skin.
Napisao sam da se zna ako neko nabavi D50S da ne gubi vreme sa 3 žice. Sa sve četiri radi, probano sa onim starim orange USB.
Sad sam se zbunio. Imam D50S i ja sam uradio sledece cisto da probam sta je minimum. Napajanje je externo i taj kablic nisam dirao. Ali zato onaj drugi koji ide na izvor sam bio odsekao i zeleo da ostavim samo D+ i D- i nije radilo sve dok nisam spojio i zicu za masu. Tako da potvrdjujem da za D50S data kablic mora da ima masu, D+ i D- (ova 3 su obavezna).
Uplatio.
Uskoro se nadam da će mi biti dostupan Topping D50S za probu, kažu da je dobar, ali ko to zna dok se ne čuje. Topping D10 je osrednji uređaj dok se ne modifikuje značajno.
Iskreno meni mi svira OK. Ne znam sad sa cime da poredim, ali sa dobrim napajanjem rezultati su dobri.
Slazem se. Iskreno naplacivali su mi, ali nisam imao cast da me oderu. Desilo mi se da narucim 2 identicne stvari i namerno odvojeno. Jedna prodje, druga dosla sa carinom. Smejao sam se, ali to je sto je. Vidi, tako bar ja mislim. Ako mi treba nesto ovih dana uzmem kod nas. Ali generalno za ovakve stvari imam vremena za cekanje pa ... Dok se uredjaj sklopi narucim i maltene stigne sve pre nego uredjaj bude gotov. Macura se ceka a kablovi sugurno na putu
4 minutes ago, Mikorist said:
jbmlga...bilo bi dobro da odvojeno prodaje utikače.
Ima, ali jebu nanulicu bas za razliku.
QuoteMoram da kazem nekoliko cinjenica:
- Ovaj konkretno Shuko i IEC ne mozete naci preko eBay ili drugih slicnih isajtova. On se ne prodaje preko interneta iz razloga sto je verna kopija i sto je izuzetno kvalitetno uradjen. Na netu imate mnogo ponuda slicnih konektora ali ovaj necete naci.
Mozda ima i jeftinije. Ovo poslao kao referencu o kojim konektorima se radi.
PS.
Na KP vidim da je cena dupla. Iskreno nije mi se zurilo. Narucio, stiglo, usrafio. Nema sta da se lemi. Ogulim zicu, gurnem, stegnem. Mozda krimp ko voli, ali ono za 15e razlike kako naplacuju na KP bas vala. Mene metar LAPP izadje bese 5e, konektori 10e. Na oglasima 30e. Znaci na 4 komada koliko mi treba trenutno razlika 60e
42 minutes ago, gluv_i_udaren said:
Jesu to oni ala Oyaide?
Kopije su u pitanju, ali top uradjeno. Vrhunski materijal. Jos se zbunio kada video imbus srafcice. Ipak kvalitetnija kopija. Nije iskljuceno da je razlika u odnosu na original samo sto nema print oznaku
Tipa: https://www.ebay.com/itm/oyaide-P-004E-C-004-Rhodium-Plated-AC-Power-Plug-IEC-Power-Connector-Power-Suppl/233045184134?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Trenutno na sajtu 2 članova, 2 Skrivenih, 194 Gosta (Pogledaj celu listu)
Ukupan broj tema434.9k
Zocky AYA DAC
in Digital
Sala na stranu. Sve cestitke obojici. Profi rad. Nema sta drugo da se kaze. Timski ste ga pokidali.
