42758 -
464
Postovi objavljeno od Mikorist
Design Philosophy Metrum Acoustics.pdf
Picture above is a part of our ears. It concerns the cochlea with is located in the inner ear. Every spot in the
cochlea is sensitive to a certain specific frequency. The highest frequencies are registered at the front while
the lowest are registered at the end of the cochlea. The basilar membrane, which is part of the cochlea,
functions as a base for 15 to 20 thousand hair cells. Each of these hair cells are connected to a nerve which
is connected to the brain. This is only a (very) short summary of the working of the ear because in truth, the
ear is infinitely more complex. We however will limit ourselves to the sensory cells (hair cells) that each have
describe a limited range of frequencies in such a way that they all overlap. The sum of all of these determines
the range of our hearing, which on average is between 20 Hz and 20.000 Hz. With 20.000 hair cells their
bandwidth is very small and thus very selective. This means that for one specific hair cell, except the specific
frequency that it is tuned to, a signal gets filtered out at 40 dB per octave. This means that our hearing on this
level behaves much like a band-pass filter, comparable to the filters found in CD-players. Implementing filters
of this level in a CD-player can thus be described as overkill.Because the basilar membrane behaves as a sharp filter for our hearing, it has become, in a certain way, part
of the DAC. The measurements on a NOS DAC are therefore not measured at its logical end-point, but
before the filter (our hearing). Herein lies the problem, which exists when comparing the actual time domain
results and the way in which the Jtest interprets and shows results.Pa zar nije tako - da je Vudu ?
Ako treba da prebrojavamo koliko ko ima dlačica u sredmjem uhu - mi preko 45 godina imamo manje od 15.000 - filtriranje je još jače
Bolje
- LightMatic and krca44 je reagovao/la na ovo
- 2
pre 1 sat, Mikorist reče
sad ću ja da uploadujem jednu traku direkt sa LP
- 1
- 1
OVO je da se uplašiš nisam slušao odavno - Naravno da imam LP
- Vix and LightMatic je reagovao/la na ovo
- 2
pre 44 minuta, Doktor reče
Maaaaaa, taj album je Remek Delo !!!
Treba čuti na 180 gr. vinilu.Smrt u boji.
AIR French Band – Moon Safari (2005, CD) - Discogs
WWW.DISCOGS.COM
View credits, reviews, tracks and shop for the 2005 CD release of "Moon Safari" on Discogs.Japansko izdanje CD - to imam u Flac
pre 4 minuta, Doktor reče
Zato AIR . . . . kidaaaaaaa . . . .
Kida kako se čuje
Nemoguće da još nekome nije neki deo stigao
pre 8 časa, NIXIE reče
U principu single OPA bi imao više smisla da se rade dva odvojena napajanja za analogni deo, kako za analogni deo PCM63 tako i za I/U. Miro je ostavio džampere da se to može izvesti, pa ko voli da troši ...
Dual OPA ima više smisla kad je jedno napajanje analognog dela.
Postoji li neka bitna razlika sa odvojenim napajanjima, ne znam. Verovatno je ima ali je minimalna.
Ama ovo radi kao babaroga ovako kako je dekuplirano u DAC.....Miro kaze da ne trebaju odvojena napajanja - on ne cuje razliku
Ti ako hoćeš ti stavi još jedan PSU2 pa ćeraj oba OPA zasebno...ali to košta burazeru....i ovo ovako je mnogo
pre 47 minuta, Doktor reče
Ovaj clanak je jos jedan dokaz propasti srpskog novinarstva.
Resavska skola, bolje reci kompilacija kritika iz svetskih ( citaj : US & UK glasila ). Najvrediniji su ovde komentari nasih citalaca koji daleko vise govore o RoP tv seriji.
Isti tekst i na Kuriru
doslovno prepisano jedno od drugih
Prve kritike serije „Gospodar prstenova: Prstenovi moći“: Trijumf ili debakl?
NOVA.RS
Najskuplja serija u istoriji, po romanu “Gospodar prstenova” Dž. R. R. Tolkina, sinoć je imala svoju premijeru sa prve dve epizode i odmah je dobila brojne recenzije. -
pre 20 minuta, gluv_i_udaren reče
muses02
Samo single moiže kod mene . Ni onaj adapter ne može - nije isto rastojanje
Trenutno na sajtu 10 članova, 1 Skrivenih, 24 Gosta (Pogledaj celu listu)
Ukupan broj tema435.1k
in Digital
Jesam gospodine
