Mikorist
Sve objavljeno od Mikorist
  1. Mikorist
    Tannoy Dorset
  2. Mikorist
    Sonido MLTL & OB
    ćudo, ćudo....
  3. Silicon Carbide Static Induction Transistors The static induction transistor (SIT) is a three terminal, vertical current flow, semiconductor device that most closely resembles the solid state version of the triode vacuum tube. [1][2][3][4] The SIT is also a voltage controlled, majority carrier device, and so it is one version of a field effect transistor (FET), where the voltage on the gate modulates the current flow between the drain and source regions. However, it has a few distinct differences. Most FETs are planar devices and have only a single gate to control current flow in the channel (where all terminals are in the same plane, and current flows horizontally parallel to this plane). However, the SIT is a vertical device, with two gate contacts on opposing sides of its channel. Thus, while planar FETs only exhibit current-voltage (I-V) characteristics similar to pentode vacuum tubes with saturating current levels, the vertical current flow and extra gate control of the SIT allows for an additional I-V regime which exhibits non-saturating current characteristics similar to triode vacuum tubes. [5][6][7][8] That is, under high drain bias conditions (V DS = 10's to 1000's V), the SIT exhibits current-voltage characteristics similar to vacuum tube triodes. Therefore, the SIT does not behave exactly as other FET devices, and so it should not be considered as just a "vertical FET". http://www.globalspec.com/reference/50916/203279/silicon-carbide-static-induction-transistors SIT po vertikali simulira triodu lampu a po horizontali pentodu lampu a nije ni samo klasican fet, nego V-fet (ne klasican).... sve u svemu sve je to zajedno i iznad toga.... ma bre, ludilo mozga.
  4. SIT simulates the characteristic of the triode vacuum tube very closely. sad koliko je to simuliranje priblizno cevima nije napisano precizno ali je napisano veoma blizu. u svakom slucaju SIT ima dušu.
  5. niko ovde mene ne s`vata odzbiljooooo 'bala te babuskicaaa
  6. Compared to other semiconductor materials, including silicon (Si) and gallium arsenide (GaAs), siliconcarbide (SiC)is relatively immune to external factors, including radiation and electromagnetic-pulse (EMP) effects. dakle lampe i SIT-ovi izdrzavaju samo nuklearni napad, zato ih i koriste za radare
  7. fabrication has been already realized in the form of a high-power transistor (2 kW, 8 MHz) cigla od 2 kW
  8. a SIT je zapravo OVO: This drain-current to drain-voltage characteristic simulates the anode-current to anode-voltage characteristic of the triode vacuum tube very closely. patent Inventors: Jun-ichi Nishizawa, Takeshi Terasaki videti - Field effect semiconductor device having an unsaturated triode vacuum tube characteristics: http://www.google.com/patents/USRE29971
  9. neizdrž........
  10. http://amp8.com/tr-amp/yamaha/yam-b1.htm anatomija B1
  11. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=390-806&utm_source=youtub&utm_medium=youtube&utm_content=390-806 da li je neko merio na slican nacin zvucnike ? valja li ovo ?
  12. mozda su upotrebljivi za pojacala za el. gitaru i/ili gitarske efekte ili kao ton generator šumahttp://youtu.be/PH54cp2ggFk
  13. Mikorist
    Zorin OS
    wget http://webupd8.googlecode.com/files/sharpfonts-2.1.shchmod +x sharpfonts-2.1.shsudo ./sharpfonts-2.1.shsudo rebootovim se postizu fontovi potpuno iste ostrine kao na windowsu videti : http://community.linuxmint.com/tutorial/view/365
  14. Mikorist
    DIY-Σ
    ćudo, ćudo
  15. Mikorist
    Zorin OS
    probaj: sudo apt-get install gnome-tweak-tool a ako ti dosadi gnome, ovo je Kubuntu sa old fashioned KDE3.5 (posto dobijem ospice {i}od KDE4) http://trinity.motivewellbeing.org/cdimages/thirdparty/ubuntu/
  16. Mikorist
    Zorin OS
    i dalje ... alergican. ako nekom zatreba samo gnome Ubuntu bez (Unity) : http://ftp.acc.umu.se/mirror/gnome.org/misc/ubuntu-gnome-remix/
  17. meni dosta i jedan B1 PCB plus 4 matched JFETShttps://www.passdiy.com/storeza 40$
  18. ko kaze. meni gori, ja imam Burning amp
  19. e pa dobro da znam da mi pravis (kad mi budes pravio) SIT amp sa povratnom spregom i R-core transformatorom. da rezimiram - cena je nebitna, odnosno bitne su samo silne nule
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 40 Gosta (Pogledaj celu listu)
    452.7k
