Showing content with the highest reputation on 02/16/16 u svim oblastima
  1. Cisto kurcenja radi, posto kablovi nemaju veze a i ponukan temom, uzeh novi FTA interkonekt. I u pravu ste. Nemaju veze al ne kablovi, vec jalova rasprava. I te kako ima veze u zvuku, To je naravno moje ubedjenje. Ko veruje u kablove, mono kristalni, nadrkanoslusljivi amorfni...kabl, gurace na svoju, ko ne veruje opet na svoju stranu. I svi su intimno u pravu. Treba li izdvojiti 50-100-200 E ili 0 E, nek odluci svako ponaosob za sebe. Ljudi ovo je hobi. Treba da uzivamo a ne da se nadkenjavamo u ovoj lepoti od hobija. Dovoljno je gnojava svakodnevnica da bi jei jos i ovde nastavljali. ... Uzgred, RTB Bor je proizvodio 99,985 bakar, proverio sa tehnologom postoji monokristalni, e sad, cemu to sluzi il ne sluzi, vi naravno to znate bolje od mene. Uzivajte braco, a ja odo da slusam Cile Mile, mlaka kaka jazz. Pozdrav P.s. Gospodo nesto mislim, Vas ni kilo dunje ne bi pomirilo u stavovima.... a po svim zakonima fiziologije bi trebalo
  2. Electrical conductors[edit] Single crystal copper has better conductivity than polycrystalline copper.[3] As of 2009, no single crystal copper is manufactured on a large scale industrially, but methods of producing very large individual crystal sizes for copper conductors are exploited for high performance electrical applications. These can be considered meta-single crystals with only a few crystals per metre of length. A single crystal or monocrystalline solid is a material in which the crystal lattice of the entire sample is continuous and unbroken to the edges of the sample, with no grain boundaries. The absence of the defects associated with grain boundaries can give monocrystals unique properties, particularly mechanical, optical and electrical, which can also be anisotropic, depending on the type of crystallographic structure. These properties, in addition to making them precious in some gems, are industrially used in technological applications, especially in optics and electronics Mislim da je takodje copy/paste iz Wikipedie...nema nigde pomena o bojlerima i cevima za etažno grejanje...
  3. Oj mladosti... da...
  4. Meni je ovo prosta masina Vrti Daphilu, Trosi 8W Sa JLSound DACom razbija.
  5. Impuls
    AK4490EQ
    vidim ostali nejasni moji navodnici i smajli. Ukratko, nakon dorade najbolji kineski kit. Prethodno su bili CS4397, Cs4398, AK4393, AK4396, PCM1798, PCM27xx
  6. Konačno tema u kojoj se priča o sečenju/skraćenju a ne o kalemljenju/produžavanju
  7. bas se trudim da shvatim sta sve ovo ima sa konekitorima i kablovima. Bas se trudim.
  • Trenutno na sajtu   3 članova, 0 Skrivenih, 112 Gosta (Pogledaj celu listu)
    452.8k
