Aleks Napisano Oktobar 5, 2021 Autor #45 Napisano Oktobar 5, 2021 pre 58 minuta, NIXIE reče još fali odozgo i biće ko Iskra Identično brate haha Samo što se razlikuje veličina, vešanje, papir, konstrukcija, način izrade, motor, magnet, princip, phase plug... sve ostalo je isto
NIXIE Napisano Oktobar 5, 2021 #46 Napisano Oktobar 5, 2021 Princip se ne razlikuje ni malo, imaš magnet i kalem i imaš 3way, gde je FR na open baflle. Sredinu ti vozi jedan driver, to je uglavnom ono što čuješ. Ono što ne čuješ, to radi jedan bas i jedan super tweeter recimo. Koliko vidim, samo je bitnija razlika u ceni.
vladd Napisano Oktobar 5, 2021 #47 Napisano Oktobar 5, 2021 2 hours ago, Aleks said: sve ostalo je isto Pogled koji se baca je potpuno isti 2a3 and Aleks je reagovao/la na ovo 2
prophet Napisano Oktobar 5, 2021 #48 Napisano Oktobar 5, 2021 The voice coil for the field coil driver now uses copper-clad aluminum wire. The cone and whizzer shapes have been improved. The motor geometry is a little better too, and the solenoid has been updated from a 6 Ohm to an 8.5 Ohm coil for about 1.7 Tesla in the gap. The phase plug is milled aluminum, with a faraday ring in its base, just above the gap. The moving mass is now down to 12.25 grams. The most recently completed drivers have a Qts of 0.43 and Fs is 17Hz. The open baffle pairs up the field coil with an Acoustic Elegance LO15-D16 with a custom phase plug. The LO15 is port constrained, much like slot loading. The field coil is magnet mounted. The baffles and sides are internally reinforced with aluminum. The baffles are santos mahogany (cabrueva), and the sides and bases are eastern hard maple. The current crossover is a simple 2nd order low-pass at about 400Hz, with the field coil running full-range. Friends have shared some great insights recently though, on how I can refine the crossover design. I'll be working on applying some of those ideas over the next couple of weeks... I'm hopeful that effort will include crossing at a bit lower frequency.Jbg kad vec ima takav drajver, mislim na F coil, koji ce mu bas helper i OB? Doktor je reagovao/la na ovo 1
Aleks Napisano Oktobar 5, 2021 Autor #49 Napisano Oktobar 5, 2021 Da ti budem iskren, i ja sam se isto zapitao. Drajver je 12 cola, Fs 17Hz, al možda za ljubitelje OB-a, a ima takijeh među ljubiteljima FR-a. Opet, možda zauzima manje mesta od bass reflexa, koji je oko 140L za njegov drajver, a i OB bass ima drugačiju dinamiku od ostalih - pa kako kome, po ukusu.
Zen Mod Napisano Oktobar 5, 2021 #50 Napisano Oktobar 5, 2021 pa treba mu bass helper zbog fizike nije napravio Perpetuum Mobile, nego FR driver
NIXIE Napisano Oktobar 5, 2021 #53 Napisano Oktobar 5, 2021 (izmenjeno) Sva sreća te košta ko nov omanji hibrid. Tako da ne verujem da će se tako skoro pojaviti u nas. I to nazvati full range je čisto preterivanje. Izmenjeno Oktobar 5, 2021 od NIXIE
Zen Mod Napisano Oktobar 5, 2021 #54 Napisano Oktobar 5, 2021 ja malo znam o predmetnom driveru, a to malo mi kaze da je jedan od naprednijih u aktuelnim desavanjima no, cini se da neki ojovud znaju mnogo vise ..........
Koja Napisano Oktobar 5, 2021 #55 Napisano Oktobar 5, 2021 (izmenjeno) Kako to svira off axis? Pošto kapiram da mu taj kompjuter pozadi lepo pegla on-axis Izmenjeno Oktobar 5, 2021 od Koja
prophet Napisano Oktobar 5, 2021 #56 Napisano Oktobar 5, 2021 Jeste, odlican drajver. Ja bih ga tako posedovao. No, govorim o primeni ne o drajveru.Malo i o samom drajveru. Jasno mi je da velika vecina ljudi ne ume da uklopi tweeter kako treba i da se zbog toga ide na fr varijantu. Verovatno je to i ciljna grupa ukoliko drajver ide u solo prodaju. Ali, mnogo je bolje imati poseban tweeter. Naravno, adekvatno primenjen. Danas ih bar ima odlicnih. Zbog toga bi verzija bez wheezer-a bila pozeljna. Pogotovo ako se pledira da se ume napraviti dobar zvucnik. Vidi se i na tim merenjima kako se wheezer ponasa. To je uobicajeno za taj tip drajvera. Sa druge strane sa ovakvim drajverom ne ici na tqwt je greota. Moje misljenje naravno. Sveukupno, dobio bi se mnogo bolji zvucnik u oba ekstrema. Mislim i da bi footprint bio tu negde. O koncepcijama:OB je bolji za sobe sa paralelnim zidovima. Ulazi dublje u sobu ali zato neverovatno rekreira prostor. Mislim da je u prikazanoj varijanti to poprilicno labavo sa jednim 12" helperom.TQWT trazi vise prostora oko zvucnika sa bocnih strana a ide blize zadnjem zidu. Neverovatan bas kad se dobro uradi. Poprilicno pojednostavljuje skretnicu.Treca varijanta bi bio hibrid, 3-way umesto 2-way ali sa ovakvim drajverom to bi bio overkill. Doktor je reagovao/la na ovo 1
Doktor Napisano Oktobar 6, 2021 #57 Napisano Oktobar 6, 2021 10 hours ago, prophet said: . . . TQWT trazi vise prostora oko zvucnika sa bocnih strana a ide blize zadnjem zidu. Neverovatan bas kad se dobro uradi. Poprilicno pojednostavljuje skretnicu. . . . IMO je ovo dobitna koncepcija za ovaj drajver. Dobro urađen TQWT sa vrhunskim FR drajverima je - penzija. Govorim iz ličnog iskustva ( dodatna sreća jednog audio "penzionera" je i još bar jedan par ESL-57, ako se nema prostora ili finansija za stakovanje istih ). Vix and Aleks je reagovao/la na ovo 2
NIXIE Napisano Oktobar 6, 2021 #58 Napisano Oktobar 6, 2021 Membrana 12", a pokretna masa nekih 12g. Pa to je ekstra tanko, nežno i suptilno. I verovatno isto toliko trajno. Mogu da zamislim one bele membrane kako lagano žute i postaju prašnjave i musave.
Zen Mod Napisano Oktobar 6, 2021 #59 Napisano Oktobar 6, 2021 kiselo ovo grozdje, mjkumu vladd, shonne and Aleks je reagovao/la na ovo 1 2
Aleks Napisano Oktobar 6, 2021 Autor #60 Napisano Oktobar 6, 2021 Zaebo se on tu nešto definitivno oko Mms, ili tim parametrom smatra samo samu težinu membrane, izmerenu na vagi. Ne postoji teorija da izmereni Mms bude 12gr, pa sve i da je od paus papira, jer u Mms se računa i težina kalema, pola spajdera (jesu konci ali i oni su nešto teški), pola vešanja i sav vazduh koji se nalazi u zamišljenoj zapremini membrane. A Niksi, piše lepo da je papir tretiran, što se žutenja tiče, ebaga sad Nije ti to Lauder
vladd Napisano Oktobar 6, 2021 #61 Napisano Oktobar 6, 2021 Sade im je (opet) moderan onaj koper klad aluminijum za kalem, upravo iz tezinskih razloga, pa je i on lak kao konac.
prophet Napisano Oktobar 6, 2021 #62 Napisano Oktobar 6, 2021 Ma i da ima masu kao Philips od 12 inča ništa ne fali. A lakši je sigurno.
Aleks Napisano Oktobar 6, 2021 Autor #63 Napisano Oktobar 6, 2021 Ma ko zna šta je radio. Zeznuti su ti washi japanski papiri, lako a nije krhko, još je on to nešto krivio. Kako, ne znam, možda pretpostavljam, a u suštini možda jako prosto... I tako dobio laganu, a snažnu membranu. Pređe damarom i večno.
vladd Napisano Oktobar 7, 2021 #65 Napisano Oktobar 7, 2021 Neki put se zapitam koji ce im takvi zvucnici za ovakvu muziku...?
prophet Napisano Oktobar 7, 2021 #66 Napisano Oktobar 7, 2021 (izmenjeno) Ko što rekoh, ne treba bas helper. Ova numera je opštepoznata i koristi se često u svrhu ovakvih demonstracija. Ali, to je samo jedna numera. Trebalo bi to svakako ozbiljnije testirati i slušati sa različitim muzičkim materijalom. Meni lično bi više značila druga vrsta demonstracije, ovo mi nije bilo sporno. Izmenjeno Oktobar 7, 2021 od prophet
