Weiss dac 202 ... zasto ???
Anubis
Evo šta kaže o razlikama jedan vlasnik Weiss-a 202 u odnosu na M-DAC, a pomenut je i M2Tech Young....
The Mdac doesn't use a wall wart, it actually uses a pretty damn hefty in line transformer to feed the internal rectification and smoothing stage. The transformer is as big a hunk of metal as you'll see in a dac, certainly it's twice the size and VA rating of the one inside my Weiss 202.
In fact the entire PSU section inside the Mdac is twice the size of what exists inside the Weiss, more low ESR smoothing caps, more diodes, more individual power rails, it's just more.
I'm fortunate enough to know John the designer and I actually have 'his' pre-production unit sat in my rack alongside my Weiss. Up until a week or two ago I also had the Young with an upgraded external PSU to compare the Mdac with.
The comment that the Mdac might be closer to the Arcam rdac than the Weiss is seriously wide of the mark, the Mdac is snapping at the heels of Weiss in terms of sound quality and in terms of functionality, interface and VFM simply wipes the floor with the Weiss at about 1/8 of the cost.
Compared to the Weiss the Mdac lacks a little in microdynamics, it's not quite as real sounding, but only marginally so, and it's a little darker sounding. But it loses very little to the Weiss and is a huge step up for the sub £500 usual suspects. I haven't heard the Ayre in my system but I did hear the Mdac and Young back to back and the Mdac was cleaner and less abrasive at the top end.
It's actually a very good dac, if you like the sound it makes then given the features there's nothing else at up to twice the price that I would consider serious competition. Of course there's no accounting for a preference for older multibit and NOS dacs so YMMV.
Link.... http://www.computera...414/#post112216
pratim pisanje doticnog i mogu da kazem da on blage veze sa zivotom nema a mislim da ima jos ljudi ovde koji su primetili nedoslednosti. pravio je napajanje za janga pa ga je tada dizao u nebesa. onda mu je vestlejk postao prijatelj, dobio je od njega licni primerak pa je krenuo da hajpuje MDAC da bi on izleteo iz sistema posle mesec dana. tacno toliko je zaziveo u njegovom sistemu dok ga nije promenio za vajsa. a kada su ga jednom pricepili na forumu apropo jang vs MDAC price, posto je ranije pisao nesto sasvim drugo za janga od ovoga sto pise danas, priznao je da ako funkcionalnost (digi pot) nije presudna, nema razloga prelaziti sa janga na MDAC.
sto za razliku od tebe ja mogu jedini da napisem, jer sam obe sprave imao po 6 meseci u svojoj sobi i vrlo dobro znam i stvarne mane i stvarne kvalitete oba uredjaja kada zivis sa njima, a ne dobijes ih na kucni demo.
uostalom, moze ZZZ kao covek koji radio par sabre DAC-ova da ti nesto kaze o MDAC-u, ne znam da li hoce
sto za razliku od tebe ja mogu jedini da napisem, jer sam obe sprave imao po 6 meseci u svojoj sobi i vrlo dobro znam i stvarne mane i stvarne kvalitete oba uredjaja kada zivis sa njima, a ne dobijes ih na kucni demo.uostalom, moze ZZZ kao covek koji radio par sabre DAC-ova da ti nesto kaze o MDAC-u, ne znam da li hoce
I na kraju, vrijedi li taj Mdac svoje pare? Ipak je nešto jeftiniji od Younga, ako se ne varam, a od Weissa da ne pričam. Ne očekujem da je bolji ii jednak ijednom od njih, nego jednostavno i kratko - ako su pare u pitanju, da li se MDac može odužiti svom vlasniku za odricanja?
"it's just a forum hype guys. if you really open your mind, i don't think you would ever need to spend more than 50 pounds on almost perfect hi rez dac. that's exactly how much a lampucera kit costs on ebay. you need a few drops of solder and a case - job done. you will forget all the mdacs, youngs and any other sub-few-grand dacs." - posted by anubisgrau on hi fi wigwam.com/forum
Ovo ste vi g. anubisgrau ?
Jel' ti stvarno misliš da je svakome kao tebi potrebno 6 meseci slušanja za
neke utiske i da si zbog toga jedino TI kvalifikovan da nešto napišeš o tome. :unbelieveble:
naravno, koliko kosta toliko i vredi. za ispod 1000e nisam cuo bolje.ali realno sve te nadrk nahajpovane DAC-ove posramljuje lampucera od 50 evra delova. samo pokazuje koliko malo treba da se dobije pristojan zvuk. naravno, i young i MDAC su bolji, nesporno, ali posto smo na DIY forumu, mnogo ima vise smisla baviti se tim alternativnim jeftinijim resenjima koje dolaze na 90% zvuka. 10% razlike jednako 20x veca cena.hahahahaha, sad vidim sta je ovaj pitbul nasao. da, upravo sam to napisao gore.first, radi se o bazicnoj objektivnosti, da prestanes da sprave koje posedujes dizes u nebeske visine, kao taj audiolab CDP. to sto je to masovna pojava, da bi se ljudi pripremili za prodaju jednog dana je jedno, a nekakvo argumentovano misljenje, namerno ne pisem objektivnost, je nesto drugo. ne mogu ovde ljude da lazem da je MDAC najveci audio izum od branka kockice na ovamo, samo zato sto ga posedujem, kada nije. ne znam zasto to radis, da li zbog odnosa sa distributerima koje imas kao njihov propagandista ili nesto trece, tek mislim da si ozbiljno far out sa svojim stavovima o nekim spravama. jos od naim nDAC sa onog javnog slusanja pa nadalje.
Poenta je da se moze kupiti cistokrvni, kvalitetan AMSTAFF za 200 eura bez "papira" i moze se kupiti isti takav sa papirima za 1000-2000 eura- to je smisao, a ne dal' neko voli pse ili dacove, dal' bi spavao sa njima ili sa weissom ... Ne moras da se slozis samnom, ali da li razumes sta ja hocu da kazem ???Izvinjavam se ... ja ne volim da pravim poredjenja izmedju zivih bica i limenih kutija.
Kad vec poredis, evo jos jedna inf., jeste da je off, ali je istinita...Covek iz susednog mesta, da ga ne imenujem- ni njega ni mesto ( tromedja ns-su -so) jer nije korektno, nema pojma da ovo pisem, povede pre 2 meseca u Nemacku na izlozbu svog psa nemackog ovcara...Pas postane svetski prvak. Prvi put u istoriji tog takmicenja u tom mestu da to nije pas iz nemacke. Po povratku u mesto narodno veselje. Posle 2,3 nedelje dolaze svabe da kupe psa...Daju 300k evra. da 300k.Covek ladno- nije za prodaju...Ako si u tim krugovima, brzo i lako mozes saznati o kome je rec...Tako da i toliko nabadanje o tome sta je skupo, a sta nije je potpuno bespredmetno, sto je tebi skupo, drugom nije i obrnuto. Uostalom rasprava- jadanje o tome bi bila prikladnija za onaj forum, ovde je vise radni a ne paradni forum...
Da, da,... ma baš smo ti poverovali da nisi video. :hot:
Šta da ti kažem,... evo vidim da si i ti postao propagandista za Lampuceru (definitivno imaš neki interes od Kineza),što je sasvim očigledno posle ovako oduševljenog pisanja po stranim forumima o istom DAC-u. Nije mi jasno zašto to radiš,ali već odavno ne uzimam za ozbiljno tvoje slušne utiske o raznoraznim uređajima. Ova Lampucera najlakše objašnjava i zašto.
I da ne bude zabune, ne trazim ja postove gospodina anubisgrau-a po netu nego sam citajuci o MDAC-u po raznim forumima naisao na njegov post.@ MILOVAN1963 Bilo bi dobro da procitas temu od pocetka da ne bi morao opet da objasnjavam da poenta nije u tome ko ima para a ko nema za weiss. Hvala.
procitana je, i iskreno, 90% mlacenje prazne slame...
Ne mislim nista lose, cak naprotiv, mislim da paznju i energiju na ovom forumu treba usmeriti ka tome kako napraviti nesto vrlo kvalitetno za razumnu kolicinu novca kojom raspolazemo, a ne na kukanje kako su bezobrazni poznati konstruktori od preko, tj kako deru sa cenama...
hahahahaha, daj bre, ne verujem
CAAAREEEE!!!!
Anubise , ti si definitivno promasio forum ...... nije mu primarna namena da se bavi niti sociologijom , niti sociopatijom , niti analitikom trzistada li si svestan da si napisao post br. 305 ?tema jednostavno nema smisla ......... bar da je zabavna (samim tim bi opravdala postojanje ) nego je presipanje iz supljeg u prazno , najblaze receno
