M2.5 screws + tapping tools.
InSides
If anybody cares to explain the issue at hand in English (too tired to spell my way through in
Serbian).
I'll happily help you out.
Magura :buehehe:
I will try to summarize.
I started this thread with the intent of acquiring several M2.5 machine head/allen head screws and a M2.5 tapping bit set, in order to, in the end, create a brass mounting plate for my Denon DL-103. I would like to run it nude to see what the hype is all about.
This is an example of the work I needed done:
Denon DL-103 and a brass plate
Alas, the gentleman that had built these in the past wanted $50 + shipping for a single plate, and I thought that I would be able to get the tools for that amount and still have the tools once I'm done.
But the nice gentleman at the board [namely ZM and stoN_Kold] offered to get the plate made for me and thus spare me of a potentially hideous monstrosity that would surely arise when I attempt to use such tools.
Seeing that I also am looking forward in getting my tonearm wire from these gentlemen, this is quite convenient.
Now, Mr. Magura, if you can help additionally in any other manner, it would be much appreciated.
All the best,
InSides, the Macedonian.
  • Odgovora 77
All the best,
Well, it depends, if you have only need for one piece.
If you would like to play around yourself, let me know.
I'll send you a M2.5 tap and some CuBe2.5. This should be sufficient to have fun :buehehe:
Magura :frusty:
Аааааааа! стоН_Колд, то је то!Ајде овако... декове можда не могу да нађем, али могу да обећам друго нешто.Пошаљите ви мени обојица те плочице/жице, плус две плочице екстра. Ја вам вратим те две екстра плочице са монтираним огољеним DL-103, за сваког по један. Рецимо да имам извор за јефтине Деноне, тако да ми није то неки велики трошак. :buehehe:П.С. ЗМ има моју адресу. :frusty:
 Ја вам вратим те две екстра плочице са монтираним огољеним DL-103, за сваког по један.  вП.С. ЗМ има моју адресу.
Питање: Јесу ли исправне те ДЛ-ке?Наравно качи слику те голотоње да видим :buehehe:.Зен има твоју адресу али Ја немам :frusty:. стоН_Колд
Sad i ja moram da se umesam kad se dele zvucnice. Nisam uspeo da ispratim sta se ovde trazi: ureznice, nareznice, stafovi, matice, plocice ili nesto drugo? stalno pricate u nekim siframa i nesto ne uspevam da pratim. Ako ti trebaju srafovi, mislim da imam i M2 i M2.5 ali ne u nemagnetnoj varijanti. Matice M2.5 imam ali bi bilo lepo da definises sta ti treba a sto se tice plocica iseci cemo tablu lima od 2mm na potrebnu dimenziju.
 Nisam uspeo da ispratim sta se ovde trazi!
Нисте колега нисте!
Било је ту свега и свачега: жица, касетофона, неизбежног Зена :frusty:, ма свега и свачега.
Препоручују за те Денон главе да завртњеви буду од Стакла :buehehe:, или од материјала сличног клириту.
Сва срећа те их имам :angry:
Разлог: ваљда Немагнетичност.
Плочице су направљене, спаковане са оном чувеном жицом и спремне за слање.
Чекам даљи развој догађаја.
У сваком случају хвала, сад знамо ко има таблу Бакарног лима :yes3:.
стоН_Колд
I šta sad :angry: Mene naruži Ston :yes3: Pukoh dek na poklon :yes3: a vi dijelite gram glave. :) Impules da znaš da si u pravu. :) Ostasmo kratkih rukava. :):frusty:
Хе,хе...није то колега(ако смем да будем толико слободан да те тако назовем) РЕВОКС ништа..Питам се коме ли је закинуо то парче лима што је морао пар пута сец,сец :):buehehe:
Питам се коме ли је закинуо то парче лима што је морао пар пута сец,сец :buehehe::frusty:
Ма Зен сигурно исекао казан за ракију.
Ништа од ракије следеће године, мада ни овогодишњу нисмо пробали :angry:
стоН_Колд
Ништа од ракије следеће године, мада ни овогодишњу нисмо пробали :frusty:
стоН_Колд
organizujte druzenje u prestonici , pa dolazim po Altec-e i donosim rakiju
:buehehe:
Хе,хе...није то колега(ако смем да будем толико слободан да те тако назовем) РЕВОКС ништа..Питам се коме ли је закинуо то парче лима што је морао пар пута сец,сец :buehehe::frusty:
Može kolega kako neProblem je što su kod nas donijeli zakon o zabrani pečenja rakije ukoliko nisi registrovao djelatnost proizvodnja alkoholnih pića pa ni za lijek nema više nijednog kazanainače druga bi priča bila :angry:Ostasmo bez "čuvene" domaće crnogorske loze. Što sad :yes3:.
