Zen Mod Napisano Novembar 28, 2010 Autor #706 Napisano Novembar 28, 2010 is heatsink colder in steady state or playing muzak ?
Zen Mod Napisano Novembar 28, 2010 Autor #707 Napisano Novembar 28, 2010 naive question - did you re-checked bias ?
sp300b Napisano Novembar 28, 2010 #708 Napisano Novembar 28, 2010 Bias is OK. Zen, You could check when You have time. Put IRFP150N on test under 2A on heatsink and measure temperature after let say 5 min (you have laser tool for temp. measurement, if i remember correctly). Do the same one day after (let the heatsink become cold) on with SJEP120R100...and we'll see.
Zen Mod Napisano Novembar 28, 2010 Autor #709 Napisano Novembar 28, 2010 nope I don't have any doubts - as I see it - both rheostats are the same , under quiescent conditionsbe it IRFP rheostat or SS rheostatso - just chill , take a shot of rakija and enjoy in sunday with family - with or without music
Magura Napisano Novembar 28, 2010 #710 Napisano Novembar 28, 2010 This just keeps getting better....First breasts, now rakija......what's next?Counting out boobs and booze, the fluffy serb is right. The reason for JFET's having higher efficiency in inverters, is that they cross zero in that application.Magura
Zen Mod Napisano Novembar 28, 2010 Autor #711 Napisano Novembar 28, 2010 Magura - refresh my memory - what's that black material you're using as heat spreaders carbon , cut from brake plates ?
Zen Mod Napisano Novembar 28, 2010 Autor #712 Napisano Novembar 28, 2010 btw - Magura - seems that Sloba somehow manage to get in Zen Mod state ........ brain confused :sarcastic_hand:now he can see how it's being me - all the time .......
Fukushima Napisano Novembar 28, 2010 #713 Napisano Novembar 28, 2010 Let's check the opinions of the others on Big Diy (link) Hehe, to nema veze sa primenom tih fetova u pojacalu, ako imas recimo 50W disipacije na tranzistoru onda imas 50W pa makar bio i od grafena
sp300b Napisano Novembar 28, 2010 #714 Napisano Novembar 28, 2010 Hehe, to nema veze sa primenom tih fetova u pojacalu, ako imas recimo 50W disipacije na tranzistoru onda imas 50W pa makar bio i od grafena Ok, ok...može bit da sam lupio, pa sam ostao živ.Ipak, manje mi se greje nego Babel originalni, a mrzi me da proveravam bias. Ubedjen sam da je sada na 2A u mirnoj tački i da ne mrda.Da li sam tamo na Babaelu bio nagruvao struju preko 2A, teško mi je sad da se setim...Pomislio sam na momenat da je u pitanju RdOn, koji je po svemu sudeći manji kod SIC MOSFETA, pa stoga manje energije inerno troši na grejanje...
Sipi Napisano Novembar 28, 2010 #715 Napisano Novembar 28, 2010 Tako je Slobo, povela te prica o prekidackom rezimu rada, nema veze... Ja bih pored mirne struje proverio da li ima i kolika je razlika u temperaturi izmedju tela tranzistora i hladnjaka.
sp300b Napisano Novembar 28, 2010 #716 Napisano Novembar 28, 2010 Temperatura hladnjaka je 42 stepeni. Radio je bar sat vremena pre merenja.edit: Temperatura sobe je 22 stepeni
Sipi Napisano Novembar 28, 2010 #717 Napisano Novembar 28, 2010 Temperatura hladnjaka je 42 stepeni....A jel' mozes da izmeris temperaturu na samom telu tranzistora?
sp300b Napisano Novembar 28, 2010 #718 Napisano Novembar 28, 2010 A jel' mozes da izmeris temperaturu na samom telu tranzistora?Izmerio 70 stepeni
Sipi Napisano Novembar 28, 2010 #719 Napisano Novembar 28, 2010 E to je to: hladnjak je 'ladan a tranzistor kuva - slaba termicka sprega izmedju tranzistora i hladnjaka. Dakle, na kucistu (telu tranzistora) ne bi trebalo da bude vise od 5 (uvr' glave 10) stepeni vise nego na hladnjaku, inace ce ova situacija polako da odvede u proboj tranzistora zbog preteranog zamora materijala vecom temperaturom od optimalne.Dakle, mesto na hladnjaku gde montiramo tranzistor treba da bude glatko i odmasceno, liskun treba da bude sto tanji a namaz kvalitetne paste izobilan. Pozeljna je podloska koja omogucuje da tranzistor bude cvrsto stegnut a pritisak ravnomerno rasporedjen po telu tranzistora i onda nece biti problema.
Magura Napisano Novembar 28, 2010 #720 Napisano Novembar 28, 2010 Magura - refresh my memory - what's that black material you're using as heat spreaders carbon , cut from brake plates ?Yes, that is a type of carbon, that is 100% carbon, as opposed to the regular types which is 90% carbon at best.It's called pyro-carbon, and is used for carbon brakes, surgical implants, and heatsinks for aerospace electronics and the like.Mine started out the life cycle as test brake discs for the car cabon brake project.Magura
Magura Napisano Novembar 28, 2010 #721 Napisano Novembar 28, 2010 btw - Magura - seems that Sloba somehow manage to get in Zen Mod state ........ brain confused :sarcastic_hand:now he can see how it's being me - all the time .......Yeah, soon he will start growing long hair and begin brewing rakija......Magura
Zen Mod Napisano Novembar 28, 2010 Autor #722 Napisano Novembar 28, 2010 E to je to:.......:rules:elem - valjda ce uskoro stici MOX-ovi ( sigurno pre punta ) , pa ce vadi djunte napolje i sredi to kako Bog zapoveda
Zen Mod Napisano Novembar 28, 2010 Autor #723 Napisano Novembar 28, 2010 Yes, that is a type of carbon, that is 100% carbon, as opposed to the regular types which is 90% carbon at best.It's called pyro-carbon, and is used for carbon brakes, surgical implants, and heatsinks for aerospace electronics and the like.Mine started out the life cycle as test brake discs for the car cabon brake project.Magura you told me once how much they're more effective than Cu spreaders ?
sp300b Napisano Novembar 28, 2010 #724 Napisano Novembar 28, 2010 E to je to: hladnjak je 'ladan a tranzistor kuva - slaba termicka sprega izmedju tranzistora i hladnjaka. Dakle, na kucistu (telu tranzistora) ne bi trebalo da bude vise od 5 (uvr' glave 10) stepeni vise nego na hladnjaku, inace ce ova situacija polako da odvede u proboj tranzistora zbog preteranog zamora materijala vecom temperaturom od optimalne.Dakle, mesto na hladnjaku gde montiramo tranzistor treba da bude glatko i odmasceno, liskun treba da bude sto tanji a namaz kvalitetne paste izobilan. Pozeljna je podloska koja omogucuje da tranzistor bude cvrsto stegnut a pritisak ravnomerno rasporedjen po telu tranzistora i onda nece biti problema.Sipi, zahvaljujem. Napravio sam tanji liskun pomocu skalpela (ovi providni su svarno bili debeli). Unistio 4 dinara za pričvršćenje Mosfeta na ZM nacin i ponovi prišrafio. Nadam se da će biti bolje sada. Sada idem da rakijam
sp300b Napisano Novembar 28, 2010 #725 Napisano Novembar 28, 2010 :rules:elem - valjda ce uskoro stici MOX-ovi ( sigurno pre punta ) , pa ce vadi djunte napolje i sredi to kako Bog zapoveda
sp300b Napisano Novembar 28, 2010 #726 Napisano Novembar 28, 2010 ZM, napon na izlaznom otporu je 0,92V na oba kanala. Dakle bias 1,85 A, ako su otpori stvarno 1 Ohm...Neka, doci se MOX, pa ce ga narihtamo ponovo na 2A.
