ninja
Sve objavljeno od ninja
  1. ninja
    ACUTEX
    Da dodam, ovo mi je favorit koji je skinuo DL-103R sa liste
  2. ninja
    ACUTEX
    I named them the bass monsters. Probably coloured but who cares? If I need bass, I call the Acutex. There are some weird things about these cartridges.I first heard of Acutex when I somehow got a Piezo YM-308 in my hands a couple of years back (I can't remember how). At the time I assumed it was somewhat of a lowly cartridge, probably with a conical tip so I never paid much attention to it. One day I just mounted it for fun and I thought this cartridge was sounding much more interesting than I wrongly assumed. So I tried to get some info about it and found out that Piezo=Azden=Acutex. Azden remained a bit of a mystery but there were bits and scraps of information to be found about Acutex. I believe Acutex was the American brand name of Piezo/Azden.My info so far as found in different places on the net:Two series of cartridges of interest: the M3xxIII and the M4xx series. The M3xxIII series I'm talking about are the M310 through the M320 models, not the M306 (conical) and M307 (elliptical) models. I think these are not interchangable with the others. These 2 don't have the tri-pole system but the dual-pole just like the M206, M207 and M208.Of the M3xxIII series there are two different body versions: the old flat nose (end 70's) and the newer long nose (beginning 80's). The M4xx series only consists of long nose versions. The long nose versions are all LPM, Lowest Possible Mass (what a statement!).Both series are "Tri-pole Induced Magnetic Systems" with a US patent.The M3xxIII long nose version has a different stylus mounting than the M4xx series so styli are not interchangeable. I like the M3xxIII mounting over the M4xx because it's much more secure, it feels less flubby. The original flat nose version is even better, it's the best stylus mounting I've ever seen: easy, safe and firm, just the way I like it. The big magnet keeps the stylus in place.Gold pins on the 315,320 and on the 415/420.Both series have a stylus range from 1 elliptical to 3 so-called STR (Super Tri Radial??) styli.M3xxIII series both flat-nose and long-nose models:310: 0.3x0.7 mil elliptical, aluminium cantilever312: STR 0.3x1.6x0.6 mil, aluminium cantilever, bonded315: Perfect STR 0.3x1.6x0.6 mil (selected from 312??, nude??)320: Perfect Vital STR 0.3x1.6x0.5 mil, titanium cantilever, nude mounted? The 320 has the lowest mass jewel.M4xx series:410: probably 0.3x0.7 mil elliptical412: STR (no stylus dimensions)415 & 420: Perfect STR (no stylus dimensions)The M4xx styli have a translucent plastic body, the M3xx have not.The M3xx series old flat nose style should have a DCR of 610 Ohm.The M3xx series long nose should have 580 Ohm.The M4xx series 710 Ohm.I measured them and it doesn't really add up.M3xx old flat nose body: 625 & 589 Ohm, in range of stated 610 OhmM3xx long nose body: 515 & 515 Ohm (wow!), in range of stated 580 OhmM4xx body: ranging from 435 to 460 Ohm, measured with 3 bodies. No way near 710 Ohm as stated in the booklet.Weird isn't it?Acutex revised the tracking force for the M3xxIII series long nose to a much higher VTF. For example the M320III: original VTF was 0.4-0.75mg, revised to 1.5-2.3mg. Makes you wonder about the compliance figures. M320III has 42x10-6 cm/dyne. Weird, isn't it?Enough with all the words, let's have some pics!
  3. ninja
    ACUTEX
    Jedna od odlicnih zvucnica za male pare: ACUTEX M 312 III STRAko nadjete M320 jos bolje!http://www.lencoheav...p?topic=6675.45v Edit: Ovo neka bude Novogodisnji poklon od mene :-)
  4. Niko nije operisan od toga ali srecom, uzimaju sve na svoju odgovornost i placaju sve troskove. U ponedeljak dolaze po paket.
  5. Continuo stigao, ali posle dugog putesestvija i nemilosrdnog tumbanaj od strane poste, sa ostecenim plintom i polomljenom rucicom ... sreca, pa je proizvodjac i novi vlasnik, Håkan Agborg, vrlo razumna osoba, tako da je vec poceo da pravi novi, koji treba da stigne krajem sedmice.
  6. Ziki treba nesto ovako, LA 211 pse
  7. Sold je prodato, Salg je prodaja!
  8. Da ih prodam ako ih uzmem
  9. Ako prihvatim, imacu 4 ona prva i 2 ona druga ... i nije problem da ih prosljedim uz jedan mali detalj
  10. Kakav je kvalitet dole navedenih Beyma drivera: 1.) Beyma 15P80Nd 2.) Beyma TPL-150H Nude mi ih u zamjenu. Je li to ista vrijedno?
  11. ninja
    Tannoy Dorset
    Gdje si slusao GedLee i koji model? Moze malo info? Sta se savjetuje uz njih? Obicno ih na slikama vidjam zakacene na zidu ... malo groteski sa tom velicinom ali opet bolje nego 2m u sobi
  12. Posao kod Tannoy!
    1. Show previous comments  3 more
    2. ninja
      ninja
      Sto ste pesimisti. Moze Boki ...
    3. Zvu
    4. stein
      stein
      Eh, što Clearaudio ne traži nekog da im pravi gramofone! ROFL
  13. .. a sto si mene zaboravio
  14. ninja
    DIY gramofon II
    To sam planirao kada ga dobijem (posta ga izgubila), sa malo objasnjenja i mjerama. Inace, nema neke specijalne mudrosti i tajni.Oni prodaju sve dijelove za ovaj gram i rucicu!
  15. ninja
    DIY gramofon II
  16. To je pijaca Imas jos malo vremena, upravo sam zavrsio sa pakovanjem, polica prazna na vrhu Iza ove kafane ... Problem je da mi je posta izgubila paket sa novim!!?? ... osigurano tko da nema novacanih problema .... problem je da mu kasne francuski motori tako da ne moze drugi da sklopi jos par sedmica
  17. Ma lako je naci, odmah pored Arnolds kiosk
  18. ninja
    DIY gramofon II
    Pazi, pazi... ova rucica mi promakela
  19. Ma tebi to ne treba, ti imas jos bolji
  20. Orbe/SME sutra leti a stari favorit ih zamjenjuje i vraca se na mjesto. Vrlo interesantan gram ili bolje receno rucica za DIYere
  21. Ako hoces drveni plint, ima tip na ebayu i pravi ih "jeftino", 80-150$, samo sto je postarina skuplja (teski). Hoces za 1/2 rucke, 9''/12'',... sve moze Mislim da je tip iz Litvanije ili tako nesto ... Evo nasao sam ga: http://stores.ebay.com/megaposters
  22. Crni granit, ovdje ga zovu diabas.
  • Trenutno na sajtu   3 članova, 0 Skrivenih, 786 Gosta (Pogledaj celu listu)
    453.8k
