prophet
Sve objavljeno od prophet
  1. prophet
    Zamena za 2SK79
    Mislio sam za neki phono. Jel može rudarska kaciga da posluži?A ovo sam mislio za neki phono da hrčkujem.
  2. prophet
    Zamena za 2SK79
    ovo se vrlo lako moglo meni desiti
  3. prophet
    Zamena za 2SK79
    2SK79 (same characteristics like 2SK63, but with plastic housing), so the 2SK63 was probably used in the first batch.
  4. prophet
    Zamena za 2SK79
    Mislim da je nešto slično bilo u ovom uređaju (sk63 ili 68 ali nisam siguran): http://www.kupindo.com/kupljeno/9409371_Wega-V4810-V-FET-Veoma-kvalitetno-pojacalo a evo i ko ga je kupio: http://www.kupindo.com/Clan/choky/Pozitivne
  5. Plastikaneri
  6. http://www.artproaudio.com/products.asp?id=58&cat=1&type=79
  7. Pravio je Sony nešto slično pre 23 godine: Bio-Cellulose tweeter is threaded by acetobacteriae aceti, giving in the end a driver which is stiffer than anything although thinner and lighter than anything, with a resonance peak which is way above that of Beryllium for instance.The raw bio-cellulose "pad" is then pressed to become the actual diaphragm, bonded with thermosetting epoxy adhesive to the pure aluminium voice coils.The thickness of the bio-cellulose diaphragm is 1/1000 that of paper and 1/300 that of silk ; its weight is 1/2 of a silk diaphragm.Bio-Cellulose was a joint development between Sony and Ajinomoto Co., Inc. and three corporations of the Agency of Industrial Science and Technology Research Institute for Polymers & Textiles in Japan.
  8. prophet
    Programiranje muzike...
    Da, ovo su samo primeri koji su semplovi korišćeni i na koji način su obrađivani. U vreme nastanka nisu postojale ovako jake mašine i rađeno je na drugom softveru, moguće i direktno na hardveru. Veoma interesantno, mnogi će se iznenaditi odakle su uzeti rifovi itd. Dobar primer za reversni inženjering. Ovo sam video još sredinom prošle godine. Super što si postavio, skroz sam zaboravio na ovo. 80-ih se dosta radilo na eksperimentisanju, ljubitelji prave elektronike će se sigurno setiti Humanoid-a (kasnije FSoL). Na žalost 90-ih je sve otišlo u qrac, čast izuzecima.
  9. Na Mek-u sa flash-a bolje svira. Za PC ne znam.
  10. 700,000,000kB je 700GB. Koliko RAM-a imaš? Preporučuju 750.000 pod uslovom da ne radiš ništa drugo sa kompom osim puštanja muzike. Probaj tako, ako te zeza smanji.
  11. Da bi radio kao memory player tj. da učita fajl u RAM i odatle ga reprodukuje. Veličinu bafera odredi sam, mislim da ti je obzirom na veličinu RAM-a ovo dovoljno.
  12. Ne znam odgovore na ova pitanja. Dakle instalirao si KS? Da li sada hoće da pusta sve fajlove?
  13. Prve pokretne stepenice u Uzbekistanu:http://www.youtube.com/watch?v=50eHW8z8zIw
  14. Misliš 24/192? Onda ne koristiš USB već coax ili optiku. Zbog toga U Foobar--> Output odaberi KS:odgovarjjući SPDIF. Probaj sa kernel i počni polako da podižeš rezoluciju jer postoji mogućnost da integrisana kartica ima neka ograničenja. Mislim da je meni sigurno radila do 24/96 a moguće i 24/192.
  15. Registracija ćiriličkog .srb Internet domena, počeće danas, na Svetog Savu, najavljeno je na sajtu Registra nacionalnog Internet domena Srbije (RNIDS). Odluku o početku registracije doneo je Upravni odbor RNIDS na sednici od 13. decembra. Prvih šest meseci pravo preče registracije .srb domena imaće samo vlasnici postojećih .rs domena, i to po ceni od jednog dinara. Posle tog perioda, ćiriličke domene moći će da registruje svako ko želi, bez obzira da li poseduje određeni .rs domen ili ne. Ćirilički Internet domen .srb je novi, drugi nacionalni domen Srbije, a posle ruskog .rf i drugi Internet domen na svetu na ćiriličkom pismu koji je moguće registrovati. Domen .srb je deo porodice internacionalizovanih domena (Internationalized Domain Name - IDN), odnosno domena čiji nazivi nisu napisani engleskim alfabetom. Svoj IDN na nacionalnom pismu već imaju najprostranija i najmnogoljudija zemlja i narod u svetu - Rusija i Narodna Republika Kina, kao i mnoge arapske i dalekoistočne zemlje. Nacionalni domen je oznaka teritorijalne pripadnosti i kao takav izuzetno je bitan za definisanje Internet identiteta svih koji žive i rade u Srbiji. Zahvaljujući osobenosti srpske ćirilice da jednom glasu odgovara jedno slovo, adrese .srb domena će se, za razliku od mnoštva domena na engleskom alfabetu, nedvosmisleno izgovarati upravo onako kako su i napisane. Stoga je i slogan kampanje za popularizaciju korišćenja .srb domena "Linkuj kao što govoriš!".
  16. Tek sada vidim da imaš i (USB) DAC. Koji model je u pitanju? Verovatno je limitiran na 16/44(48). Zato ti i traži da uključiš resampler i smanjiš rezoluciju. Tako da DAC koristi za manje rezolucije a integrisanu zvučnu za veće.
  17. U Foobar--> Output odaberi KS: HD Audio naziv zvučne kartice (pretpostavljam Realtek)podesi buffer lengthoutput format 24-bitU Advanced--> Playback-->Full file buffering stavi 500.000Obavezno isključi Foobar pre postavljanja .dll fajla u components. Kada ga ponovo pokreneš onda sledi ove korake.
  18. Za XP probaj sa kernel strimingom, meni je radio bez problema. Skini dll za kernel sa foobar sajta. Wasapi bi trebalo da je pisan za VISTA i W7. Sa ASIO sam uvek imao problema i na XP i na W7.
  19. prophet
    Zvuk ekonovejva
    Stevo, gde si slušao Sentry?
  20. Phono:
  21. http://www.diyaudio.rs/topic/1255-ibanez-starfield-5050w/
  22. Priznaj da nisi koristio oroginal EVA.
  23. To je ono što stavljam ispod zvučnika.http://www.kupujem.rs/strunja269a-evaab-p-1306.html
  24. Zašto ga dampiraš, zbog buke?
  25. Premešteno iz teme o zvučnicima. Zvu Ja ne znam gde ima da se kupi to što ti treba ali znam gde ima da se kupi eva sardina.
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 157 Gosta (Pogledaj celu listu)
    453.6k
