Eci
Sve objavljeno od Eci
  1. Već na prethodnoj slici, kutije su okrenute - stoje na delu T, zbog velikog nagiba lakše je postavljati MDF letviceZavršena gornja krivina On the previous picture, the boxes are already turned ,and laying on the part T, because the large slope; it is easier to set the MDF stripsThe upper curve is completed
  2. Nastavak Process continues
  3. I kreću letvice. Obe kutije su radjene istovremeno. And the strips setting begins. Both boxes are done simultaneously.
  4. Kutije se zatim polože na ledja, radi formiranja gornje krivine sa MDF letvicama. Svaka se posebno obradjuje kao i kod donje krivine. After this process the boxes should be laid on the rear side, to form the upper curve with MDF strips. Every strip should be especially processed, like by the lower curve.
  5. I gotova je donja krivina And the lower curve is finished
  6. Nastavak Process continues..
  7. Nastavak Process continues..
  8. Formiranje gornje i donje krivine je izvedeno sa MDF 19mm, svaka MDF letvica je obradjena sa 4 strane, pošto se dimenzije menjaju sa promenom nagiba.. Forming the upper and lower curve was realized with 19mm thick MDF. Each MDF strip was processed from four sides, because the dimensions are vary with the change of slope ..
  9. Postavljeni nosači The carriers are set
  10. Postavljen gornji nosač The upper carrier added
  11. Nosač za formiranje gornje krivine Carrier for forming the upper curve
  12. Postavljen donji nosač The lower carrier added
  13. Ovaj deo nije na crtežima. Ovako rešenje je primenjeno za formiranje krivina prednje horne. Napravljen je nosač, koji naleže 5mm na otvor prednje strane H, i jedan deo iznutra na H. Zadnji deo nosača naleže na S1. Isto, nosač je uradjen i za gornju krivinu, sa istim principom naleganja na H i S1.Nosač za formiranje donje krivine This part is not on the drawings. This solution was applied to form the curve of the front horn. There was made a carrier which one part lays 5mm on the hole of the front side H, and the other part lays inside the H. The rear part of the carrier lays on the S1. The same way, another carrier was made for the upper curve too, with the same principle of laying on H and S1.On the picture : carrier for forming the lower curve
  14. Pogled od napred posle ubacivanja K Front View , K parts are added
  15. pa levo.. And left..
  16. Ubacivanje dela K, desno Adding of the part K, right
  17. Furniran S1.Stranice A nisu zalepljene, gornja ploča G nije zalepljena. Razlog je velika težina kutija, koje će se u kasnijim koracima morati okretati. Part S1 veneered.The A sides are not fixed, the top plate G is also not fixed in this moment to the box. The reason is the large weight of the boxes, which should be rotate in later steps of production
  18. Furniranje dela S1 Pasting the veneer on the part S1
  19. Pogled od nazad posle svih ovih zahvata Rear View , after these procedures
  20. Pogled od nazad, vidi se razmak izmedju dela W i P , kao i ulazi u tunele ( dole ) levo i desno Rear View , you can see the gap between parts W and P, also ( down below ) the beginning of left and right tunnel
  21. Pogled od napred, kompletirane stranice tunela Front View, the tunnel sides are completed
  22. Ubačeni trouglovi ( crvene strelice ), pogled od nazad The triangles are inserted (red arrows), rear view
  23. Pogled od gore View from above
  24. .. Pa levo.. and left side
  25. Deo zalepljen desno.. That part glued on right side..
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 100 Gosta (Pogledaj celu listu)
    450.7k
    Alen
    Alen
