Eci
Sve objavljeno od Eci
  1. Deo koji zatvara O,D,H,F - žuti krug The part which closes the openings between parts O, D, H and F – yellow circle
  2. Sledeći delovi nisu na crtežima, ubacuju se u toku rada. Radi se o formiranju tunela, postoje otvori izmedju delova O i dela P, zatvaraju se sa trouglovima ( formiraju se stranice levog i desnog tunela ). Označeno na slici sa crvenim strelicama. Takodje postoje otvori ( levo i desno ) izmedju delova O, D, H i F - to je na slici zaokruženo žutom bojom, koji se zatvaraju delom koji je na sledećoj slici ( trapez čija je donja ivica oborena na 45*, ta ivica naleže na O ) The following parts are not on the drawings, they are inserted during the building process; They are necessary for tunnel forming. There are openings between the O parts and part P, they should be closed with triangle shape parts (they forming on this way the sides of the left and right tunnel). That is marked on the picture with red arrows. There are also openings (left and right ) between the parts O, D, H and F – they are on the picture circled with yellow. That openings should be closed with a part what is shown on the next picture (a trapezoid, whose bottom edge is lowered to 45 *, that edge comes on the part O)
  3. Pogled od nazad Rear View
  4. Dodavanje dela TAdding of the part T
  5. Pogled od nazad Rear View
  6. Iz drugog uglaFrom another angle
  7. Dodavanje dela HAdding of the part H
  8. Pogled od nazadRear View
  9. Iz drugog uglaFrom another angle
  10. Pa deo C na R i D sa suprotne strane Connecting of part C on parts R and D from the opposite side
  11. Pogled od nazadRear View
  12. Spajanje dela C sa delovima R i DConnecting of part C with parts R and D
  13. Bez stegaWithout clamps
  14. Pogled od nazad Rear View
  15. Spajanje dela H sa delovima OConnecting the part H with O parts
  16. Dodat i deo FPart F is also added
  17. Spojeni delovi C i B Connected Parts C and B
  18. Pogled od nazadRear View
  19. Ovaj deo takodje nije na crtežima, ubačen je u toku rada, sprečava vibriranje dela W. Radi se o uporniku koji se nalazi izmedju W i L, trapeznog je oblika. This part is also not on the drawings, it was inserted during the building process, prevents the vibration of part W. It is a trapezoidal shape vertical part located between parts W and L.
  20. Pogled od gore View from above
  21. Pogled od nazad Rear View
  22. Ubačen deo W. Inserted Part W
  23. Proba: kako se deo W uklapa - veoma bitan deo, razdvaja kompresioni deo kutije od unutrašnje horne, formira ujedno i grlo horne Ostali delovi su stavljeni sa stegama, čisto da se stekne uvid, kako će to izgledati Test: How the part W fits - a very important part, separates the compression part of the box from the inner horn, and also forms the horn throat. All other parts are placed with clamps, just to see how the box will look like
  24. Formirani deo TOjačanje na sredini nije na crtežima, ubačeno je u toku rada Completed part TThe vertical part on the middle is not on the drawings, it was inserted during building process
  25. Pogled od nazad Rear View
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 104 Gosta (Pogledaj celu listu)
    450.7k
    Alen
    Alen
