Eci
Sve objavljeno od Eci
  1. Postavljanje dela J Installation of part J
  2. Pogled od nazad Rear View
  3. Delovi S1 i S2 sa crteža WMR 18, unapred se zalepe S1 je 6mm debeo bukov šper, S2 je 28mm MDFPostavljanje nosača ( S1+S2 ) za HPD385 Parts S1 and S2 ( from the WMR18 drawing ), they are connected in advance. Part S1 is a 6mm thick beech plywood, the part S2 is a 28mm MDFOn the picture : setting up the carrier (S1 + S2) for the HPD385
  4. Pogled od nazad Rear view
  5. Deo L izmedju D stranica Part L between D sides
  6. Deo P na deo Q Part P goes on part Q
  7. Pogled od napred Front view
  8. Opet D na R Again part D goes on part R
  9. Pa D na R Part D goes on part R
  10. Kreće sastavljanje: Deo Q na deo R And starts the assembling: Part Q goes on the part R
  11. Spojeni delovi O The O parts are connected
  12. Stranice D, nalepljene lajsne D sides, pasted moldings
  13. Slika iz radionice Image from the workshop
  14. Spojeni delovi F i C Parts F and C are connected
  15. Vezivanje dela F na deo C Binding the part F to the part C
  16. Deo T iz drugog uglaTreba primetiti da je i ovaj deo isfurniran ( gornji deo tunela ) Part T from a different angleThis part was also veneered in advance ( the upper part of the tunnel)
  17. Izgled završenog dela T The look of completed part T
  18. Izgled kompletnog dela R The look of completed part R
  19. I za prednju stranicu H And for the front side H
  20. Isti momenat iz drugog ugla The same picture from a different angle
  21. Za stranice CFor C sides
  22. Lajsne za stranice DMoldings for D sides
  23. Ovo je prvi korak. Radi se o delu R, na kojem su iscrtane linije gde treba postaviti lajsne. Vidi se takodje da je donji deo tunela isfurniran. Lajsne su postavljene za deo Q. This is the first step. Here is the R part, on it are drawn marking lines, where the moldings should be placed. You also can see that the lower part of the tunnel is veneered in advance. Moldings are set for a part Q.
  24. Izrada kutija je trajala oko dva meseca, od toga više od mesec dana je trajala priprema - nabavka materijala, nalaženje pravih osoba za odredjene postupke oko izrade pojedinih delova.Na krojnoj listi ( WMR19 )fali: 1 daska hrast dužine 5m širine 40cm i debljine 5,5cm potrebna za ukrasne lajsne, 1 daska bukva dužine 4m širine 20cm debljine 2,5cm potrebna za izradu upornika i ramova za maske. Takodje potrbno je oko 18kg lepka za drvo ( Henkel moment ) i više od 2kg Henkel ekspres lepka ( kao univerzalni ) za lepljenje furnira na manje površine. Korišćen je hrastov furnir ( slavonski, extra kvalitet ), potrebno je oko 30m2 za komotan rad.Lepljenje furnira: zbog ogromnih ravnih površina, ručno je to nemoguće izvesti. Treba naći presu, najbolje kod stolara koji izradjuju vrata, imaju prese 2mx1m i furniranje je tada besprekorno. Neke stranice treba unapred furnirati, kao i neke delove - pre same gradnje. Pogledati explode view :A : obe straneB : duža stranaC : jedna strana ( jedna leva i jedna desna po kutiji )E : jedna strana kompletno, druga strana delimično ( zadnja vidljiva strana tunela )G : jedna stranaH : jedna stranaR i G : po dve trake, gornji i donji deo tunela. Slike slede: The production of this boxes lasted about two months, more than a month took me to prepare: procurement of materials, finding the right people for production of several parts. On the cut out list (WMR19) is missing: 1 oak plank width 40cm, 5m long and 5.5 cm thickness what is needed for decorative moldings. 1 beech plank width 20cm, 4m long and 2.5 cm thickness required to produce internal moldings and for the frames of decorative masks. Also is needed about 18kg wood glue ( Henkel Moment ) and more than 2kg Henkel Express glue (as universal glue ) for sticking veneer on smaller areas. Oak veneer was used ( from Slavonia/Croatia, extra quality ), needed about 30m2 for comfortable work. How to stick the veneer: because of the huge flat surfaces, with hand work that is impossible to manage. It is the best to find a press with dimensions 2m x 1m by some carpenter which makes doors, with this press the veneering is perfect. Some parts should be veneered in advance. Take a look to explode view: A: both sides B: longer side C: one side (one left and one right for each box) E: one side completely, the other side partly (the visible rear side of the tunnel) G: one side H: one side R and G: two strips, the top and the bottom of the tunnel Pictures are following:
  25. Kasnije ću staviti i slike koje su nastale u toku izrade kutija. Later I will put the pictures which are made during the box production process.
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 104 Gosta (Pogledaj celu listu)
    450.7k
    Alen
    Alen
